Author Topic: Wagos  (Read 1249 times)
mudway
  • Model Boat Mayhem is Great
Wagos
« on: August 25, 2017, 10:23:36 am »
I’m not sure if this is the correct place to post but here goes.
I’ve noticed people recommending the use of wago connectors instead of the old connector blocks. These are something I have not heard of and are confusing me. This is easily done these days.
In the old blocks, you could put two wires in one side and one out or vice versa depending what you want to do.
Nothing I can find tells me how to do this with the Wagos.
If a two hole one then logically, two separate wires can be connected this way as with the connector block except you end up with two wires parallel to each other rather than one “continuous” wire the old way.
What about three and five hole ones though. For the three hole ones, if you want one power wire in and two out or two in and one out, which holes do you use?
Similarly the five hole ones, which holes are power in and which power out?
TailUK
Re: Wagos
« Reply #1 on: August 25, 2017, 10:32:41 am »
From what I can tell all the holes in the block are connected so power in can be any of them.  I've just ordered a pack of 10 x 5 way blocks and look forward to trying them.
Incidentally, Ordering them from your local Screwfix works out cheaper than fleabay.  A 50 pack of 3 ways is  £15.13 inc VAT that's about 30p each and you don't have to send to Hong Kong for them.
T33cno
Re: Wagos
« Reply #2 on: August 25, 2017, 04:52:04 pm »
Bob K
  • Bob K
Re: Wagos
« Reply #3 on: August 25, 2017, 04:55:51 pm »
Sorry, I thought this thread was about Wives And Girlfriends?     {-)
TailUK
Re: Wagos
« Reply #4 on: August 25, 2017, 06:06:28 pm »
May they never meet!
Page created in 0.084 seconds with 22 queries.
