Author Topic: Hunter Systems  (Read 2004 times)
Howard Q
Hunter Systems
« on: January 21, 2018, 04:30:32 pm »
Hello everyone. I have to plead guilty on this score, I have not purchased anything for a little while from Hunter Systems, having put the name of the Company into Google plus using the www. path it does not bring anything up, actually the www. check shows the site being closed, does anyone have any information that can help as I would like to purchase some items, the products from this Company were always first class, still got and using bits bought in quantity from the old Ellesmere Port shows in the 1990s. Howard Q.
chas
Re: Hunter Systems
« Reply #1 on: January 21, 2018, 04:42:09 pm »
Hunter systems are long gone. There are several good companies around with similar products and everyone you ask might have an opinion as to which is best. Action electronics are loved by many, it all depends what you want.
Chas
jarvo
  • Etherow model boat club
Re: Hunter Systems
« Reply #2 on: January 21, 2018, 09:21:15 pm »
Hi Howard, I have several Hunter systems, ESC's, Also a few Electronize ESC's, they are both very good, but , Electronize are still producing. Have a look on their website
Mark
Tugs are for pulling
Howard Q
Re: Hunter Systems
« Reply #3 on: January 21, 2018, 10:57:31 pm »
Hello. The bits I was looking for are the smoke maker that Graham was producing complete with mini fan that I controlled by electronic switch,  it was very effective, my recent builds were all modern vessels so smoke was not needed, I am now building a 1928 ferry so this unit would be ideal, I know there are vapour units available, but in my view, water and electrics in a confined space are not ideal bedmates, any help would be appreciated.Howard Q.
Atlantic Mouldings
Re: Hunter Systems
« Reply #4 on: January 22, 2018, 06:37:56 am »
Howardq ,
I belive "Mastman" bought a lot of Graham's old stock so you could try and contact him , you never know he may have what your looking for.
jarvo
Re: Hunter Systems
« Reply #5 on: January 22, 2018, 01:00:24 pm »
Howard, there are some 'smoke machines' on ebay, they use water and ultra sonic's to make steam, worth a look
Mark
McGherkin
Re: Hunter Systems
« Reply #6 on: January 22, 2018, 01:20:45 pm »
I personally feel it’s a little safer than a red hot element and oil, plus you get the oil staining all over the model. If you use distilled water it won’t even be conductive.
RST
Re: Hunter Systems
« Reply #7 on: January 23, 2018, 09:24:19 pm »
Glad someone else posed this question -I've been looking for hunter systems for a while but not found much.
Re: Smoke generators, glad I wasn't the only person thinking the original concept of hot wires and oil is probably less safe than the modern ultrasonic and water.  But I must admit I still have seuthe smoke generators (they're so small!!!), and so conveniant compared to the mega smoke machines.  One bottle of oil "puffs", the other gives constant smoke.  Eazy-peazy.  I'm sure you can still get them from model railway folks and the like -and they're quite cheap / compact -but they do give HEAT and proper "smoke" compared to the allbeait muh bigger units which do not.
inertia
Re: Hunter Systems
« Reply #8 on: January 23, 2018, 11:46:01 pm »
unbuiltnautilus
Re: Hunter Systems
« Reply #9 on: January 23, 2018, 11:58:38 pm »
If it's glowing, you are doing it wrong!
Page created in 0.097 seconds with 21 queries.
