Author Topic: tidy workshops  (Read 5253 times)
tidy workshops
« on: March 23, 2018, 11:35:30 am »
I learned a lesson yesterday, on tidiness in the workshop.
a good member on here, nemesis messaged me a few days ago regarding "bendy" copper tubing in the shape/form of brake fluid piping for motorcars and that this would have been a solution to the rear roll bar on my little Atlantic 21 rib that  have been resurrecting instead of a] trying to heat and bend plastic tubing, and b] also brass tubing which I had to anneal with heat. To which I said what a brilliant idea and I'd use that on any future project, and thanked Bill for his help and input.
if only I had kept a tidy workshop, I might have known that I had a small length that must have been given me some long time ago and was hung on a hook behind a box covering the lathe.......but now that I know, I'll know to use that and more, next time I need to create a mast for a lifeboat or similar vessel.
moral is............don't be a slob, and keep your workshop tidy. <*< >>:-( >>:-( <:(
Re: tidy workshops
« Reply #1 on: March 23, 2018, 11:38:54 am »
A great tip I read, probably on here.
Every time you go into the workshop, put 10 things away before you start work.
david48
Re: tidy workshops
« Reply #2 on: March 23, 2018, 11:43:12 am »
I saw this heading ,and immediately thought are we all going to have a snap inspection of our workshops / sheds  if so I am in dead trouble ,just been looking do not know where to begin !!!!!!!!
David
Re: tidy workshops
« Reply #3 on: March 23, 2018, 11:44:11 am »
good one TT............... I'll put that into practice forthwith...............might even find my other chuck key..........in a month or two........that's how bad it is, lol.
grendel
Re: tidy workshops
« Reply #4 on: March 23, 2018, 12:27:00 pm »
I try and keep a section of the workbench clear for any quick jobs, but generally have to tidy a section for any bigger jobs.
Brian60
Re: tidy workshops
« Reply #5 on: March 23, 2018, 12:43:03 pm »
I do this every day before beginning any work. It might be one item or tool or 20. I can't begin work when the area is sloppy. So anything not put away when I last finished, gets put away before I begin - some might call it OCD, but its really much easier to work in a clean environment than a cluttered one..
Re: tidy workshops
« Reply #6 on: March 23, 2018, 02:11:39 pm »
... you can't model properly if everything is laid out logically.... need to work from memory!   %)
Bob K
  • Bob K
Re: tidy workshops
« Reply #7 on: March 23, 2018, 02:55:53 pm »
in my workshop everything is laid out in geological order, latest-used strata at the top, not used for ages lower down in the pile.  Therefore quick-drying assemblies are at the top whilst drying, 24 hour stuff may be underneath.  I know where everything is, based on when and where I last used it.
Occasionally, at key build stages, I do a major tidy up.  Surprisingly it then takes ages to find out where things have gone to, so I try not to tidy too often.
Working in a very limited space makes a "clean desk" almost impossible without getting rid of all the boats.
nemesis
Re: tidy workshops
« Reply #8 on: March 23, 2018, 03:08:11 pm »
put all your tools away and tidy up before starting work, fine. Half hour later the bench is as it was before tidying up. Been there. nemesis
Mark T
Re: tidy workshops
« Reply #9 on: March 23, 2018, 03:14:51 pm »
Mines ultra tidy - but you know that already because of the flack I received for being too tidy  %% {-) :embarrassed:
nemesis
Re: tidy workshops
« Reply #10 on: March 23, 2018, 03:31:32 pm »
Talk about being tidy, I visited a modeller some years back to find him about to file a piece of metal. Took out a file, a few passes then put the file away, measured up, got the file out again, a few more passes, put the file away again and measured again. Believe it or not this went on for ages but he was tidy, nemesis
Re: tidy workshops
« Reply #11 on: March 23, 2018, 03:43:55 pm »
Fred Ellis
nemesis
Re: tidy workshops
« Reply #13 on: March 23, 2018, 04:30:04 pm »
A thing of beauty is a joy forever. nemesis
Re: tidy workshops
« Reply #14 on: March 23, 2018, 04:40:48 pm »
This is my tool box....
https://en.wikipedia.org/wiki/Henry_O._Studley
I can only dream of a tool box like that............even my grand dads wasn't that well furnished.........and he had a lot, lol. %% %%
Howard
Re: tidy workshops
« Reply #15 on: March 23, 2018, 08:13:33 pm »
Martin I can see your nose growing the hour we'll not have to look out for one of the shirts if you keep telling porky-pies like that lol {-)
                           regards Howard.
carlmt
    • Linkspan Models
Re: tidy workshops
« Reply #16 on: March 23, 2018, 08:48:58 pm »
David
You and me both David!!!
I am lucky if I can see the colour of the carpet for sanding dust, sawdust, resin flash etc.  And as for workspace - I really need to sort the place out!!1
Trouble is, there are a lot of motorbike and Jaguar spares in there as well - I need to sort one of my sheds out first to transfer the spares out of the workshop....then I can find space to be tidy!!!!
One day...................
Re: tidy workshops
« Reply #17 on: March 23, 2018, 09:30:39 pm »
I have a few rules including:
The Chuck key for the drill lives on top held in place by a block of magnet.
Lathe tools live in a drawer unit I made at school for GCSE.
Lathe chucks live in an old metal drawer.
Needle files always go in a block holder I made for them at the end of a session of work. At home all my tools live in a block holder I made when I moved into my first home to keep them tidy.
I keep my collection of materials to a minimum by replacing the cereal packet card every time I empty a box thus keeping the supply fresh and as large as possible, Wood is retained if it of sensible length dependant on ease of supply and value. I keep all my chemiwood unless it is too raggedy a shape or too out of true to get a useable piece from. Paints, resins etc generally live in a cupboard but do migrate and need periodic corralling and putting away.
I do recommend making a tool block or buying desk tidies. The latter may not be practical for odd tools like pliers or big- wide tools, so a tool block will allow you to control and maximise storage.
Re: tidy workshops
« Reply #18 on: March 23, 2018, 09:51:31 pm »
Mine is tidy for all of 30 secs then this chap called Stavros starts to work in there and all hell breaks loose
Mind you I did clear it a week ago and I FOUND 3 CHUCK KEYS.......I just wonder is one of them is Neil's
BrianB6
Re: tidy workshops
« Reply #19 on: March 23, 2018, 10:20:35 pm »
NEVER let a daughter into your workshop unattended. >>:-(
Ours not only tidied up but threw out all the old paint tins and other "rubbish" when she thought I was not looking. <:(
Mind you, I am not allowed to touch anything in my wifes studio.  :embarrassed:
Re: tidy workshops
« Reply #20 on: March 24, 2018, 07:19:44 pm »
Hm. That was a bad thing (Well intended) but bad  >:-o
Rottweiler
Re: tidy workshops
« Reply #21 on: March 24, 2018, 08:21:30 pm »
yeh yeh! They look unused and in mint condition matey!
Mick F O0 O0 O0 :-))
PS I cant find my tools to take a photo of them!
Re: tidy workshops
« Reply #22 on: March 24, 2018, 10:21:05 pm »
Click on the reference below the photograph for some interesting information about this toolbox. O0
Page created in 0.869 seconds with 21 queries.
