Author Topic: Making things work without the use of servo's  (Read 3978 times)
cabinboy
« on: September 16, 2007, 03:09:11 pm »
Hello me hearty’s,
I have bought a model tug and need to make something’s work, as I have never attempted any electrics can you help.
I want to get the radar and navigation lights to work from the receiver without using a servo to operate the switches can this bee done and how? Hope you can help.
cabinboy
 O0
FullLeatherJacket
Re: Making things work without the use of servo's
« Reply #1 on: September 16, 2007, 04:46:04 pm »
CabinBoy
This is one possible solution. It will operate both of the functions you mentioned from one channel. Please see the Mayhem Trader's Directory or send me a Private Message for details of the website.
Works for me - but then I do make the things!!
Suit yourself.
FLJ  ;)
Telstar
« Reply #2 on: September 16, 2007, 05:00:44 pm »
Hi .
It depends how many channels you want to use, and how much money!!
ACTion (see elswhere on mayhem) used to do a multichannel switcher unit that went on the rudder channel of your RC and could be used to switch on and off more than one item independently ( up to 8 items I think) only downside I could see was a slight delay on rudder response (should be no problem with most scale models), perhaps F L J can give an update on that.
Alternatively I have been using a fair copy of a circuit from
 http://www.keirle8122.fsnet.co.uk/   modified to give me two isolated switch (relay ) outputs from a 'spare' channel on my 6channel RC
The components cost pence at Maplins, the most expensive item I bought being the servo plug and lead.
For the radar I have a home build circuit that starts the radar scanner when I 'start' the drive (propulsion) motor, and has a delay on switch off so the radar doesn't start stop when maneuvering/ going astern(backwards) but after not using engine for a while (adjustable up to about 1.5 min) the radar then stops
I know this is not how the purists would have it but I build my models for me not for others
Hope this is some help
Tom
ps I have no association with F L J  :angel:
While I wrote this F L J posted
FullLeatherJacket
« Reply #3 on: September 16, 2007, 05:35:02 pm »
Certainly can, Tom. It's called the Quadswitch and will operate four separate circuits from one channel. It doesn't have to be connected to the rudder channel, either - it's quite happy with its own dedicated little slot, if you have a spare one. However, CabinBoy only mentioned two functions and I didn't want to frighten him away!
FLJ  8)
cabinboy
« Reply #4 on: September 17, 2007, 04:50:46 pm »
Thanks for the replies I have sent FLJ aprivate message, anyone who wishes to help me and give detailed instructions on how to set things up please send me a private message.
Many thanks
Cabinboy O0
Guy Bagley
« Reply #5 on: September 17, 2007, 05:17:37 pm »
whilst on this subject can FLJ enlighten me-
 re the quadswitch, what sort of current /voltage can the quadswitch handle ?
 thanks...
FullLeatherJacket
« Reply #6 on: September 17, 2007, 08:41:14 pm »
Guy
PM on its way.
FLJ
Subculture
    • Dive-in to Model submarines
« Reply #7 on: September 17, 2007, 09:46:26 pm »
Sorry it's in German, but this site has some really neat little switchers that use microcontrollers and mosfets-
http://www.scaleship.de/shop/category_14/Schaltbausteine.html?shop_param=cid%3D14%26
They're tiny little units, not much bigger than the servo plug, and they work very well indeed- ideal for switching lights and radar units.
Cheap too.
Page created in 0.06 seconds with 21 queries.
