Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 60   Go Down
Author Topic: What have you bought this week?  (Read 203295 times)
Taranis
  • Balne Moor MBC
Re: What have you bought this week?
« Reply #200 on: February 18, 2019, 04:05:55 pm »
To go with the brass split pins I bought. I purchased these 2mm brass washers to use as grab rail back plates on the split pins.
Model shops seem to charge the earth so I think these are a bargain unless someone knows better?
4x100 for £7.32 inc delivery
Price breakdown
ANDY
« Reply #201 on: February 18, 2019, 09:28:02 pm »
Andy.......I purchase M2 - HH metric bolts from Knupfer ...same as your supply?.......but for M2 brass washers I found the Chinese precision M2 brass washers with a true M2 toleranced hole unbeatable
So the Knupfer M2 bolts are to DIN & measure ~~1.93 diameter & are a great mating size for the M2 washers
Taranis
  • Balne Moor MBC
« Reply #202 on: February 18, 2019, 09:30:46 pm »
Have you a link to your seller Derek please  :-))
This is the gist of the idea passed to me by Chris Scott
ANDY
« Reply #203 on: February 18, 2019, 10:43:22 pm »
Andy...I do see a large clearance >>:-(  between the OD of the split pin & the ID or the washer....which may be problematic for soldering...
[I suspect if you gauge your M2 washers, they may in fact be M2 clearance or approx 2.2 to 2.3]
I found the Germans as the only supplier of brass hex head, but this guy in China for M2 & M3 washers, M2 & M3 S/S socket head cap screws.....and amazingly M3 socket head cap screws in brass!
I just search in Google/e-bay....find this supplier name & choose to purchase from him as there are usually 2 or 3 suppliers with the same product for same or similar cost
In the last image you can see the M2 HSS twist drill in the caliper & a sample of one of his M2 ID washers.....with very little clearance.....obviously they use 2.0 diameter pins in their die forming operations.........[not 2.2 like others]
[200 M3 brass washers were $5.36 Australian ..posted free to me].............
Taranis
  • Balne Moor MBC
« Reply #204 on: February 19, 2019, 07:25:51 am »
Thank you  :-)) :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #205 on: February 25, 2019, 01:29:32 pm »
I bought this for my car and liked it so much I bought a second for the van
Qi phone charger and mount
Just drop the phone in and it clasps it securely with no faffing with wires
ANDY
« Reply #206 on: February 26, 2019, 10:50:48 pm »
I bought Epoxy resin, Acetone and GRP cloth for Novgorod and a Matchbox E Type Jag for a war games project  :}
I am thinking of getting Bass and ply for the armoured cruiser soon before my wallet deflates.
grasshopper
    • A1 Hobbies Ltd.
« Reply #207 on: February 27, 2019, 07:39:05 pm »
 Not so much bought this week but finally assembled my 8x6 shed to get some of the junk out of my garage so I can locate my bench!
raflaunches
  • The Penguins are coming!!!
« Reply #208 on: February 27, 2019, 07:48:56 pm »
Slightly different to the usual
I bought a new vinyl copy of Jeff Wayne’s Musical Version of The War of the Worlds. I’ve got an original but didn’t want to wear it out or damage it if I had a new one to play. Sounds pretty good on my gramophone.
Back to the usual!
A flag from Mike Allsop aka flag man.
Nick B
Illegitimi non carborundum!
Liverbudgie2
« Reply #209 on: February 27, 2019, 07:55:50 pm »
Dizzy cap, HT leads, coils, head gasket set, belts, together with other small items for the XJ-S.
LB
« Reply #210 on: February 27, 2019, 09:38:34 pm »
Wow LB.......[Jaguar spares >>:-( ] ........which Bank Manger did you need to see for a $$$$ loan?  :-X ............ Derek
Liverbudgie2
« Reply #211 on: February 27, 2019, 11:43:37 pm »
Wasn't that bad really - £400ish; the big spend comes tomorrow with a new alloy rad and fans and more bits and bobs.
LB
Captain Flack
« Reply #212 on: February 28, 2019, 08:55:42 am »
Lego Technic and power upgrade
« Reply #213 on: February 28, 2019, 12:20:15 pm »
just got my car back, two new rear suspension rods that looked like open ended ring spanners, and the clutch pedal and its fitting to the bulkhead refitted - wondered why the clutch was not engaging as it usually did, well its a 20 year old car - what do you expect.
My son tried at weekend to fit his old motherboard to my pc case, replacing an asroc alive for a better small form one, with a better chipset etc and ram, well my pc is destroyed, so i am having to use an old one, he went out and bought a new motherboard and cpu and ram etc and fitted it - wouldn't read the old c drive so he's overwritten it and so it's definitely fragged and I wont use it on principle, I will just have to find a way of hiding this pc in the loft and use it up there, so i need to put a proper power supply in there to allow me to use it effectively, so may be off line for a long time.  >>:-( >>:-( >>:-(
« Reply #214 on: February 28, 2019, 12:34:16 pm »
So you can choose your computer repairer, but not always your relatives   {-)
ChrisF
  • What's my favourite cake!
« Reply #215 on: February 28, 2019, 01:32:06 pm »
Bought a monopod for when using my recent purchase of a big camera lens.
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All to a scale of 1:12
Liverbudgie2
« Reply #216 on: February 28, 2019, 02:52:41 pm »
A handy investment especially when you're out and about - in more ways than one. I always keep mine strapped to my wrist.
LB
Bowwave
« Reply #217 on: March 01, 2019, 10:08:34 am »
Don't try and take a mono pod  through  airport security  {:-{ <:( :police: .
Bowwave
Buccaneer
« Reply #218 on: March 01, 2019, 07:23:58 pm »
I collected my new car this morning. Volvo XC40. I would have kept the Land Rover but on only 5000 miles per year and less and less longer runs Petrol had to be the way to go.
ChrisF
« Reply #219 on: March 02, 2019, 02:44:40 pm »
I'm changing to petrol soon as retiring and the XC40 is on my list to replace the Yeti. Let us know how you get on with it.
Chris
ChrisF
« Reply #220 on: March 02, 2019, 02:46:53 pm »
Bowwave
My wife insisted on taking my mini-tripod through once, it fits in a holster type case. She got stopped.  :}
« Reply #221 on: March 02, 2019, 02:57:21 pm »
Left her behind then {-) {-)
ChrisF
« Reply #222 on: March 02, 2019, 03:09:25 pm »
Nah, couldn't do that, I wanted my tripod back!
Martin [Admin]
« Reply #223 on: March 02, 2019, 07:44:23 pm »
Scale model replica of HMS Victory engine telegraph circa Battle of Taraf al-Ghar!
 ( details confirmed in the Ebay listing from the Chinese seller! )
Taranis
  • Balne Moor MBC
« Reply #224 on: March 02, 2019, 08:11:59 pm »
 Sail's in and out are missing {-)
ANDY
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 60   Go Up
