Author Topic: Replacement Switch?  (Read 3022 times)
Replacement Switch?
« on: May 03, 2018, 11:26:28 pm »
Got to replace this switch,  DPDT  ..... where do I get one / three?
Closest match as possible.
( Power switch for radio mic receiver box )
Re: Replacement Switch?
« Reply #1 on: May 03, 2018, 11:33:46 pm »
Pop this into Google "alpha dpdt switch"
  - there's quite a choice  :o
grendel
C-3PO
« Reply #3 on: May 04, 2018, 07:01:19 am »
https://www.mouser.co.uk/ProductDetail/Alpha-Taiwan/SP70030F-0202-13F1-01-NN?qs=sGAEpiMZZMvxtGF7dlGNprJRKGquplIEnW8MDGpdxSw%3d
https://www.mouser.co.uk/datasheet/2/13/TW-700210-1155755.pdf
If it's just contact corrosion then you can sometimes bend the lugs to open the case, get to the contacts, clean them and re-assemble or alternativley a good squirt of switch cleaner
https://www.amazon.co.uk/Super-10-switch-cleaning-lubricant/dp/B001DQ1FHM
C-3PO
« Reply #4 on: May 04, 2018, 09:54:53 am »
Similar - https://uk.rs-online.com/web/p/products/7582111/
If the insides haven't given up the ghost, a flood with contact cleaner and a few operations might bring it back to life, but obviously, if the latching mechanism is dead, its a goner.  Getting them apart is easy - it putting them back together in working condition that is the difficult bit.
« Reply #5 on: May 04, 2018, 10:35:12 am »
Thanks everyone.   How do I know the pin space is the same?
« Reply #6 on: May 04, 2018, 10:53:51 am »
Component shop
C-3PO
« Reply #7 on: May 04, 2018, 10:59:58 am »
Martin - same manufacturer - "Alpha"
I think this is exactly the same switch - if not Mouser have many other Alpha switches of this type
Data sheet gives all dimensions - https://www.mouser.co.uk/datasheet/2/13/TW-700210-1155755.pdf
C-3PO
« Reply #8 on: May 04, 2018, 12:02:23 pm »
Mouser.co.uk
Merchandise Total:  £2.92
Delivery Charge:    £12.00
Order Total:          £14.92
    .... er, NO!
C-3PO
« Reply #9 on: May 04, 2018, 12:37:02 pm »
Ouch... if you don't find an alternative I order reasonably frequently from Mouser and can add one to my order. I have never paid for FedEx shipping but my average order is £35-£50...
Just realised
Free shipping on most orders over £33 (GBP)
otherwise £12
C-3PO
grendel
« Reply #11 on: May 04, 2018, 04:03:25 pm »
terminal spacing 2.5mm not 3mm
grendel
« Reply #12 on: May 04, 2018, 04:16:08 pm »
maybe a trip into your local maplins might produce a result, at mine they now have all the components out on the shop floor at silly prices. I got a whole large reel of solder for 40% off (£13 instead of £21) its a bit pot luck now as to what they have left, but prices are at least competitive now.
« Reply #13 on: May 18, 2018, 08:35:04 pm »
Update.
Couldn't find the right switch so ordered a couple of 2.5mm pitch pin switches from fleabay.
Malcolm, I did have a go at the original switch... I don't think i can fix it!   {:-{
« Reply #14 on: May 18, 2018, 08:57:05 pm »
now maybe a bit slow here, but radio mic receivers are mains powered, the transmitters as we all know are 3 v......so chum Martin not sure what you have  {:-{  but if I bring some of my old radio mics to mayhem (sadly now after the government have taken away our frequently licences ) maybe you could butcher one :-)) :-)) :-)) :-))
