Author Topic: Antifouling paint  (Read 8512 times)
Philsy
Antifouling paint
« on: September 13, 2007, 01:34:51 pm »
Can someone suggest a paint that resembles traditional copper-based antifouling, please?
Phil
Bryan Young
Re: Antifouling paint
« Reply #1 on: September 13, 2007, 11:07:33 pm »
Phil
Standard red oxide does the job for me.
Notes from a simple seaman
cdsc123
« Reply #2 on: September 13, 2007, 11:31:58 pm »
Go adding black gloss to red undercoat until the desired sheen and shade are achieved.
The old International copper-base antifoulings were a plum colour prior to launch, after a while in the water the areas underwater would darken and the waterline areas would develop a greenish tinge.
Red oxide primer does work quite well, it is a little too matt and a litttle too bright though for my liking.
Philsy
« Reply #3 on: September 14, 2007, 08:26:38 am »
Thanks for the replies. This is for a working model, so I guess I would need a sealer over the primer?
« Reply #4 on: September 14, 2007, 08:32:13 am »
With Halford's red oxide primer it doesn't seem to need a sealer but putting a matt or semi matt varnish over the top will address cdsc123's point and provide a bit of extra protection as well.
Bunkerbarge
« Reply #5 on: September 14, 2007, 08:33:02 am »
Two of my models have got nothing more than Halfords Red Primer on the bottom of the hull and they both are in perfect condition.  I wouldn't bother putting anything else over it unless, as Colin says, you feel the need for a bit of extra protection.
Philsy
« Reply #6 on: September 14, 2007, 08:34:54 am »
Thanks, I'll give it a try.
Phil
« Reply #7 on: September 14, 2007, 06:25:59 pm »
Right then Colin Bishop and  Bunkerbridge point of info on PRIMER If it is a plastic hull then there is no problem BUT if it is a wooden hull then it needs sealing this is due to the fact that ALL primers are POROUS
« Reply #8 on: September 14, 2007, 06:47:08 pm »
Stavros, I usually use it on a wooden hull that has already been sealed, either with sanding sealer or my favourite gumstrip/shellac so the primer just acts as a colour coat. But, point taken. Thanks.
« Reply #9 on: September 14, 2007, 08:25:52 pm »
Bets thing to do Colin is to seal it with Matt varnish then Definatly no worries
« Reply #10 on: September 14, 2007, 08:36:43 pm »
Which varnish do you recommend Stavros? I'm thinking Ronseal interior. Wouldn't want to put Plasticote over Halfords.
« Reply #11 on: September 14, 2007, 08:42:46 pm »
Would personnaly use exterior as I dont think the interior is waterproof
« Reply #12 on: September 14, 2007, 09:15:06 pm »
The problem with Ronseal polyurethane exterior varnish (and most others of the type) is that it contains UV filtering agents and therefore has a distinct yellowish cast which alters the colour of the underlying finish, the interior also affects the underlying colour but much less so unless you apply it over white. The interior variety is supposed to be proof against boiling water, weak acids, chemicals etc. etc., and many modellers swear by it. I think it can be regarded as waterproof for all practical purposes.
The quick drying acrylic stuff gives a more transparent finish but can go cloudy if immersed in water which suggests it is absorbant.
« Reply #13 on: September 14, 2007, 10:09:44 pm »
I use Ronseal Matcoat.
Does say on the tin not to use in bathrooms or kitchens, but been using it now for over 12 yrs and nothing happened so far.
I usually give 2 thin coats though.
Ghost in the shell
« Reply #14 on: September 14, 2007, 11:50:32 pm »
thats whats on my Najade :) halfords top paint, plasticote clear acrylic.
Go Nuclear!  you'll love it
« Reply #15 on: September 15, 2007, 12:13:35 am »
That's interesting Ghost, how long did you leave the Halfords to cure before applying the Plasticote varnish? I don't think the solvents like each other much.
« Reply #16 on: September 15, 2007, 05:13:54 pm »
What really tickles me here is why on earth does everyone mix paint systems up,why buy Halfords Acrylic paint then put an Enamel over it, the mind boggles,if you now scratch the boat and want to touch it up you now cant,it's a major repaint
Ghost in the shell
« Reply #17 on: September 15, 2007, 06:02:40 pm »
about a couple of hours.
i did say Plasticote CLEAR ACRYLIC :)
oh she has been touched up, using little tinlets of plasticote silver.
Ghost in the shell
« Reply #18 on: September 15, 2007, 06:05:22 pm »
...to ensure everything worked well, I did spray a piece of scrap ABS with the desired mix, seemed to work well so that was used on the main hull
« Reply #19 on: September 15, 2007, 06:47:10 pm »
But you see Ghost you are missing the point why use different makes of paint,Plasticoat gives a very poor finish in comparsion to Halfords laquer,at least with Halfords product if you get a run or the shine is poor you can Tcut the shine back wiht Plasticoat you can't
« Reply #20 on: September 15, 2007, 06:51:02 pm »
The thing that put me off using the Halfords transparent lacquer is that it's intended to be gloss - fine for the car but not for my boats.
« Reply #21 on: September 15, 2007, 06:53:57 pm »
But Halfords do a semi gloss laquer as well
« Reply #22 on: September 15, 2007, 06:55:43 pm »
if you spray the laquer on and it's too shiny either T Cut it and dont polish it or Rub down with 2000 grit and cut back with Farecla and you will gte a dullish finish
« Reply #23 on: September 15, 2007, 07:06:20 pm »
I've not seen the semigloss - if I find some I'll give it a try. Not keen on rubbing down to dull the finish, too much like hard work and, being me, the result would be an uneven degree of gloss.
Sub driver
« Reply #24 on: September 15, 2007, 07:14:48 pm »
Hello, This may be a strange question But have you thought about buying some Humbrol clear cote Matt varnish and spraying that on, it will give you exactly the result you are after ?  :)
Page created in 0.042 seconds with 21 queries.
