does that only really apply to nickel type batteries?
No, I had a friend that used to run a Blueback RC submarine model.
I missed the two different times that this occured, but this was the sequence...
He had a sealed gell cell battery in the watertight compartment of the submarine.
He could charge it by pluging into the box via receptors he had built in.
After several years of running, he placed a new battery into the boat, and sealed it back up and
then charged for the next day. When he got out to the pond, he switched on his radio then
the boat, and sailed off. When he activated the motor to flood the tanks, apparently there was
a large thud, and a huge volume of water was thrown into the air, and his sub sank.
He recovered and and spent a couple weeks to repair the submarine. The water tight chamber had
blown open, So once he repaired that, he put everything back in its proper place and went back out to
the pond... Switch on transmitter, boat, sail off, switch to flood the boat, and Boom,,, another catastrophic
explosion and sinking. ....
Turns out that charging a brand new battery in a sealed water tight compartment fills the compartment with
hydrogen gas. ::) The submarines motor that ran the lead screws for the ballast plungers had brushes that
arc'd when run. Hydrogen gas,... sparky motor... Boom!!
Best to charge the batterys where they can air a bit...
