Author Topic: Birth of a new Stuart D10  (Read 6278 times)
rhavrane
  • Steam passionate collector
« on: August 18, 2017, 08:53:30 pm »
Bonjour,
There is no two Stuart D10 identical.
Max, an outstanding modelmaker, is finishing a magnificent Stuart D10 equipped with a mechanical coupled water pump. Admire the details of his manufacture.
Since the original crankshaft was not originally drilled, Max made a coupling for the pump shaft and made two bearings instead of one to support it.
Here are its first test (it will be painted with the original green an black Stuart colors, every screw will be tightened and the side valves have to be accuratly adjusted) : https://youtu.be/CtoQT9tvom4
Raphaël
Starspider
Re: Birth of a new Stuart D10
« Reply #1 on: August 18, 2017, 11:23:43 pm »
Very nice  :-))
steam up
« Reply #2 on: August 19, 2017, 04:59:58 pm »
Good looking engine seems the timing is a little off (problems in self starting) sure it will be sorted  :-))
rhavrane
« Reply #3 on: August 20, 2017, 08:31:43 am »
Bonjour,
Yes, Maw has to review the timing after mounting the pump and I was surprised to see how a degree of shift of the eccentrics could affect the operation of the machine. I thought that 120 ° between the two was mathematically correct, the reality shows the opposite ...
I also understand why it is impossible to make the two excitations in a single block of metal, independently of machining difficulties.
Raphaël
« Reply #4 on: August 22, 2017, 08:22:08 pm »
A very nice piece of work  :-))
rhavrane
« Reply #5 on: September 17, 2017, 09:26:51 pm »
Bonjour,
To avoid any vibration or friction which would disturb the operation, my friend Max has replaced the initial coupling by a TOC for the water feed pump :https://youtu.be/C5ATzAKX_Ww
Next step, accurate tuning (quite difficult to obtain on both sides) and steam test  :-))
Raphaël
rhavrane
« Reply #6 on: November 04, 2017, 08:09:28 pm »
Bonjour,
Max, the friend who had the extreme kindness to make me this machine Stuart made it very tight and, after half an hour it is already untied.
At 30 psi it roars and turns like a clock to 15 or even 8 psi. Some details are still to be fixed before the boat can go on the water, but it is well born as you can see it : https://youtu.be/kFyBAtKFvXY
Raphaël
KNO3
« Reply #7 on: November 04, 2017, 09:08:42 pm »
Seems to work very well. Can you post some pictures of the boat here?
rhavrane
« Reply #8 on: November 05, 2017, 08:11:49 am »
Bonjour Calin,
I am more familiar with videos than photos, but I will do several ones this afternoon for you, thank you for your interest  ok2
Raphaël
rhavrane
« Reply #9 on: November 05, 2017, 09:15:07 pm »
Bonjour,
As suggested, photos of the tugboat : https://photos.google.com/share/AF1QipPkf0pyGba5SLzlAPyBaE4a38fnjF35MM6BigHtGh0OnkWXx8IGct1MbrBWEO3Odg?key=WU91QS1haTNNNXVFRGN2MFY3X2FPTVF0RUtwQUJB
I have yet to install a new gas regulator (the one offered leaks, not cool when it is gas  :(( )and modify the rudder cable command befor the endurance test... in the bathroom ok2
Raphaël
KNO3
« Reply #10 on: November 06, 2017, 08:38:20 pm »
Thank you for the pictures! Is the water overflow on the left side of the hull above or below water level?
« Reply #11 on: November 06, 2017, 09:13:40 pm »
You have good eyes Calin  O0....I see the white fitting on the outside of the hull, but cannot see it being connected internally
There does appear  :o to be a short length of clear plastic tubing [with a bend] in the vicinity...however not sure what it is or where it goes
rhavrane
« Reply #12 on: November 06, 2017, 09:46:03 pm »
Bonjour Calin and Derek,
Both of you are right, the output of the by pass is supposed to be just over the waterline, but I have not tested yet the boat in the water, so it will be a surprise. Never mind, the important point is that the input is under the waterline to push the water in the pump and avoid anu defusing :
Raphaël
« Reply #13 on: November 06, 2017, 10:21:44 pm »
OK thanks Raphael..... I now see in the video  :embarrassed:......the bypass valve at the pump body and clear tubing to the discharge valve
The one thing that is not clear, is that a pump suction lower down in the hull directly below the discharge?...if so, the owner must be fortunate to run in clean water good enough for the boiler feed [although I also see a small disc filter in the suction line] but this is only for house bricks  >>:-(
rhavrane
« Reply #14 on: November 12, 2017, 08:47:56 pm »
Bonjour,
The water line is the white one on the hull, I have added 3 kilos of lead to avoid a capsize. The Stuart D10 is definetly a powerful steam machine even at 2 bars (30 psi) and the pump is a plus for the autonomy of a 20 kilos boat  :-))
https://www.youtube.com/watch?v=JdRwDXVLJIA
Raphaël
KNO3
« Reply #15 on: November 13, 2017, 07:23:49 pm »
Works nice! I would place the bypass water exhaust above the water line, because it would look very nice to see it letting water out, like on many real ships where you have a cooling water exhaust at the side.
ooyah/2
« Reply #16 on: November 13, 2017, 08:41:55 pm »
Raphael.
If you discharge the bypass water below the waterline how will you know if the pump is working.
George.
rhavrane
« Reply #17 on: November 14, 2017, 08:02:51 am »
Bonjour,
I fully agree with you, we should have installed the bypass water exhaust above the water line for practical reason and nice looking.
Besides this, I let the water go through the by pass only to prime the pump, after, its flow just covers the steam consumption, so the bypass valve is closed.
I have checked its work by tilting the boat, and the RPM of the machine decreased just a little when the water was oriented to the boiler.
This is not a majour issue, I can change it.
Thank you for your interest.
Raphaël
rhavrane
« Reply #18 on: November 26, 2017, 07:13:21 pm »
Bonjour,
I take the benefit of this topic to share wwith you the D10 and its enhancements made by my friend Emmanuel :
https://www.youtube.com/watch?v=Ro9QCgCKui0
Raphaël
rhavrane
« Reply #19 on: December 02, 2017, 07:55:10 pm »
Bonjour,
Another beautiful D10 enhanced by my friend Max for Didier : https://youtu.be/LKPQcWBBwho
Raphaël
rhavrane
« Reply #20 on: December 26, 2017, 08:53:54 pm »
Bonjour,
I have solved my water leaks problems and, at the end of the video, you can hear the effort made by the machine at low speed to run its pump : https://youtu.be/OtLh60pTfaQ
Next step, put the plant back in the tug, add 5 kilos of leap (the boat is 1,30m long, 0,25 m wide and will weigh 20 kilos, the steam plant by itself weighs 6,5 kilos without water and gas) at appropriate locations and test iton the pond when the weather is more lenient :-))
Raphaël
rhavrane
« Reply #21 on: February 18, 2018, 08:12:55 pm »
Bonjour,
https://www.youtube.com/watch?v=dzlse2W3xHo
This first navigation allows me to validate the quality of the machine Stuart D10 made by my friend Max and to discover the improvements that I must carry to this steamship. Alas, two successive incidents will very quickly interrupt my tests.
The measured autonomy is still 1 h 30 min limited by the gas.
Raphaël
