Author Topic: old servos  (Read 8184 times)
john44
old servos
« on: November 01, 2017, 09:19:38 pm »
hi guys, I have some old servos Wired red, black,black. Which wire is the signal wire the middle
Or outer black so I can swap them over and use the servos.
RMH
Re: old servos
« Reply #1 on: November 01, 2017, 10:07:34 pm »
Hi John
The diagram at the bottom of this page might help you decide which wire is which
http://www.hooked-on-rc-airplanes.com/rc-servos.html
Richie
john44
Re: old servos
« Reply #2 on: November 01, 2017, 10:51:06 pm »
Thanks Ritchie, but one servo is a hitec hs-300 which is red black,black,the other are Sanwa
Thanks anyway.
unbuiltnautilus
Re: old servos
« Reply #3 on: November 01, 2017, 11:40:18 pm »
As a rule the red and black are always paired together, so the other black is white!!
Or translated into some form of english, the pos and neg are usually paired together ( except maybe on Fleet gear..a law unto themselves!!), meaning whatever you are left with is the signal wire. The above description does smack of Sanwa mid to late eighties, not Hitec. However, the servo may have been rewired, in which case all bets are off and good luck to you sir :-)
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: old servo,s
« Reply #4 on: November 02, 2017, 07:05:33 am »
Why bother? Servos are so cheap that it's easier to treat yourself to something new and properly compatible.
Re: old servos
« Reply #5 on: November 02, 2017, 08:42:40 am »
Sanwa went their own way for many years and only fell into line around the turn of the century.
It is quite possible that anybody using mostly Sanwa gear would rewire a "foreign" servo to match.  To be sure involves looking at the insides and seeing where the wires go.  Usually the power wires have a short connection to an electrolytic capacitor which is marked "+" and "-", the other being the signal.  With flat cable, a cross-over can be easily spotted, twisted wire, less easy.
But as said earlier, new ones are so cheap today.
john44
Re: old servos
« Reply #6 on: November 02, 2017, 08:28:04 pm »
Hi plastic, treating myself to new kit is not a problem, it's just as I am a curious person and would
Like to know for my own satisfaction.
Klunk
Re: old servos
« Reply #7 on: November 02, 2017, 11:00:06 pm »
john go see George he has plenty of servos in all the boats he doesnt use! Ps hope to be up in the new year sometime so bacon rolls  on me!
full time penguin
john44
Re: old servos
« Reply #8 on: November 03, 2017, 10:04:41 am »
That's very true klunk, look forward to meeting you again.
john44
Re: old servos
« Reply #9 on: November 03, 2017, 05:11:42 pm »
Hi klunk, I asked George he said his boats are all in working order you would have a lot of servos
Because you don't sail your boats you just collect them  {-) {-)
Klunk
Re: old servos
« Reply #10 on: November 03, 2017, 05:21:17 pm »
Cheeky person! I sailed a boat this year!
full time penguin
Brian60
Re: old servos
« Reply #11 on: November 04, 2017, 04:11:29 pm »
These charts may help.................
edit: Airtronics is Sanwa :-))
Klunk
Re: old servos
« Reply #12 on: November 04, 2017, 04:19:41 pm »
now that is a very handy reference chart!!!!!!
full time penguin
RAAArtyGunner
Re: old servos
« Reply #13 on: November 05, 2017, 02:35:51 am »
Brian,
Yes indeed,  :-)) :-)) ,
Martin, could it be filed for future reference???
john44
Re: old servos
« Reply #14 on: November 05, 2017, 04:55:24 pm »
Thanks for the chart Brian, that will help everyone on the forum I should think.
Re: old servos
« Reply #15 on: November 05, 2017, 08:50:44 pm »
RAAArty.....agreed good reference & all in one shop..... :-))
I am pretty sure you are still on Win7'..
Just right click the file name......choose Add to favourites... & hey presto
Do the same for the other three file names  & you have them grouped & saved together in your favourites by name O0
RAAArtyGunner
Re: old servos
« Reply #16 on: November 06, 2017, 05:00:06 am »
Derek,
Yes you are right, you've got a memory like an elephant O0 {-) , am still on WIN7.
Thanks for the tip :-)) :-)) :-)) .
Worked great, amazing  :-)) :-))
Never toooo old to learn
Brian60
Re: old servos
« Reply #17 on: November 08, 2017, 03:36:43 pm »
Thanks guys, but by far the simplest way to file them is right click on each picture and then click save as. It will then download each picture to your computer, I've got loads of stuff like this in a folder called 'useful boat info' :embarrassed: :embarrassed:
RAAArtyGunner
Re: old servos
« Reply #18 on: November 08, 2017, 11:22:06 pm »
Thank you,
Tried that and it is easier. :-)) :-)) :-))
At least that way I might remember where it is.
Page created in 0.015 seconds with 20 queries.
