Author Topic: Hitec 4  (Read 3347 times)
Gardener
Hitec 4
« on: August 05, 2017, 03:26:32 pm »
can you convert a hitec 4 controller with left stick that does not spring back to neutral position for boat operation ?
Re: Hitec 4
« Reply #1 on: August 06, 2017, 11:44:46 am »
I should imagine there is a little spring in there somewhere that can un-hooked
ken
unbuiltnautilus
Re: Hitec 4
« Reply #2 on: August 06, 2017, 01:17:22 pm »
You can open the set up, find the ratchet part of the stick and give you a more positive mid position with a small triangle profile file. Tippex the side of the ratchet, set the stick in its mid position, mark where the metal part contacts the plastic ratchet and mark it with a pencil. Then file a bigger 'tooth' into the ratchet. This will not remove the ratchet effect, but it will give you a positive neutral feel when using the LH stick. It works, done it many times.
Gardener
Re: Hitec 4
« Reply #3 on: August 06, 2017, 02:53:14 pm »
Thanks for you help
ChrisF
  • What's my favourite cake!
Re: Hitec 4
« Reply #4 on: September 08, 2017, 05:52:46 pm »
I bought a Hitec to replace the Acoms 27Mz and wanted to do the same thing but having used it with my yacht I found it fine. I was of course using it to control the sails rather than the motor.
My neighbour is happy using the stick without a spring for his aircraft and boats.
Is there a right and wrong for this? I assume it's better to have a spring return for boats as many have reverse and you want a distinctive throttle off position at the mid-point?
I'm getting another Hitec, the Flash 8 purely for powered boat use and am leaning towards having the spring return on the left stick.
Chris
Re: Hitec 4
« Reply #5 on: September 08, 2017, 06:20:14 pm »
For sail control ratchet is best
as you can take your thumb off
and the sails will be held by the winch.
With power it may be better to have a
centre neutral so taking thumb off when
you talk to your mate stops the boat.
Re: Hitec 4
« Reply #6 on: September 09, 2017, 09:49:50 am »
Also, some ESCs seem to be quite picky about the signal they get when they power up, insisting on a "proper" neutral.  The sprung stick helps ensure this.
Removing a spring to go to non-centered is easy, to go the other way, less so.  It might need a kit, I don't know if one is offered for Hitec.
bj
Re: Hitec 4
« Reply #7 on: September 09, 2017, 01:53:02 pm »
If it is built the same as their Optic range then it is INBUILT and only needs the back of the Tx removing and a screw turned to engage the feature. Check your instruction manual
ChrisF
Re: Hitec 4
« Reply #8 on: September 09, 2017, 04:00:59 pm »
Thanks for the replies chaps, confirms my thoughts that the spring return is the way to go.
Chris
