Pages: 1 2 [3] 4 5   Go Down
Author Topic: IJN Akizuki 1:100 scale build  (Read 25699 times)
Re: IJN Akizuki 1:100 scale build
« Reply #50 on: June 23, 2018, 10:16:21 pm »
Neat and straight. It looks just like the real thing Dave. Like with Brian B and other people's scratch building, it is  a shame to paint over tidy work.
T888
« Reply #51 on: June 24, 2018, 06:04:58 am »
Once again Thanks for your feed back Ian it is much appreciated.
Painting ! That's funny you should say that.
This build, I started to use Tamiya paints. {:-{  But I've found that there is a difference in there TS range and XF, the TS is more a satin, but the XF is Matt.
There is also a colour shade difference as well.
it also seems that this vendors paints are a special order, as the first order for Hull and deck colours took over four weeks to come in. The second order, I've been awaiting for more hull grey, is now over four weeks.
I should have used Revel paints.
Regards David
« Reply #52 on: June 24, 2018, 02:39:47 pm »
I have used Revell's enamel Wine red (I think that's the name!) for painting below the waterline on two models now and am very pleased at its coverage and finish. It suits a coarser brush well and I would recommend this colour.
I haven't used Tamiya paints for ages. The last job was to paint a river on wargames terrain using a Dark blue and a Grey. While fresh they are good paints, but I find they separate after a year or two of storage.
Looking at a paint chart on line suggests that as one range is classic paint in a pot while the other is aerosol then it may be to do with the formulation for spraying. Cleverer folks than me would know if aerosol paint needs special thinners or even further reformulation to work from aerosol cans?
Re feedback, These projects are like watching telly for me. I do not have one and so entertain myself reading on this and one or two other forums.
T888
« Reply #53 on: June 24, 2018, 09:18:03 pm »
I used Tamiya this time as they did the specific paint for this class of warship, I'll have to live with this choice , as I've painted so much.
I'll in the future be using Revel paints, as like you have found it does give good coverage, it spray well when using an air brush and its stable.
I hope to keep you entertain for a bit longer with this build.
Regards David
« Reply #54 on: June 25, 2018, 09:40:05 pm »
It's first class. If the reality TV was as interesting I would consider getting a TV!
T888
« Reply #55 on: July 07, 2018, 07:06:21 pm »
Not been watching football, but I have been doing some wiring and small fitting work.
Regards David
« Reply #56 on: July 07, 2018, 10:04:39 pm »
Does the component box contain two ESCs and a mixer? The switches suggest duality in your system somewhere. That Funnel/superstructure assembly just gets better!
I listened to it on 5 Live and wished I had put a tenner on the England to win as I would have been £400 up on the deal!
T888
« Reply #57 on: July 08, 2018, 06:03:15 am »
Hi Ian,
The control box as you said , does have two ESC . It also has the 8 channel receiver, this allows me to use the control box in different models with out having to un-plug all the ESC and R/C units.
I still need to cut vents in the box and add the cooling fan.
I wish I was lucky in betting, unfortunately I never have been. £400 would buy a lot of modelling supplies.
Regards David
« Reply #58 on: July 08, 2018, 04:00:46 pm »
I tried that for my first two models but dimensions and some magic grey smoke prevented me from doing this.
For larger models I can see this as a good idea.
T888
« Reply #59 on: July 26, 2018, 09:21:35 pm »
Little more progress I thought you may like to see.
Regards David
« Reply #60 on: July 31, 2018, 08:33:22 pm »
Good lord, that superstructure isn't giving you any leeway eh? Lovely work as usual T888  :-))
T888
« Reply #61 on: August 04, 2018, 04:24:00 pm »
Moved back to working on the bridge structure. Not to happy with the vented box , I'll see what it looks like once it's painted.
Regards David
« Reply #62 on: August 04, 2018, 04:26:25 pm »
Things can look wonkier as an image than in real life. Sometimes the clearest images are too sharp for preview thumbnails etc, so don't knock your work too soon.
T888
« Reply #63 on: August 04, 2018, 04:37:50 pm »
Thanks Ian, I always have issue with making louvre,s, I just can't seem to get them spaced correctly. I've use serval methods / jigs to get good alignment / spacing. But specially at this scale just does not come good for me.
Regards David
T888
« Reply #64 on: August 09, 2018, 05:31:40 pm »
Made the master for the Capstern, deck hatch and the bases for the boat Davits this morning. This afternoon RTV mould was ready so the masters were pulled and I've started cast fitting off
Regards David
T888
« Reply #65 on: August 31, 2018, 02:26:52 pm »
Some update on my build. Hope you enjoy
Regards David
« Reply #66 on: August 31, 2018, 10:24:51 pm »
Wow! talk about progress. She's nearly complete I reckon. The model is very clean and well finished  :-))
T888
« Reply #67 on: September 01, 2018, 06:29:23 am »
Thanks Ian,
I still have a lot more to do, Boats, Davits, Mast, small AA guns, depth charge racks, just to list a few things.
Must say thanks for your comments again :-)) . It seem your the only one making comments even though this thread has over 4000 views.
Regards David
« Reply #68 on: September 01, 2018, 09:47:31 am »
Dave,
You beat me to it.
I have 1 of these vessels which needs a refurb.
Had it a few years now so I am one of the watchers, but don't want you to get too big headed with more comments!!!!
« Reply #69 on: September 01, 2018, 10:36:52 am »
I try and comment when the builder has done a lump of work rather than complimenting them on banging a nail in, as a sub assembly or impressive section of railings is something to enthuse about. It is often a major undertaking for the builder using up loads of their enthusiasm especially if it had to be re done several times to get right.
T888
« Reply #70 on: September 01, 2018, 05:01:25 pm »
Thanks for your feedback Ian,
Bob, I can always trust you to bring me back to earth. Thanks for your post, its appreciated,  if there's any fittings I've moulded,  that would help out with please let me now.
Tomorrow if the weather holds I would like to do some sea trials, I'll post pic,s if I do.
Regards David
« Reply #71 on: September 02, 2018, 09:49:30 am »
Now that is an offer I might not be able to refuse.
Being honest another stunning model up to your usual standard.
« Reply #72 on: September 04, 2018, 08:33:08 pm »
Video:
T888
« Reply #73 on: September 04, 2018, 09:01:25 pm »
Big thanks to Martin for down loading the video of her first sea trails :-))
Regards David
« Reply #74 on: September 04, 2018, 09:38:30 pm »
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.1 seconds with 22 queries.
