The weather cleared up for a few days, so I popped out to the pond for lunch.
The U-joint finally held up, there were three repairs. The opposite end came loose, and after a
first go at epoxying it failed, I drilled and set three shear pins into the locking collar and rubber.
The model felt like it was running a bit sluggish, but it could be the new batteries.
It will spin about quickly with one reverse bucket down and in a turn.
However at slow speed, the model slides around, and won't stop turning unless a bit of counter force is applied.
It will need a bit of practice to cozy up to the quay with out bouncing around.
While the model felt slow, it had a good scale speed look to it.
And with the u-joint holding, I have set to painting and setting the safety railings, and will finish setting other fittings.
