Thanks Brian
KNO3 - if you met my captain you would see that he's as hard as nails and would see upholstery just something else to clean
The reason that the instruments are on the floor is because he's got a hump back and can only look downwards - only joking mate I just put them there to see how things would fit; they actually are located on the wheel house wall just under the windows.
Here's a couple of pictures of the furniture now fully glued in place just waiting for the wheel house to be lowered onto the deck
Ok now onto the wheel house roof. I thought that I had the timber to make this but I didn't
So first job was to cut 21 planks 6mm x 2mm to do the job. I'm running out of mahogany now so I need to get this boat finished!!
Then measured and placed the first plank as everything else follows this one
Next I placed and glued the rest of the roof. I didn't bevel these planks as the camber is so slight but I guess you could if you wanted too
Then sanded it to shape
Next I hit a problem - The roof has a drip trim that runs around its edge and no matter how I tried I could not get the tight bend at the front of the roof. The mahogany snapped every time I tried so I gave up. Instead I decided that the only way to do this was to make the corners from solid. So I did
I cut the corners out and then glued them onto the corners
Lastly I put the rest of the edge around and sanded it to a finished shape. I'm dead chuffed with this little detail and think it was well worth the effort
Next jobs are fitting the doors on the lower structure and the tarpaulin support on the wheel house. I'll try and get some more up tommorow
Mark
