Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25   Go Down
Author Topic: Building the FV "Mady Jeanne"  (Read 156056 times)
missyd
Re: Building the FV "Mady Jeanne"
« Reply #525 on: April 20, 2020, 06:55:51 pm »
Hi Danielle whats is the diameter of your rudder post?  Maybe someone on the forum could send you some if they have some brass rod spare.  Then I guess you could cut a slot in it and fit it over the rudder.  Just a suggestion to maybe get you through this time of scarce material.
Thanks a lot for you offer Mark. Its a treaded rod M4...I used it on all my models and its ok....
Danielle
missyd
« Reply #526 on: April 20, 2020, 07:05:25 pm »
Now my friends ... the rudder is finished. I have just to clean the parts before I paint them.
Pic1...Rudder soldiered and ready for the next step.
Pic2...The parts I need to make the attachement to the rudder axle
Pic3...I even used a very old mini anvil...
Pic4...Now that is looking fine for me...the 1st set took me 2h to finish (not so nicely) only to loose one part and so I redid everything in 1h much nicer work....
Pic5---6....ready for action!!
Pic7...the M2.5 hex screws are essential...at the moment they are rather loose so I can take it apart again...
Danielle
Taranis
  • Balne Moor MBC
« Reply #527 on: April 20, 2020, 08:23:42 pm »
I love your work, most splendid scale  :-)
ANDY
missyd
« Reply #528 on: April 21, 2020, 05:58:04 pm »
Thanks a lot Andy!!!! :-))
Mark...I did find 4mm round brass profile in my new storage tubes....it was a little bit hidden but I managed to make the rudder post perfectly with it. O0
Now the rudder is 100% finished! It was one of the best things I did as model ship builder.
Pic1...2: Shows how small these 2.5mm hex scres and nuts are...spanner is a 3.5. It was important for me to do it this way.
Pic3: First fitting of the rudder....This is with the treaded M4 rod....wasn't happy with it.
Pic4: End version of the rudder. The rudder post is screwed into the upper flange and secured with M4 nut.
Danielle
Mark T
« Reply #529 on: April 21, 2020, 07:35:32 pm »
Very nice and very tidy miniature engineering  :-))   This ship is going to be amazing!
missyd
« Reply #530 on: April 22, 2020, 06:00:08 pm »
Thanks a lot Mark!!! :-)) ;)
Today I started to make the keel protection .... all trawlers from brittany have some sort of protection because some of them stay on sand/mud when the tide is low.I have to make it by stacking 4x0.5mm tinplate together and will then solder it together.
Pic 1-3: Mark and cut the tinplate with my special tool.
Pic 4: I used a L-shaped aluprofile to get the pieces together.
Pic 5: Ready to get soldiered. Everything is held together with M3 screws. The holes will be used to fix the part on the keel. Its heavy!
Danielle
missyd
« Reply #531 on: April 26, 2020, 04:01:25 pm »
Disaster!!! <:( Impossible to soldier it nicely together....I ordered some 15x4mm brass profiles that should delivered this week....In the meantime I work on my Les Paul style guitar kit I bought some time ago...
Danielle
missyd
« Reply #532 on: April 29, 2020, 05:36:27 pm »
Got the brass profiles today! Very fast delivery indeed...  :}
Pic 1 shows the first profile bent to fit the keel.
Pic 2 without the right tools you can't bend the profile at all. Luckily I got this pair of bending devices from my apprenticeship. Useful they are.
Pic 3 Gas torch and normal solder for electronics with flux. Heat the profile and if the temperature is alright you may solder severl cms in one go.
Pic 4 its massive and heavy. Will add some weight very low. Any weight is welcome with a model this big.
Pic 5 Cleaned ... looks ok. At the tip it will fit the keel much better in the end.
Danielle
Mark T
« Reply #533 on: April 29, 2020, 05:51:03 pm »
Thats a nice fit for such thick metal top job  :-))   How are you going to secure it to the bow - screws?
missyd
« Reply #534 on: April 29, 2020, 05:52:43 pm »
Mark, I will use a lot of screws. Did the same with the N. Loredana in a much smaller scale. I drilled the holes already.
Danielle
Mark T
« Reply #535 on: April 29, 2020, 06:01:11 pm »
Yea thats the same as I did - I also sat the metal on a bed of epoxy resin just in case any water got between the keel and the metal.
missyd
« Reply #536 on: April 29, 2020, 07:04:50 pm »
Ok! I normally use a lot of wet paint between the brass and wood. I never use Epoxy on my boats.
