Author Topic: When to charge?  (Read 2191 times)
tizdaz
  • Boom!
When to charge?
« on: February 13, 2018, 03:19:46 am »
Hi guys, just a quick one
I have a voltage LED display that shows current voltage of my 12v cel, question is at what voltage should i disconnect & recharge, its a 12v 22AH gel cel as i know i shouldn't let it drop too low?
cheers :)
My large-scale TID Build Website: http://www.tizdaz.co.uk/forum
Facebook:
Re: When to charge?
« Reply #1 on: February 13, 2018, 09:05:02 am »
If a 12 volt battery gets below 12 volts, its time to charge.  If it doesn't make it to at least 13.5, its time to change.  Either way, its a good idea to check the calibration of the display device against something of known accuracy occasionally.
In a multi battery set-up, it is a good idea to make sure that the battery being reconnected is the same voltage as its mates, a small difference can give a very big circulating current as they even out.  If they connect through a schottky diode unit, the highest voltage one carries the load until its voltage drops down to equal the next, then they bot carry the load.
tizdaz
  • Boom!
Re: When to charge?
« Reply #2 on: February 13, 2018, 08:48:49 pm »
ok thanks :)
Facebook:
Peter Fitness
Re: When to charge?
« Reply #3 on: February 13, 2018, 09:16:22 pm »
Following advice I received many years ago, I always recharge my SLA batteries after every sailing day, and store them out of the boat fully charged. A couple of them are over 8 years old and still delivering full power, I don't have a digital read out, but charge as a matter of course.
Peter.
BrianB6
Re: When to charge?
« Reply #4 on: February 13, 2018, 10:00:23 pm »
I agree with Peter, always charge straight after sailing.   My charger shows a red LED whilst charging and a green LED when fully charged ( was not all that expensive although I have had it many years)
Also try charging after a month or so just to top it up.  SLA's should be kept fully charged.
tizdaz
  • Boom!
Re: When to charge?
« Reply #5 on: February 13, 2018, 11:59:42 pm »
great info thanks guys, i wasnt too sure so will just charge after each sail :)
Facebook:
Page created in 0.134 seconds with 22 queries.
