Author Topic: HiTEC 785HB  (Read 2926 times)
rnli12
HiTEC 785HB
« on: June 29, 2018, 12:44:27 pm »
Does anyone know if the length of travel can be adjusted on the sail winch or is a best via the transmitter?
tsenecal
Re: HiTEC 785HB
« Reply #1 on: June 29, 2018, 03:09:31 pm »
i have three of these... the only method i know of to adjust is via transmitter EPA.  it is NOT a digital servo, and offers NO programability directly.   this also means that once you have the EPA set, you will definitely want to set up fail-safe settings so that loss of radio signal doesn't tear stuff apart.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HiTEC 785HB
« Reply #2 on: June 30, 2018, 12:04:47 am »
Or a servo stretcher for "dumb" transmitters.
mickkays
  • up spirits
Re: HiTEC 785HB
« Reply #3 on: July 25, 2018, 05:07:57 pm »
Have you looked at a servo morph from action electronics ( about £18), It certainly does the job but you need the space in your boat to fit it.
Slinger
LME Slinger
Re: HiTEC 785HB
« Reply #4 on: July 26, 2018, 03:18:53 am »
How to get up to eight and a half turns, https://www.youtube.com/watch?v=OaRFgXzupFA, using Arduino or other microprocessor.
If you are using it for a sail boat, and you only need a moderate increase in sail sheet travel, consider using a larger drum.
For example, a 4cm diameter drum will wind approx. 12.5 cm of line per full rotation, a 5cm diameter drum would wind almost 20cm per rotation, and a 6cm drum would wind 28cm. However, the larger the drum, the more torque needed.
Page created in 0.018 seconds with 22 queries.
