Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18   Go Down
Author Topic: Another Huntsman rebuild  (Read 94257 times)
Re: Another Huntsman rebuild
« Reply #275 on: June 20, 2021, 10:44:57 pm »
Finally for now, here's a photo of the sponges used to apply the varnish. I bought these a while ago and find they are good for about 3 coats, provided the heads are cleared of the varnish as much as possible - I just squeeze them with a few sheets of kitchen roll.
When they are passed their usefulness, the heads are removed and the remainder used as stirrers. :-))
T888
« Reply #276 on: June 21, 2021, 08:50:41 pm »
Ray,
Nice job of bending the wood around the stern :-))
Regards David
« Reply #277 on: June 21, 2021, 09:07:05 pm »
Cheers David, yeah, that bit was relatively easy - I had more bother with the sides actually  :o
Joe suggested the size of mahogany to use and, as he said, it does bend nicely  :-))
radiojoe
« Reply #278 on: June 22, 2021, 09:35:24 am »
That's the deck edge finished very nicely Ray,  :-))
Joe
« Reply #279 on: June 22, 2021, 09:52:30 am »
Thanks Joe, your suggestion was spot on!
Managed to get another coat of varnish on last night and that should be fine now.  :-))
« Reply #280 on: July 17, 2021, 09:37:25 pm »
Just another little update...
To compliment the above, here's a couple of shots of the boat in daylight rather than under fluorescent light...
« Reply #281 on: July 17, 2021, 09:41:27 pm »
Next, the drivers seat has been installed complete with 'feet'
...and I managed to get some resin casting done - this is what I used as a master for the grab rail supports...
« Reply #282 on: July 17, 2021, 09:49:31 pm »
I had made these eight pieces individually but, as I needed a total of 32, I decided to group them together and use them to cast 8 at a time.
Also, I have been gifted fairleads, cruciform bollard and anvil bollards, along with the Force 4 vents.
These were kindly donated by one of our forum members...and these have now received the 1st coat of paint.
Here's a few more pics....
« Reply #283 on: July 17, 2021, 09:52:59 pm »
The sloping supports are for the grab rail ends and the sort of triangle shape, with top chopped off, are the intermediate supports.
These have all now been sanded down and set up ready for painting, which I hope to complete tomorrow. %)
radiojoe
« Reply #284 on: July 18, 2021, 12:43:03 pm »
All looking rather good Ray, she looks clean and bright out in the sunlight a far cry from what you started with, well done mate.
Joe :-))
« Reply #285 on: July 18, 2021, 12:59:15 pm »
Many thanks Joe and you've helped me along the way - hoping to start on the windscreen soon  :-))
T888
« Reply #286 on: July 18, 2021, 01:51:01 pm »
Well Ray, the castings came out well, all adds to the that feeling, I made this and it looks good :}
Regards David
« Reply #287 on: July 18, 2021, 02:05:41 pm »
Thanks Dave and you're spot on there - so satisfying when they turn out good  O0 .
All being well I should get final coats on this evening and see if I have something suitable for the rails  :-))
« Reply #288 on: September 26, 2021, 09:40:27 pm »
Absolutely nothing done since last update in mid-July. Just brought it out tonight and given her a dust off.
Hope to be back on the boat this coming week.
« Reply #289 on: October 03, 2021, 05:25:09 pm »
Spent the last few evenings trying to make a suitable template for the boat windscreen. Meanwhile, getting some fittings ready to install and generally getting the boatshed into some semblance of order.
As can be seen in the photos I've managed to come up with a template for the windscreen (last photo) and just need to source suitable material - probably take a few attempts to get one made for installation.
Also, the photo showing plastic strip being coaxed around the saloon top wood was done in stages, using a hair dryer to help form the shape.
radiojoe
« Reply #290 on: October 03, 2021, 09:09:22 pm »
Hi Ray   yeah quite tricky the windscreen I used the small mast to brace the center of the screen, in case you are still looking for some clear plastic www.slecuk.com stock sheets large enough to do the screen in one piece,  500 x 660mm and  660 x 1000,  0.5mm thick, If it helps.
Joe.
« Reply #291 on: October 03, 2021, 09:14:51 pm »
Ah brilliant, thanks for that Joe, I'll order a couple of sheets tomorrow.  :-))
T888
« Reply #292 on: October 04, 2021, 11:56:45 am »
Nice to see you back on this build Capt :-)) :-))
Regards David
« Reply #293 on: October 04, 2021, 07:00:46 pm »
Cheers Dave - yeah, it's a good feeling and now I've finally finished doing jobs for family, friends and neighbours I can get on with my own outstanding tasks  :-))
T888
« Reply #294 on: October 04, 2021, 07:10:22 pm »
Capt, you will enjoy getting back to your outstanding tasks (model boating?)  :-)) :-))
Regards David
« Reply #295 on: October 04, 2021, 08:47:37 pm »
Definitely!  :-))  O0 O0 O0
madwelshman
  • Learning all the time.
  • Fairey Marine Fanatic
« Reply #296 on: October 05, 2021, 11:33:31 am »
I appreciate I'm a bit late with this, but I'm not sure, but i may have a plan template for the screen on a Precedent H31.
Assumjng im right and that i can find it, I don't know for sure which scale it is though.
If you'd like me to have a look for it, let me know.
Will
49" Precedent Perkasa
46" Aerokits Sea Queen
42" Veron Fairey Huntsman 28 x2
34" Lesro Sportsman mk1
34" Precedent Fairey Huntsman 31 x3
34" Aerokits Sea Commander x2
29" Aerokits Sea Rover
20" Aerokits Fast Patrol Boat
16" Aerokits Sea Urchin
« Reply #297 on: October 05, 2021, 12:35:22 pm »
Hi Will, if you can find it, it could be useful to me, although I think my model dimensions are likely to be a bit different to the standard due to the way I've built the topsides.
No problem if you can't find the template and thanks for your offer  :-)
madwelshman
« Reply #298 on: October 05, 2021, 01:14:51 pm »
No problem Ray, I will have a look tonight and see if I can find it. If I can, I'll pm you for your email address.
Will
Mark T
« Reply #299 on: October 05, 2021, 06:47:26 pm »
Great to see you back on it Ray  :-))
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18   Go Up
