Author Topic: Linear servo - where to buy?  (Read 2482 times)
C-3PO
« on: December 23, 2017, 01:24:24 pm »
Linear servo - I had a quick Google and didn't get any positive results
Are they still made? Can you still but them?
Thanks in advance
C-3PO
bfgstew
  • Comfortably Numb
Re: Linear servo - where to buy?
« Reply #1 on: December 23, 2017, 01:31:06 pm »
Subculture
    • Dive-in to Model submarines
« Reply #2 on: December 23, 2017, 01:35:10 pm »
You can get very small linear servos. They're low torque and designed for very light aeroplanes. e.g.
https://hobbyking.com/en_us/hobbyking-ultra-micro-servo-1-7g-for-3d-flight-left.html
If you want a standard size linear servo, the cheapest and easiest solution is the EMS kit, which adapts certain Futaba servos to a very nice linear servo.
http://www.emsjomar.com/linear.aspx
Becker in Germany did sell linear servos in various sizes, not sure on current availability.
Other than that, it's a case of searching on ebay for old Linear servos from the seventies by the likes of Futaba, Skyleader etc. Or DIY.
Brian60
« Reply #3 on: December 23, 2017, 04:24:54 pm »
I have a couple of the hobbyking type and to be honest, unless you are building a quadcopter for inside use they are too small and too feeble to move anything but the lightest load - I attached a sheet of A4 paper to one and it struggled to lift it when free hanging. They do larger types though, or they did for outside aero use.
« Reply #4 on: December 23, 2017, 04:39:42 pm »
please excuse my ignorance guys, but what are they and what do they do.
Brian60
« Reply #5 on: December 23, 2017, 04:45:05 pm »
A standard servo makes a rotary movement.
A linear servo converts the rotary movement into a back and forth movement similar to pulling open/closed a drawer, it does this by using a worm drive and toothed track.
C-3PO
« Reply #6 on: December 23, 2017, 04:56:20 pm »
Linear servo - sort of like this
The ones I used many moons ago had 2 attachment points that traveled in opposite directions to each other
C-3PO
C-3PO
« Reply #7 on: December 23, 2017, 05:53:59 pm »
Possibly a neat 3D printed solution - thanks Tim Garrod
https://hackaday.com/2016/03/31/3d-printed-case-turns-servo-into-quality-linear-actuator/
C-3PO
timgarrod
    • Alvaston Pirates Model Boat Club
« Reply #8 on: December 23, 2017, 06:17:45 pm »
No Problem C3po, Will print one off next week a give it a go. not a neat as the adaptor that go on top of the servo but a option .
The Old Fart
  • Great Yarmouth Model Boat Club
« Reply #9 on: December 23, 2017, 07:25:14 pm »
C-3PO
« Reply #10 on: December 23, 2017, 07:56:27 pm »
Hi Dave,
I guess an enhanced version of Tim's initial suggestion - I will consult Tim (shapeways) Garrod to see what his rates are as I don't have a 3D printer and my piggy bank currently is ear marked for a sub...
C-3PO
« Reply #11 on: December 23, 2017, 09:27:26 pm »
C-3PO
« Reply #12 on: December 24, 2017, 11:05:57 am »
Hi Derek,
Thanks for that suggestion - I am familiar with the "linear actuator" they are widely availbale in the UK - I discounted these as I didn't want to sell a body part to facilitate purchase.
I can only assume it's the limited production/ more involved engineering (gear box) that determines such a high price of these actuators - some of them are eye wateringly expensive 60+
I think Tim/Dave's suggestion have merit at an affordable cost... - I also think this "travelling nut" could work well and is simple to hook up to
C-3PO
The Old Fart
« Reply #13 on: December 24, 2017, 12:21:34 pm »
Are yes, these are used for the Z axis on my 3d printers.
Brian60
« Reply #14 on: December 24, 2017, 01:59:10 pm »
Does it have to be a servo Threepio? What about these linear stepper drives, I have two of these in my ship at the moment, just needs a bit of arduino code ok2
AliExpress or Banggood is your friend for them.
steamboatmodel
« Reply #15 on: December 24, 2017, 03:59:57 pm »
If you have any old cd/dvd drives you may find some of those small steppers with the traveling mechanism in them.
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
