Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14   Go Down
Author Topic: Stevns Arctic Build  (Read 98762 times)
Howard
Re: Stevns Arctic Build
« Reply #225 on: May 05, 2020, 05:23:18 pm »
Hello Brian,
 it's looking so good bonny lad but then I was never worried about your skill to make one am not into trawlers shame in wasn't a  north east tug still trying to get Anth to make a 1:24 Ryhope that would go great with my other four Tyne/Wear tugs but we all have to have a wish/dream hull I still enjoy watching your next project come to life I pick up so many tips seeing how you have done it again thanks for your build tread.
                Regards Howard.
chipchase
« Reply #226 on: May 05, 2020, 06:08:36 pm »
Thanks lads, at 72 I'm still learning  :-))
chipchase
« Reply #227 on: May 10, 2020, 05:46:28 pm »
Just removed from the mould today, really pleased the way she has turned out I should have been moulding my own hulls years ago  :-))
towrope
« Reply #228 on: May 10, 2020, 06:13:34 pm »
nice job Brian hope you didn't have many problems separating the mould I know you have other things on your inventory so if your not working on the Stevens straight away put it back in the plug helps keep it's shape and stops it twisting and protects the plug
                                                         all the best Brian and take care :-))
chipchase
« Reply #229 on: May 10, 2020, 06:38:37 pm »
Thanks Tom, it took a bit of persuading but the mould was OK, I have a few others I'm busy with LOL, I will take your advice and put it in the mould for now  :-))
Howard
« Reply #230 on: May 10, 2020, 08:40:42 pm »
Hello Brian,
 As all ways a great job can I ask if your next one could be a 1:24 Ryhope sorry Brian am being cheeky I wish you well  as I never thought you would ever fail.
             Regards Howard.
chipchase
« Reply #231 on: May 10, 2020, 11:16:15 pm »
Hello Brian,
             Regards Howard.
I don't think so Howard, I think the three projects i have on at the moment will keep me going for the next few years  :-))
I looked at her history, she was built 1943 in Alabama long before France Fenwick Tyne & Wear Co Ltd bought and registered her at Sunderland
and named her Ryhope.
Howard
« Reply #232 on: May 11, 2020, 12:18:32 am »
Hi Brian,
 Yes I think there was five all together all name after parts of Sunderland and first diesel tugs on the river Wear, I have four !:24 Tyne, Wear Tugs all different, Ryhope would will be my last dream tug might have to copy you and make my own give my plans to Anth when I bought my Cragsider so will have to buy another set keep up the great work such an enjoyment watching your builds.
              Regards Howard.
chipchase
« Reply #233 on: May 13, 2020, 08:58:11 pm »
I was hoping to carry on with the Trawler hull today but unfortunately i am waiting for gelcoat, so i decided to start on the Stevns bulwarks.
chipchase
« Reply #234 on: June 13, 2020, 09:08:36 pm »
Thought i would have a break from the Trawler build and do a bit on the Stevns, I managed to finish the bow thruster and hopefully get it fitted tomorrow
Howard
« Reply #235 on: June 13, 2020, 09:56:40 pm »
Hi Brian.
I like how you do yours makes a lot of sense if you ever have to change the motor or tight for space I hope if you don't mind me copying it
             Regards Howard.
chipchase
« Reply #236 on: June 14, 2020, 08:14:35 am »
Hi Brian.
             Regards Howard.
Hi Howard I have messed around with different set ups over the years and find this the easiest way, as you have said if any maintenance is needed easy removed, I don't have any problems with any one copying the way I have done mine  :-))
chipchase
« Reply #237 on: June 15, 2020, 09:33:05 pm »
Good day today, got the bow thruster fitted pleased with the way it has turned out.
chipchase
« Reply #238 on: July 08, 2020, 10:51:12 pm »
Had a break from the trawler today done a bit work on the Stevns, I need to get the deck supports fitted so decided to cut the 14 wash ports out to help line up the deck supports. I also made the wash port inserts.
Howard
« Reply #239 on: July 09, 2020, 10:48:28 am »
Hi Brian,
That's just amazing modelling I wish I lived next door so I could see your skill every day and learn from you.
            Regards Howard.
chipchase
« Reply #240 on: July 10, 2020, 08:12:09 am »
Cheers Howard  :-))  I will let you know when the house next door comes up for sale LOL
chipchase
« Reply #241 on: July 11, 2020, 08:47:00 am »
Small update anchor ports done. :-))
chipchase
« Reply #242 on: July 11, 2020, 09:37:17 pm »
Managed to get the port and starboard keels made and fitted today.
« Reply #243 on: July 11, 2020, 09:44:55 pm »
Those bilge keels do present difficulties for us all but you appear to have been successful - I'm guessing that you've anchored them from the inside?
chipchase
« Reply #244 on: July 11, 2020, 10:08:48 pm »
The keels are metal Ray, the photo I have attached is one of the keels I made for the trawler, the keels on the Stevns are made in the same way. Small holes are drilled into the hull them the pins pushed through then bent over in opposite directions then filled with car filler it makes a really strong job.
« Reply #245 on: July 11, 2020, 10:22:25 pm »
I just knew it would be a solid fixing!
Thanks for the update Brian - it's in the book now for future reference  :-)) .
chipchase
« Reply #246 on: July 14, 2020, 09:28:28 pm »
Progress over the last couple of days, all wash ports know fitted in place port and starboard deck supports fitted and bow deck fitted.
Howard
« Reply #247 on: July 14, 2020, 11:14:35 pm »
As Always Brian looking good seeing the master piece taking place.
 I'll be copping the way you do your keels. easier and better then the way I was thinking of
              Regards Howard.
chipchase
« Reply #248 on: July 15, 2020, 08:57:39 pm »
              Regards Howard.
cheers Howard, pleased you like the keels  :-))
chipchase
« Reply #249 on: July 15, 2020, 09:14:07 pm »
Another good day today started to get Schottel's lined up
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14   Go Up
Page created in 0.032 seconds with 22 queries.
