Pages: 1 [2] 3   Go Down
Author Topic: SG&K 1920 Gentleman's Runabout MK2  (Read 16388 times)
canabus
Re: SG&K 1920 Gentleman's Runabout MK2
« Reply #25 on: July 29, 2017, 11:28:52 am »
Hi All
Finally closed in the stern with the help of my magnets with handles!!!
A bit of sanding, fibreglass resin and spray putty/undercoat.
I have a lovely rear end (not mine)!!!
Canabus
pompebled
« Reply #26 on: July 30, 2017, 11:12:26 am »
Hi Canabus,
Aha, I already wondered how you were going to get those supermagnets out of those confined spaces...
Handles, very clever!
Regards, Jan.
Boaters are nice people
canabus
« Reply #27 on: July 30, 2017, 11:43:41 am »
Hi Jan
I also added 10mm squares of plywood to the standard magnets to help stop them breaking when they drop onto hard floors.
I do not plan on testing this one out hopefully!!!
Canabus
canabus
« Reply #28 on: August 03, 2017, 10:14:12 am »
Hi All
Installed the aft deck and started planking with the outer planking in two pieces(forward and aft).
It was only because of the width and length of the free veneer a mate gave me.
I cut out the center pieces and the cockpit area(a bit extra in this area).
The outer sides I left about 5mm extra.
Very interesting cutting veneer and not breaking it!!
One of my mad ideas to test myself out!!!!
Canabus
« Reply #29 on: August 03, 2017, 11:28:22 am »
Nicely shaped asrse .... stern!
canabus
« Reply #30 on: August 03, 2017, 12:17:53 pm »
Hi Martin
In this day and age the spelling is R-SEND !!!
canabus
« Reply #31 on: August 08, 2017, 10:09:16 am »
Hi All
Cracking on with the deck planking, she is looking pretty sweet!!!
Canabus
« Reply #32 on: August 08, 2017, 08:17:22 pm »
That's going to look something special when varnished  :-))
canabus
« Reply #33 on: August 10, 2017, 09:00:14 am »
Hi All
Well I finally finished the planking !!!
Canabus
canabus
« Reply #34 on: August 15, 2017, 07:37:42 am »
Hi Guys
After sanding the deck, I vanished with two coats that was OK.
A bit of light sanding between coats and added another coat.
Check it the next day and a lot of section on the bow the veneer had lifted !!!
The stern section is OK.
It's the outer veneer and it's all one piece, used the same glue.
Very disappointed!!!!
Canabus
canabus
« Reply #35 on: August 26, 2017, 12:15:13 pm »
Hi Chaps
Totally stripped the deck planking off and started again.
Fingers and toes crossed with different wood glue this time.
« Reply #36 on: August 26, 2017, 05:39:49 pm »
Likewise, fingers crossed for you. What glue did you use first and what is the varnish? spirit or water based??
canabus
« Reply #37 on: September 02, 2017, 10:42:22 am »
Hi All
Finished planking and added the first coat of vanish.
Canabus
C-3PO
« Reply #39 on: September 02, 2017, 02:45:50 pm »
That's going to be one slick boat when all the varnishing is done  :-)) The lady in the cockpit seems impressed  :-)
canabus
« Reply #40 on: September 05, 2017, 09:55:04 am »
Hi All
Finish vanishing the deck and starting on the right Royal Pipa Blue Bottom !!!
Canabus
« Reply #41 on: September 06, 2017, 09:49:50 am »
Not bad. I like the variety of shades found in the planks and their symetry.
Nice  :-))
canabus
« Reply #42 on: September 07, 2017, 10:12:46 am »
Hi All
Finished painting the bottom of the boat.
Canabus
canabus
« Reply #43 on: September 09, 2017, 10:12:24 am »
Hi Chaps
Painted the sides and started planking the dash, also installed the shaft oiler.
Canabus
canabus
« Reply #44 on: September 11, 2017, 10:31:55 am »
Hi All
Finally finished the dash planking.
Add the T shifter for the oiler!!!
Canabus
« Reply #45 on: September 12, 2017, 08:48:25 pm »
I salute all methods of hiding the funtional or disguising it  :-)) That is a cool idea.
canabus
« Reply #46 on: September 13, 2017, 11:47:23 am »
Hi Chaps
Well out with the polish and clean up the boat.
All system installed and working.
A bit offset on the rudder and setup the ESC to my standard boat settings.
Only using the 3S 3700mah Lipo battery and a total suggest at the CG point.
The crew are a bit heavy at 100 grams each!!!
Weather is looking good, so it's gentleman start your engine !!!
Canabus
canabus
« Reply #47 on: September 17, 2017, 11:47:47 am »
Hi All
The had it's first run today with great success, the CG was 410mm from the bow and it sat in the water on the waterline.
A slow start with a quick check of the forward/ reverse and rudder controls.
As you all will see from the pics what a boat without spray rails is like!!!
Up on the plane at 1/3 throttle and turning nice on the rudder.
I got the offset spot on for once.
Stayed in the 1/3 to 1/2 throttle for the camera shots and then hit it up to full throttle.
Sat on the water beautifully, but, the turns had to be slower mainly because of no spray rails.
I am very happy with the performance, but, still have a few bits to add to finish to boat.
Canabus
canabus
« Reply #48 on: September 17, 2017, 11:54:37 am »
Hi All
A few more pics.
Canabus
canabus
« Reply #49 on: September 17, 2017, 11:55:33 am »
Hi All
More pics!!!
Pages: 1 [2] 3   Go Up
