Author Topic: BEN AIN  (Read 3771 times)
BEN AIN
« on: February 25, 2018, 04:39:41 pm »
Just had a message about a  BEN AIN I  owned some 10 years ago about how much ballast to but into it..............I never built it so if any builders are out there of this model, could you tell me please how much you put in, using a 12v 7amp/hr battery as I haven't a clue, and the guy wanting the info didn't even leave his name via email.
thanks, neil.
afetta
Re: BEN AIN
« Reply #1 on: February 25, 2018, 05:13:40 pm »
Nell thanks for posting that, it was I that contacted you regarding the Ben Ain and the actual displacement, sorry not to include a name, actually I am a novice at this posting and messaging..sort of thought the sender would be revealed..
Re: BEN AIN
« Reply #2 on: February 25, 2018, 05:21:33 pm »
ahh............I wondered if youd make it on here..........was a very out of the blue message and it wasn't unti after I had posted this that I actually did build a Ben Ain but that was more than 30 yearsago and it was a converted  smaller Caldercraft Talacre kit.............could you tell me where you saw the photo as I don't know which model you mean now...........
thanks afetta, and welcome to the site.........plenty of help here for you, as both a novice and seasoned builder...........I'm often asking members, especially about electrickery..
neil.
afetta
Re: BEN AIN
« Reply #3 on: February 25, 2018, 05:30:41 pm »
Yes, I saw the photo on the Tugforum.com, someone had asked a question about Mount Fleet models, your photo was one of the reply posts..A
Re: BEN AIN
« Reply #4 on: February 25, 2018, 05:53:36 pm »
I thought that forum had folded some time ago..........I was a member...........will have a look. thanks.
mountfleet
Re: BEN AIN
« Reply #5 on: February 25, 2018, 06:19:54 pm »
Hi Afetta,
My works Ben Ain has a 7lb weight at the front of the main hatch, across the hull, a 12v 7ahr battery at the back of the hatch, 2 2lb weights under the bridge and a pound of lead shot resined in round the propshaft.
Giving a total of 12lb plus battery.
Hope this helps
Adam
Mountfleet
TheLongBuild
  • Build em, and play hard..
Re: BEN AIN
« Reply #6 on: February 25, 2018, 06:30:36 pm »
No the Tug Forum is still going
Re: BEN AIN
« Reply #7 on: February 25, 2018, 07:13:40 pm »
Hi Afetta,
Hope this helps
Adam
Mountfleet
good one Adam..................now where is that tender tug..........hope it's on the burner mate. O0 :-))
neil.
afetta
Re: BEN AIN
« Reply #8 on: February 25, 2018, 08:36:48 pm »
Thank you all for the support, so 12 lbs seems like a good figure.
Buccaneer
Re: BEN AIN
« Reply #9 on: February 25, 2018, 08:56:07 pm »
Hello Afetta
My Ben Ain has a total all up weight of 12.3 Kg. This includes 2 x 12V 7.7 A/Hr Batteries at approx. 2.5 Kg each and 700 g of lead ballast. With just one battery you would need approx. 3.2 Kg of Ballast, depending on what other fittings you have.  Hope this helps
Buccaneer
Re: BEN AIN
« Reply #10 on: February 25, 2018, 08:58:16 pm »
Sorry about the underlining!! It should have been under 'total' and 'each' only.
I've cleared it for you.
ken
