Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Down
Author Topic: Stevns Arctic Build  (Read 98755 times)
Dreadnought
Re: Stevns Arctic Build
« Reply #200 on: April 22, 2020, 08:59:26 am »
Ooh that's a big water-cooling inlet lol  {-) {-)
chipchase
« Reply #201 on: April 22, 2020, 09:02:44 am »
Its for the bow thruster LOL
steve mahoney
« Reply #202 on: April 22, 2020, 10:12:27 pm »
Woah! That's drastic.
chipchase
« Reply #203 on: April 22, 2020, 11:09:54 pm »
yes it might take in a bit water it will need a big bilge pump  :-))
chipchase
« Reply #204 on: April 23, 2020, 09:54:08 am »
As I have said I decided not to use belts for the drives. The alloy headgear is a little bit on the noisy side, I have since changed to nylon headgear and they are a lot quieter, the two photos show the way they are with the alloy headgear.
dodes
« Reply #205 on: April 23, 2020, 05:11:03 pm »
Nice piece of engineering.
chipchase
« Reply #207 on: April 27, 2020, 04:33:10 pm »
Starting to take shape again, a few blemish's to get rid of then try to do the mould
« Reply #208 on: April 27, 2020, 09:27:33 pm »
Just been comparing the photos, prior to your drastic measures, to the 'as it is now' photos. You've done yourself justice there mate - great work  :-))
Blaven03
« Reply #209 on: April 27, 2020, 09:33:20 pm »
Looking great.
chipchase
« Reply #210 on: April 27, 2020, 09:43:36 pm »
Thanks lads  :-))  I am going to experiment making a mould of this plug before I attempt making the mould for the Pelagic Trawler.
Taranis
  • Balne Moor MBC
« Reply #211 on: April 27, 2020, 09:49:29 pm »
Any pictures of how you did it?  %%
ANDY
chipchase
« Reply #212 on: April 27, 2020, 11:10:21 pm »
Andy I have only a couple of photos the one on page 8 showing the amount I removed and this one showing the car filler before I did  bit more shaping, if you have looked at my Pelagic Trawler build it was basically the same method, i made some frames the shape that looked better then fitted them into the hull, I fitted a piece of ply down the centre of the hull to hold the frames in place then filled packed with close foam then shaped and covered with the car filler then lots of sanding, hope this explains.
Taranis
  • Balne Moor MBC
« Reply #213 on: April 27, 2020, 11:12:16 pm »
Thank you that’s a good explanation  :-))
ANDY
chipchase
« Reply #214 on: April 28, 2020, 09:29:51 pm »
that's the sanding just about finished, fitted the dividing board on the hull hopefully get gaps filled tomorrow ready to start waxing up.
chipchase
« Reply #215 on: May 02, 2020, 03:51:29 pm »
Well that wasn't to bad first half of plug gel coated and glassed, former removed and plug waxed ready for next side.
« Reply #216 on: May 02, 2020, 05:15:58 pm »
Seems like you've got this moulding technique sorted Brian - good to see your progress  :-))
Georgeconna
« Reply #217 on: May 02, 2020, 07:41:52 pm »
Never seen this before so good educational pictures there!
towrope
« Reply #218 on: May 02, 2020, 08:45:18 pm »
  Nice work Brian give it a couple of days before you try to separate the two parts this lets it cure the longer you leave it the better it will be  then hope for the best and fingers crossed look forward to seeing the finished subject  :police: :-))
chipchase
« Reply #219 on: May 02, 2020, 09:24:48 pm »
cheers lads quite pleased with my first attempt I will probably leave it about four days towrope. I have just finished putting the first coat of glass on the starboard side, I will give it another three coats tomorrow  :-))
towrope
« Reply #220 on: May 02, 2020, 09:49:42 pm »
good work Brian hope you don't take it the wrong way but drill the holes for bolting together before you separate the two half's that way it will bolt together perfect keep up the good work.
chipchase
« Reply #221 on: May 02, 2020, 10:10:07 pm »
 All suggestion's are welcome towrope, I will be drilling the holes before I part the mould I have also incorporated lining up pins into the flange
chipchase
« Reply #222 on: May 05, 2020, 04:55:45 pm »
Well decided to remove plug from mould today with a little bit of persuasion it came out LOL, a bit of cleaning up but I'm quite pleased at my first attempt at making a mould.
Im looking forward to start glassing up my Pelagic Trawler plug know.
« Reply #223 on: May 05, 2020, 05:06:49 pm »
My initial reaction - looks like you've been successful - well done mate.  :-))
Howard
« Reply #224 on: May 05, 2020, 05:22:40 pm »
Hello Brian,
 it's looking so good bonny lad but then I was never worried about your skill to make one am not into trawlers shame in wasn't a  north east tug still trying to get Anth to make a 1:24 Ryhope that would go great with my other four Tyne/Wear tugs but we all have to have a wish/dream hull I still enjoy watching your next project come to life I pick up so many tips seeing how you have done it again thanks for your build tread.
                Regards Howard.
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Up
Page created in 0.038 seconds with 21 queries.
