Pages: 1 2 [3] 4   Go Down
Author Topic: Commandant l'Herminier-French light corvette class-1/100  (Read 18802 times)
Akira
Re: Commandant l'Herminier-French light corvette class-1/100
« Reply #50 on: January 17, 2019, 09:15:09 pm »
Scary! Beautiful work. Your brass work makes my hands shake.Jonathan
raflaunches
  • The Penguins are coming!!!
« Reply #51 on: January 17, 2019, 09:25:30 pm »
Beautiful work, once in a while I find a build that I truly admire and yours is one of them. Keep up the good work.
Nick B
Illegitimi non carborundum!
midori gaoka
  • Location: On the french coast , in front of channel island
« Reply #52 on: January 24, 2019, 09:24:18 pm »
Hello,
I've just worked on liferaft. I did not succeed in mould and resin. So I put each one in my drill and shape it with sand paper.
They are 8 the same number as  counter measure box. They are stocked  inside
RST
« Reply #53 on: February 07, 2019, 10:18:43 pm »
Just asking -for the liferaft cannisters did you wrap polystyrene strip round the body?  I never had a problem doing this for years but recently I am finding the polystyrene strip breaks instantly as the solvent is applied.  I have maybe been making polystyrene things for 20 years and never had a problem, but the last 6 months it seems to make no difference what solvent or polystyrene sheet / extrusions I use, everything goes "ping" and breaks when solvent is applied under bending.  I am also finding the same chemical attack when I use CA instead -it never used to happen.  Perhaps the chemical mixes have changed?  Much respect to folk (and you!!!) who can still make it work.
Thanks,
NickelBelter
« Reply #54 on: February 08, 2019, 03:36:47 am »
I have had that issue with CA, I suspect it's the glue causing the plastic to go brittle while its stressed from bending around a curved form.  Have not had that issue using Tamyia solvent cement.
Niall
« Reply #55 on: February 10, 2019, 02:24:58 pm »
Could I suggest rapping the plastic strip around a suitable diameter metal rod(I usually used the shaft of a drill bit). Tape in place and pour over boiling water. The heat forms the plastic to the curve and reduces the chance of breaking when glueing in place.
RST
« Reply #56 on: February 10, 2019, 06:19:06 pm »
With the greatest of respects, I'm intrigued how our modeller does it.  I'm not inexperienced, actually I tried the Tamia solvent for the first time recently and I find it the most difficult solvent to deal with -it's very aggressive, clearly designed for plastic model kits.  I'm in France these days also so no easy access to the usual solvents and glues that "just work" over the last 20 years.
midori gaoka
« Reply #57 on: February 13, 2019, 12:44:12 pm »
Hello,
As you can see on photos, I work on rails. I drilled 0.5 mm holes. I wanted to complet before hull paints.
« Reply #58 on: February 13, 2019, 05:31:56 pm »
Exquisite  :o
raflaunches
« Reply #59 on: February 13, 2019, 06:40:17 pm »
Now that is amazing!
That is some skill will a soldering iron, I’m still practicing my skills on larger items and plan on getting to a standard to solder the masses of iron work on my Invincible’s bridge but even that is bigger than your exquisite stanchions.
Nick B
« Reply #60 on: February 14, 2019, 11:47:42 pm »
Likewise I am impressed with your brass work and soldering. The rails and their awkward shapes are fabulous!
midori gaoka
« Reply #61 on: April 01, 2020, 08:59:02 pm »
Hello,
I'm very very sorry. The model has progressed but without photos on the forum. I will try to reduce the delay.So I have completed davits. And I 've started the lifeboat
« Reply #62 on: April 04, 2020, 11:51:36 am »
It's been worth fourteen months to see that lovely boat Midori.
Is the clear plastic strip a stencil or letraset (Old school!) ??
midori gaoka
« Reply #63 on: April 04, 2020, 09:21:51 pm »
Hello,
I'm from the very old school, So I used the lettraset.So I've  completed the rescue boat which could be used as a small transport crew boat.
After thet, I've stated the dinghy boat.
littoralcombat
« Reply #64 on: April 04, 2020, 10:52:26 pm »
No need to apologise for your absence.......it has been worth the wait. Scratchbuilding at its finest.
Fantastic work Sir!
Nigel
Chris67
    • La mini-flotte de Lamiral67
« Reply #65 on: April 06, 2020, 03:43:26 pm »
Hi !
What a nice building !!! Bravo !!!!!!! :-)) :-)) :-))
midori gaoka
« Reply #66 on: April 07, 2020, 10:36:12 am »
Hello,
Thank you for your comments.
Now, it is time to paint. For first time, I use a paint for figurine (Prince August) . A very good quality and very easy to airbrushed, but very delicate .A water drop on a dry surface, and it is a small disaster. So, 3 vernish edges will be airbrushed to protect the painting.
« Reply #67 on: April 07, 2020, 08:42:28 pm »
If the paint you mention is Vellejo then yes, it has a period during its curing where it is a bit like vinyl and is fragile. It doesn't take knocks well and I find it lasts much better if painted over good old Humbrol style enamel or a good primer.
Your bridge front looks good Midori :)
midori gaoka
« Reply #68 on: April 10, 2020, 08:27:36 pm »
Hello,
So, it's time to finish hull and to give it a weathering effect. So, with pigments and paint, why not represent seaweed and seashell.
« Reply #69 on: April 13, 2020, 08:42:17 pm »
Paint applied with sponge? Looks amazing  :-))
midori gaoka
« Reply #70 on: April 19, 2020, 09:48:33 pm »
Hello,
I 've painted decks.Near the turret, there is a refuelling tube.I've found a glyceric paint with oil colour.So, I've  represented oil mark.
« Reply #71 on: April 19, 2020, 11:22:22 pm »
I like those little touches. Simple but so effective.
midori gaoka
« Reply #72 on: April 20, 2020, 09:20:24 pm »
Hello,
Thank you for your coments. It's time to give more life to the ship.I wanted to represent a refueling at sea. And keep an idea why not in the future sail with a french or a british navy tanker. On the second photo, i ve tried to represent rust on the exhaust.
« Reply #73 on: April 20, 2020, 10:43:46 pm »
Little rust or loads, it is always worth doing a little something as these areas probably got periodic repaints/replacements and so could be at any stage in between. Our veteran sailors can tell us best how often an exhaust would be maintained.
With regards to British military vehicles, an old friend of mine who did national service in the late forties said that for scratches on vehicles, you rubbed a bit of old engine oil in to stop rust before getting the opportunity to paint the offending area, otherwise you were put on charge for negligence.
midori gaoka
« Reply #74 on: April 25, 2020, 07:44:46 pm »
Hello,
The model is available for trials.A litlle bit stressed,as each time I let a new model on water. But, It was not too bad.
Pages: 1 2 [3] 4   Go Up
Page created in 0.165 seconds with 22 queries.
