Model Boat Mayhem - Forum
Author Topic: Bench Disk Sander 125mm from Lidl 29.99  (Read 3554 times)
Tug Fanatic
Re: Bench Disk Sander 125mm from Lidl 29.99
« Reply #25 on: February 13, 2018, 08:05:00 AM »
I cannot get at wherever mine has gone without completely dismantling the machine.
Howard
« Reply #26 on: February 14, 2018, 06:43:12 PM »
Hello Gents,
 Am so pleased and must be lucky  as I have just put my first disk on my sander and after what's been said on here was so very worried I undid the table  and pulled it off looking at it I could see a metal thread so disk on and table  put back and screwed up  I don't know if it made a difference  but I never stood it on its end, phew so pleased am not having to take it back.
                  Regards Howard.
nemesis
« Reply #27 on: February 16, 2018, 07:49:01 PM »
Finally got round to unpacking the replacement sander, instead of taking the platform off to put the disc on and taking the chance of having the same thing happening again I took the angle platform off and applied the disc. simples, nemesis
mrzippy
« Reply #28 on: February 16, 2018, 08:38:32 PM »
Problem solved fellow Lidl shoppers -
When you undo the Allen bolt there's a bog standard galvanised nut trapped? in a plastic channel/slot
that disappears as if by magic, or in this instance - the powerful magnets in the electric motor.
Mine did it and completely vanished from view inbetween the ali sanding disc and motor casing,
required a dentists mirror to find it and right angled tweezers to retrive the nut.
Nut is now firmly hot glued into place in its channel/slot !
regards Paul
Paul2407
« Reply #29 on: February 18, 2018, 04:57:24 PM »
regards Paul
Good idea,
I managed to pick one of these up today and I have to say apart from the casing they are so simular to the Proxxon version it's uncanny everything is in the same place, switches, speed knob, fixing points even the vaccum outlet is in the same position I would be rather annoyed at buying the Proxxon at around 200 as this even comes with a 3 year guarentee too, I managed to unpeel the disc and slide it behind the platform and stick it on the disc without removing anything just a gentle turn to press it on completely around and I'm good to go
Tug Fanatic
« Reply #30 on: January 25, 2019, 09:55:34 PM »
Its back & of course other tools & consumables.
Sunday 3rd February 29.99.
https://www.lidl.co.uk/en/MiddleofLidl.htm?articleId=20015
Footski
« Reply #31 on: January 26, 2019, 08:33:16 AM »
Argh......I have been waiting for this for over a year to be sold in Lidl Spain, to no avail. I would love one, but guess I will just have to keep waiting.. >>:-( >>:-(
« Reply #32 on: January 26, 2019, 10:59:29 AM »
Any good?
Operational - 1/72 LCMIII, 1/180 Royal Sovereign
incomplete, HMS Victory, tug, cardboard castle class convert, got the new job, looking again though
« Reply #33 on: January 26, 2019, 11:08:40 AM »
So its only any good if you dont dismantle it  {-)
« Reply #34 on: January 26, 2019, 11:47:48 AM »
Our store has a couple of welding units (and helmets) and the odd cordless drill, unlikely to have the cross cutter at 50.00 as well (could have done with that a couple of weeks ago when I was cutting the pelmet for the kitchen  >>:-( ).
Tug Fanatic
« Reply #35 on: January 26, 2019, 01:04:59 PM »
No that wasn't the problem. If you followed the instructions for fitting the sanding disk a couple of nuts fall away from their location inside the machine. You need to dismantle the unit & fix the nuts in place - hot glue was suggested.
Whether that worked & whether they have resolved the problem this year I have no idea.
Footski
« Reply #36 on: January 26, 2019, 01:51:58 PM »
My son has one of. These sanders and it works beautifully. Outstanding value for money. Not sure about those with faulty nuts, but maybe it has been put right?
« Reply #37 on: January 26, 2019, 04:05:45 PM »
Prefer tools which are made out either cast or sheet steel . Although I have been known to break those  >>:-(
The early bird catches the worm.
But it is the second mouse that gets the cheese.
« Reply #38 on: February 03, 2019, 09:09:20 AM »
about to start off to the local store to see if I can get one, but most likely they wont be any  <:(
« Reply #39 on: February 03, 2019, 09:15:07 AM »
  You might be able to get a Lego bulldozer.
Dave_S.
« Reply #40 on: February 03, 2019, 11:00:31 AM »
I arrived at my local Lidl store (Witney) at 09.45 and was first in the queue. I managed to get their one pillar drill and one of the dozen or two bench sanders they have. Can't report on quality until I unbox them, probably tomorrow with all the upheavals in our house preparing for a new kitchen. It does mean I'll have a new 5'6" worktop with cupboards and drawers though!
« Reply #41 on: February 03, 2019, 05:46:23 PM »
Well, first in the queue as well, got the sander (there was about 5), a multi purpose tool (side ways oscillator action) and a separate pack of things for it. tempted but resisted the pillar drill even though at one point, one of them was in the trolley, then thought 'I don't do enough to warrant one' so put it back.
As Dave_S said probably wont unbox it till tomorrow (still have to get it out of the car boot yet), had to replace the front door mortice lock.
What lego bulldozer, didn't see them advertised.
grendel
« Reply #42 on: February 03, 2019, 08:29:15 PM »
this weekend I got a baby fly press set up as a 1/8" hole punch - 4 holes at 1" centres
« Reply #43 on: February 03, 2019, 09:19:06 PM »
https://www.lidl.co.uk/en/MiddleofLidl.htm?articleId=20022
« Reply #44 on: February 03, 2019, 09:32:41 PM »
Nah - too difficult for me, above my (mental) age - 8 to 14  {-)
