Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Down
Author Topic: Stevns Arctic Build  (Read 98761 times)
chipchase
Re: Stevns Arctic Build
« Reply #325 on: December 09, 2020, 11:01:04 pm »
Another three photos showing the port side of my Arctic build this is the second coat of primer. A couple of places  still needs a bit more rubbing down.
chipchase
« Reply #326 on: December 10, 2020, 05:53:54 pm »
Good day today, got the brass delivered and made a start on the bollards
chipchase
« Reply #327 on: December 10, 2020, 06:50:09 pm »
Another couple of photos showing the bollards and first coat of primer.
Howard
« Reply #328 on: December 10, 2020, 07:01:55 pm »
Hello Brian,
 A very nice bit of detail work you're a standard I aim to try and get to.
 I love how you have curved them inwards shows your attention to detail which makes a big differences  thank you for showing and sharing your skills with us.
         Regards Howard.
chipchase
« Reply #329 on: December 10, 2020, 09:05:36 pm »
Hi Howard as you know I like to try and a make the model as near to the real vessel as possible, that's only achievable if you have access to lots of good photos. The only photos that I have are ones that I found on the internet.The slope on the bollards was quite easy to achieve I cut a small v shape into the bollard then bent to the angle I needed then filled with solder. here are a couple of photos, the bollard is just pushed into place at the moment.
Brian
« Reply #330 on: December 10, 2020, 09:28:16 pm »
Chip....those solid Bollards look good :-)) ......are they tapped M3 from underneath?
My real question.......with 20+kg pushing along, is there any thought of some sort of metal [brass] protection U angle plate for those vulnerable leading edges of the bow lower plate?
chipchase
« Reply #331 on: December 10, 2020, 10:04:11 pm »
Hi Derek, yes the bollards will be threaded and bolted into position, I haven't thought about fitting any reinforcement on the leading edge as I filled the inside of the keel, this normally is quite strong. To be perfectly honest by the time I get her finished I will be too old to lift her into the water  {-)
Brian
chipchase
« Reply #332 on: December 12, 2020, 06:40:41 pm »
Found some bearings so decided to make the bow thruster for my shelter deck trawler.
chipchase
« Reply #333 on: December 12, 2020, 09:44:06 pm »
A bit more progress on the thruster
chipchase
« Reply #334 on: December 13, 2020, 10:58:41 am »
Coupled the motor up and running great, hole cut in bow for the thruster.
chipchase
« Reply #335 on: December 13, 2020, 11:27:46 pm »
Thats the bow thruster finished all I have to do know is fit it into the hull  :-))
chipchase
« Reply #336 on: December 19, 2020, 11:10:15 pm »
I haven't done much on the Stevns since I started doing some work on the Our Lass but managed together the top coat on the bollards.
Taranis
  • Balne Moor MBC
« Reply #337 on: December 19, 2020, 11:21:55 pm »
Lovely parts and an interesting shade of green  :-)
ANDY
chipchase
« Reply #338 on: January 15, 2021, 08:27:30 pm »
Know that the trawler is up to a stage in the build that I am happy to put to one side for the moment I am going to do a bit more on the Arctic build.
While working on the trawler i kept looking at the anchor outlets on the tug they did not look right, I have decided that they need to be made slightly bigger, this will keep me occupied over the weekend plus I have given a bit of thought to how the big bow fender is going to be attached.
I have cut 1.5mm brass to fit into the bow bulwark, this fitment is silver soldered as it needs to be strong. the fender will be fitted with nylon inserts, these will be tapped and threaded so the fender can be fitted securely.
chipchase
« Reply #339 on: January 19, 2021, 07:07:07 pm »
Managed to make the anchor outlets a bit bigger over the last couple of days, took a bit longer than I thought due to the deck being fitted.
a lot happier with them know.
chipchase
« Reply #340 on: January 22, 2021, 09:48:07 pm »
Just a small update on the bulwark fender support plus started to make the bulwark supports, I decided to make them out of alloy.
chipchase
« Reply #341 on: January 24, 2021, 07:08:00 pm »
Couple of productive days got all the bow bulwark suports finished and fitted, starting to take shape.
chipchase
« Reply #342 on: January 24, 2021, 08:47:24 pm »
Another couple of photos from the last couple of days progress
chipchase
« Reply #343 on: January 28, 2021, 07:29:17 pm »
Hi all another good couple of days, all  the alloy bulwark supports made and securely fitted 62 in total. She is starting to look like the
STEVENS ARCTIC know.
towrope
« Reply #344 on: January 28, 2021, 09:24:03 pm »
Looking good Brian bet that was a painful chore and you will be glad that you have finished the supports
                                    stay safe and all the best Tom
chipchase
« Reply #345 on: January 28, 2021, 09:41:10 pm »
Cheers Tom  :-))
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Up
