Technical, Techniques, Hints, and Tips > Engineering Techniques and Materials.
Sealing around prop shaft outer tube
Baldrick:
I think it depends on the manner in which the prop shaft sleeve exits the hull. If it is a neat round hole through the stern post a bit of tape around the orifice and then stand the boat upright and pour in a bit of epoxy resin. If it is a long angled slash through the keel then I like to build up a shroud around the tube and hull to be faired in when set then a bandage of resin and tape over the inside to encapsulate the wound.
Gardener:
nemesis:
If it is a brass outer tube make sure that you really rough it up as brass and resin do not like each other. So you are depending on a mechanical key. nemesis
Gardener:
:-)) Thanks
Navigation
[0] Message Index
[*] Previous page
Go to full version
