Pages: 1 [2] 3 4   Go Down
Author Topic: HMS LIVERPOOL BUILD  (Read 29070 times)
David gray
Re: HMS LIVERPOOL BUILD
« Reply #25 on: July 07, 2019, 08:01:00 pm »
some more pics
« Reply #26 on: July 07, 2019, 09:12:53 pm »
Outstanding workmanship. I take my hat off. Well done.  :-))
littoralcombat
« Reply #27 on: July 12, 2019, 03:50:07 am »
Great build David, keep the pictures coming.
Nige
« Reply #28 on: July 12, 2019, 10:27:26 pm »
Amen. I love the detail and brasswork. It is first rate like Radio Joe's warship models and numerous others here.
« Reply #29 on: July 12, 2019, 10:37:16 pm »
If we didn't know it was a model, and there were no distractions in the background, it would appear to be the real thing - fantastic workmanship, most inspiring  :-))
newbe7
« Reply #30 on: July 14, 2019, 12:25:54 pm »
WOW the detail blows me away you do great work .
Rck
David gray
« Reply #31 on: July 15, 2019, 09:12:15 pm »
Thanks for all your comments, wish the pictures where a bit better
I am using an old camera so the files aren’t to big
Regards David
Just the front domes and radar to make  and Ariels to to add and this part is
Finished
David gray
« Reply #32 on: November 10, 2019, 05:13:20 pm »
just about finished the upper structure now,  Started to detail the lower structure , quite a bit of work fitting the hand rails and awning
rail used 0.3 brass wire for this. still a lot more detail to add before painting , also a geared motor to add for the 1022 radar
here are a few pics
David gray
« Reply #33 on: November 10, 2019, 05:17:49 pm »
more pics
David gray
« Reply #34 on: November 10, 2019, 05:19:40 pm »
more pics
« Reply #35 on: November 10, 2019, 07:09:01 pm »
Fabulous detailing on your superstructure - very realistic.
Curiosity has got the better of me David, what is that 'pewter' looking object on the base of the radar?
David gray
« Reply #36 on: November 10, 2019, 09:08:56 pm »
Hello Ray it's suppose to a R A S  ( refueling at sea ) nozzle head , I bought this from fleetscale and it's supposed to be 1/96 scale but it looks to big
I have since removed it
Regards David
« Reply #37 on: November 10, 2019, 09:19:34 pm »
Ah yes, I see that now, at first I thought it was the torso of a knight in armour  {-) .
Yeah, definitely over scale for the RAS connection.
Thanks for the update...
« Reply #38 on: November 11, 2019, 01:15:56 am »
David...our RAN vessels use US compatible RAS ship receival connections for obvious reasons....[like a US refueler embarked with a US/RAN Naval exercise]
You may find all Countries aligned with NATO have their Naval vessels similarily equipped?...or taking it further, any Countries [vessels]  currently aligned with the US Government Policy........Japan, The Phillipines, Vietnam?.....the list is mindless
The RAS hosed themselves are 4" bore, so the connection mouthpiece [lighweight non-corrosive stainless alloy] would be a nominal say ~~ 5" convoluted  OD max
« Reply #39 on: November 11, 2019, 06:15:27 am »
Just watched a video of our two new RAN refuellers.........the RAS hoses appear far larger than the 4" bore I suggested earlier...
  :embarrassed:  things sure have changed over 32 years since I stepped onboard such vessels
https://www.google.com/url?sa=i&source=images&cd=&ved=0ahUKEwjpx8f5vuHlAhWHV30KHXxwD4IQMwhIKAAwAA&url=https%3A%2F%2Fwww.navy.gov.au%2Fsupply-class-aor&psig=AOvVaw3607Inoqqv4kFOtQ3PfjCz&ust=1573538797386266&ictx=3&uact=3
« Reply #40 on: November 11, 2019, 06:48:21 am »
Couldn't let it go without an answer  %)
https://www.amdefencemarine.co.uk/what-we-do/defence/assault-courses/
MIL- Spec RAS hoses range from 64 to 153 mm diameter  :P
[When you back-check this, you will see that these Standards also apply to your RN]
With separate classifications to me
frogman3
« Reply #41 on: November 11, 2019, 10:14:57 am »
HI David just been lookin at your build an very nice detailed an just wondered wheather you have your hull yet from sirmar ?
chris
David gray
« Reply #42 on: November 11, 2019, 11:32:23 am »
Hi Chris yes I didn’t have the hull when I started the superstructure so I have decided to build both structures before I start the hull
I have all the fittings and running gear also
It’s taking  longer than it should because I am having to
Work a lot from photos to build the latest version of her
The jebinco plans are the Bly for the the 1983 version
littoralcombat
« Reply #43 on: November 12, 2019, 11:02:39 am »
Coming along nicely David, following this build closely.
May I ask what you have used for the plastic coated wire removable handrails, such as those adjacent to the RAS station on the 1022 stump mast. Very realistic!
Nige
David gray
« Reply #44 on: November 12, 2019, 08:49:18 pm »
Hi Nige I used 0.5mm brass wire for the fixed railings and 0.3 brass wire for the black platinum coated ones
Regards David
David gray
« Reply #45 on: February 01, 2020, 05:36:09 pm »
painted the lower structure and attached the the upper structure started adding the rest of the detail
David gray
« Reply #46 on: February 01, 2020, 05:40:27 pm »
more phots
David gray
« Reply #47 on: February 01, 2020, 05:46:03 pm »
more pics
David gray
« Reply #48 on: February 01, 2020, 05:53:29 pm »
more photos
David gray
« Reply #49 on: February 01, 2020, 05:56:43 pm »
mm
Pages: 1 [2] 3 4   Go Up