Danielle
missyd
« Reply #537 on: May 01, 2020, 05:19:41 pm »
Work is done....went well and I am happy with the result.
Pic 1: I used these useful little clamps to hold the brass profiles together during soldiering.
Pic 2: 1.120kg is the weight. I hoped for some more... {-)
Pic 3: I also redid the lower bearing for the rudder...
Pic 4&5: Before fixing it permanently to the keel.
Pic 6: I used really thick acrylic paint on the keel to get things watertight.
Pic 7&8: The paint that is coming out under the brass profile is used as paint on the hull
Pic 9: Black matte acrylic paint is used over the new part.
I must say that the additional protecting keel is making the hull much better. The wooden keel was not the right shape. So in the end it cost me a few hours work and some hard earned swiss francs to get it done.
Danielle
missyd
« Reply #538 on: May 02, 2020, 03:14:50 pm »
Saturday....I did some painting. And I got some round 4mm brass profile from the reopened DIY superstore. No I wont visit it again as long as this silly Coronavirus pandemia joe is around.
OK I did some sanding and put on some matte black.
Danielle
« Reply #539 on: May 02, 2020, 10:41:04 pm »
Hi Danielle. You are doing some brilliant model engineering there. I always like to see some quality metalwork.
I am pleased for you at getting to the point where you can pop some paint on. I always feel it is a signpost that you are getting somewhere with a project.
missyd
« Reply #540 on: May 03, 2020, 06:03:43 am »
You're right...I was at a point where I did not go ahead with this model. But I found a way to restart everything...but I do other projects in between. I built a kitchen cupboard and actually I do the finishing on a guitar kit.
Danielle
missyd
« Reply #541 on: May 04, 2020, 05:18:47 pm »
Today is dual work day....painting the Marie-Jeanne's hull matte black and varnishing my Les Paul guitar kit....Careful with the black paint...you have to keep your hand clean!  ok2
Danielle
missyd
« Reply #542 on: May 06, 2021, 04:49:38 pm »
One year later with a better equipped workshop I restarted building this model.
Pic 1: shows how small the motor is. The propshaft and prop are ready. The boxes are: Big box for 2x Battery. 3 smaller ones are to hold the lead (20-30kg)
Pic 2: Preparing the hull for the deck.
Danielle
SailorGreg
« Reply #543 on: May 06, 2021, 05:42:06 pm »
Welcome back Danielle!  Lovely to see Mady Jeanne progressing again.  I can't get over how small that motor is - it looks too small to drive a boat of this size and weight, but I'm sure she will be perfect when she hits the water.
Greg
Mark T
« Reply #544 on: May 06, 2021, 06:46:09 pm »
I was only thinking about your build the other day wondering how you were getting on.  Welcome back  :-))
Taranis
  • Balne Moor MBC
« Reply #545 on: May 06, 2021, 07:50:30 pm »
Great that you’re back 🎉 👌
ANDY
missyd
« Reply #546 on: May 07, 2021, 06:23:10 pm »
Thanks to you all!!!! Its really nice to be back at work on my trawler.
The Motor ist really small...well see. I used the same one for the N.Loredana.
More work done on the rudder and ruddershaft.
Pic 1: Rudder and prop arangement. Maybe I should change the 80mm diameter prop for a 10cm one....
Pic 2: I may use a chain (like my other boats have) but I am not shure about it. I'll go to the nearest model shop tomorrow to get a stronger servo. The one I have is too small. And some servo attachments too.
Danielle
« Reply #547 on: May 07, 2021, 06:34:11 pm »
We have all missed you, (and the build) great to have you back, still loving your work......your Dremel is bigger than your motor..... :-)) :-)) :-)) ....I think you need a bigger motor...to late late for a smaller boat  {-) {-)
Taranis
  • Balne Moor MBC
« Reply #548 on: May 07, 2021, 06:42:00 pm »
I must admit I am quite startled by the small size of the motor but I'm not criticising this. However with any motor my own choice is to ensure 100% straight alignment. I have a severe dislike of universal couplings  %)
I love the build  :-)
EDIT if you think a bigger prop looks better go for it  O0
ANDY
« Reply #549 on: May 08, 2021, 02:51:43 pm »
Hooray you're back! I recall you using a reasonable sized motor in a Hoooooge hull  :}  So, what did you do to improve your workshop Danielle? Is it all 'Singing and dancing' as we say in Blighty?
Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25   Go Up
Page created in 0.109 seconds with 21 queries.
