Author Topic: New Member  (Read 7124 times)
Big Ada
Re: New Member
« Reply #25 on: March 07, 2018, 05:05:34 pm »
Stunning Models,
Len.
Piers Grabeard
Re: New Member
« Reply #26 on: March 07, 2018, 05:14:19 pm »
Thankyou.
Perkasaman2
Re: New Member
« Reply #27 on: March 07, 2018, 05:29:57 pm »
Piers you are a craftsman.
Re: New Member
« Reply #28 on: March 07, 2018, 09:32:43 pm »
Amen  :-))
Piers Grabeard
Re: New Member
« Reply #29 on: March 07, 2018, 09:35:57 pm »
Thanks to those who made nice comments.  My models don't have the finesse of some I've seen, they tend to be very practical working models for r/c. I don't have to spend ages when I get to the pond with the super-glue sticking on all the bits that fell off on the journey; and they do come off best in any collision!
Re: New Member
« Reply #30 on: March 08, 2018, 10:38:02 pm »
Any lack in finesse (and I cannot see much of a lack) is made up for by the interesting joints and structural detail. A modern fibreglass plane may look all sleek and snazzy, but there is nothing to beat seeing how a Lancaster or Spitfire has been shaped and assembled from formed panels and challenging formers. Seeing the section of wooden lattice , all two feet of it? from a crashed zeppelin at Yeovilton is such an education seeing how each piece of wood was shaped and material removed to lighten it.
Flush rivets may have been more aesthetic, but they are much less interesting  :-))
Piers Grabeard
Re: New Member
« Reply #31 on: March 08, 2018, 10:45:07 pm »
I found flush rivetting to be quite tricky. Getting the depth just right is hard to judge. I have bought several countersunk bits with the correct size (3/32) mandrel in the end, but the mandrels are always seriously undercut in the shaping of the cutting edge. The thin aluminium I use doesn't support the weakened mandrel sufficient and the tiniest 'chatter' and the mandrel snaps off.  I have ended up just using a drill of the same diameter as the overall dimension of the countersunk rivet head.
Captain fizz
Re: New Member
« Reply #32 on: March 09, 2018, 10:30:44 am »
Sir, I salute you.
Your models are superb and a credit to your metalwork skills :-))
Simon
T33cno
Re: New Member
« Reply #33 on: March 09, 2018, 01:14:20 pm »
Amazing  %% 8)  and Welcome Piers
Piers Grabeard
Re: New Member
« Reply #34 on: March 09, 2018, 10:42:16 pm »
Thankyou Plastic and to several others for kind comments.  Just in case anyone is interested, the 63 inch Damen Stan 1605 Patrol model took 5,000  3/32" pop rivets to make. I've learned a lot about pop rivets since I started making these models. It also took a hundred or so 8BA nuts and bolts and a quantity of 3/32 solid aluminium aircraft rivets from the Hastings hangar at Handley Page. I was given a shoe box of assorted rivets in 1967 and I'm still using them.
smudger1309
  • Colwyn Bay M.B.C
Re: New Member
« Reply #35 on: March 17, 2018, 12:03:35 am »
very nice models,  thank you for sharing  :-))
Piers Grabeard
Re: New Member
« Reply #36 on: March 17, 2018, 08:53:50 am »
Thankyou.   If anyone wants to make a metal model, I'm quite happy to pass on what I've learned over the years.
Re: New Member
« Reply #37 on: March 18, 2018, 08:07:26 pm »
When you next build a model, do a build log and then you can share your wisdom and experience in a measured and orderly manner. Don't worry if you don't seem too get many responses sometimes when you do start one, just look at the visits and you will be surprised at how many people are watching  O0 :-))
Piers Grabeard
Re: New Member
« Reply #38 on: March 18, 2018, 09:06:31 pm »
Hello Ballastanksian,
My recent boat, number 30, I photographed its progress from day 1 every week or two until I finished it. I haven't managed to post any pictures, as I can't get the system to work and I'm not very good on computers. Somebody else has posted my other pictures, and if he was willing, I could send them to him. The first lesson I learned is when producing drawings is not to draw them on wallpaper joined edge to edge to get the size needed. I drew them on a large sheet of ply from Wickes, which is rigid and much more useful. Drawings on paper stretch and shrink with humidity and also tear very easily. Also needed is another ply board with battens down both sides and acrossways here and there to build the model on. This is marked with a centre line and lines across every 1/2 inch and the 'stations' numbered in inches. There must be holes cut out in the middle to put your hand inside. All the bulkheads and frames are cut out and attached to this board with nuts and bolts before skinning commences. Frames are needed at intervals no more than 4 inches, and 2 or 3 inch intervals where the hull shape is complicated. It's very similar to building a balsa model aircraft except you are using thin sheet metal. One thing with metal is that there are no shortcuts. The skin has to be right, you can't file or sand down the contours afterwards like you can with wood, it's only 25 to 45 thou thick. Metal is not easily bent in complicated curves without professional bending and shaping presses; you are generally limited to curves in one plane.  The hull is assembled with 3/32 inch blind (pop) rivets, countersunk below the waterline and your personal choice above. Good quality rivets retain the snap head and are watertight, and even the slightest tendency to leak is cured once the model is painted. More troublesome are the seams, but are easily fixed with paint. Don't use filler to start with, it just sits on the outside. Use up any old gloss solvent-based paint on the inside of all the seams. It will penetrate the seams and may drip underneath the boat to start with, but after 8 coats, will fully seal all the joins. Colour is immaterial, I have loads from old house decoration jobs.  Any holes and cut-outs in the frames and bulkheads need to be made before they are fitted. Drilling holes afterwards is very tricky. It can be done with a right-angle drill drive, or with a long drill, made by silver soldering a drill onto a long shaft, but it is not easy. When the hull is all rivetted up it can be removed from the assembly board; it will be very rigid and strong.  All my stringers and longerons are either cut from sections of greenhouse frame or bent from sheet. For this you will need a couple of lengths of 3/4 x 1.1/2 mild steel bar about 2 or 3 feet long. You will need lots of G cramps and a piece of RSJ from a big building. Domestic RSJ's are a bit light in section. This is clamped to the work bench and the work all clamped up. It then remains to hammer up your sheet metal working along the edge gradually until you have it all bent up at right angles. It's easier to hammer upwards because you can see the line you are bending the metal to. You can't if it poitning downwards. I have a big collection of iron blocks of all shapes and sizes for shaping metal around. 'U' channel can be made by hammering the metal with it clamped to  the edge of angle iron and hammering it around. Different gauges of angle iron will give different sections of channel.  I'll stop here in case of gone on too long, but I can carry on if anybody wishes, and can certainly try to answer questions, and if all the construction stages are wanted I will submit more photos for inclusion. Peter
