The Shipyard ( Dry Dock ): Builds & Questions > Yachts and Sail
Mast Length?
Brian60:
As my main build ground to a halt, I returned to my pond yacht which has been consigned to a cupboard top for 5 months :embarrassed: :embarrassed:
The hull is completed but the plan I was working from had no details on mast length, its only a pond yacht so nothing has to be specific or exact, not as though its entering any competitions :} So the question is, is there a length of hull to mast height ratio to work at or is it down to 'it looks right so it ok?'
I did see someplace that a rule of thumb is hull length plus a third more. I've done that but it looks way too tall for this hull. Its 22 inches long, so I made the mast 32 inches. It looks better at 27 inches, but before I go pruning I'd like an idea to work to please.
tigertiger:
If you have the plans, is there a sail plan, from which you can glean some ideas. For example, if the bottom part of the mainsail is shown, you could extend the lines, then add a bit for the up-haul halyard. Or any lines from the fore stay or back stay.
You could also get some ideas of scale of you do a photo search on google, if you know the name of the model. Or a rough idea of ratios by looking at photos of other pond yachts. When comparing photos, you should also compare keel types, some have small keels and relatively short masts. Others long keels and long masts.
Other than that, the rest of your thinking seems logical. If the mast is too tall, you will carry to much canvas and the boat may heel more than you want it too.
exvtop:
The Micro Magic is 21 inches long and mast height of the main rig is 29 and a half inches.
Should think 29 to 30 inches for yours would be about right.
KitS:
My Minimum has a 31" hull length and its 1M storm suit mast is 41" tall, so that's a 1:1.3 ratio.
In truth it's a tad undersailed for light winds, viz being stuck in the middle of the lake at Wicksteed y'day for some time, but it works most days.
Brian60:
OK thanks for the replies you guys. Sadly it was just a set of frame lines with no other info, not even a model name. I have seen similar while searching google. I did some time ago start a build log in the yacht section above, as per that you will see it has a shallow but long and bulbous keel. I think it may have just been drawn by someone as a 'suck it and see' idea.
Looking at the length of the mast and the amount of lead I could get into the keel I reckon it may be prone to capsizing in any but the lightest of winds. I think I may even cut off the keel and make it deeper.
Navigation
[0] Message Index
[#] Next page
Go to full version
