Author Topic: 34" glassfibre Huntsman  (Read 1156 times)
shadysadie
« on: March 31, 2018, 05:44:37 PM »
A question please for the brushless gurus. I would very much like to convert my old 34" Precedent Huntsman (glassfibre hull) to brushless power and have a spare Turnigy 36-39 1100kv outrunner and 60A ESC.. Would this motor be too powerful running on 3s LiPos with an appropriate prop.? I would prefer to use the 3s batteries which I already have to save on expenses.
ChrisF
Re: 34" glassfibre Huntsman
« Reply #1 on: April 02, 2018, 12:21:45 AM »
From what I've gleaned about brushless motors the kv is a little on the high side but not manically so and so is quite a good choice for the Huntsman.
You don't have to use full throttle! And using the 3S on lower throttle settings should give you longer run times.
Chris
Concentrating in the main, on the fine Fairey Marine boats, which is plenty for me to get on with!
imsinking
« Reply #2 on: April 02, 2018, 12:52:25 AM »
I'm currently running a Thumper V3 3530 / 14 1100Kv outrunner & its fine on a 40x prop, sounds good too , check my Fantasy Huntress in this section . .
Bill
shadysadie
« Reply #3 on: April 02, 2018, 09:25:04 AM »
Many thanks for the advice folks - sounds feasible so I'll give it a go!
canabus
« Reply #4 on: April 02, 2018, 10:34:22 AM »
Hi Shadysadie
 I am running a 3648-1450kv on 3S with a 60Amp ESC and a 2 blade 40mm CNC prop.
I was going to put a 3639-1100kv in my 34" Huntsman, but, I had a spare 1450kv.
The boat handles either motor and will zip along very well.
Canabus
shadysadie
« Reply #5 on: April 02, 2018, 12:44:46 PM »
Thanks canabus, I also have a spare 60A car ESC so it looks like all systems go!
canabus
« Reply #6 on: April 02, 2018, 01:56:02 PM »
Hi Shadysadie
If the ESC is the Hobbyking HK-60A SL and you have the program card.
I can post the settings we use for it.
The only setting we change after that, is if you go to 4S.
Canabus
shadysadie
« Reply #7 on: April 02, 2018, 03:41:50 PM »
Hi canabus.
My ESC is the Hobbyking HK-60A "QUIK" series with reverse. I have the program card and I will not be going above 3S but is this a different ESC to the SL?
Thanks, David.
canabus
« Reply #8 on: April 03, 2018, 12:27:03 AM »
Hi Shadysadie
The "Quik series" are different to the Hobbyking HK series.
The 60 Amp (part Number HK-60A SL) with handle 2-4S batteries.
Also the HK 45 and 100 use the same program card.
I think the 30 Amp would , but, I have not used one.
Our club guys use the same ESC and have had no problems with them.
Canabus
