Author Topic: Summer sailing with m/s Visby  (Read 4441 times)
hama
« on: August 08, 2018, 10:00:48 pm »
Hello!
Away for a week on holiday and brought my model ferry to a new environment.
More pics and videos will follow...
All the best!
Hama
hama
Re: Summer sailing with m/s Visby
« Reply #1 on: August 08, 2018, 10:05:57 pm »
She broke her moorings during photo shoot and a greater power intervened! {-)
Dreadnought
« Reply #2 on: August 09, 2018, 01:47:52 am »
The two pictures at the top look real!  :-))
steve mahoney
« Reply #3 on: August 09, 2018, 07:47:42 am »
Seeing it beside your hand to give it some scale makes your work even more impressive.
Tafelspitz
  • Model Boat Bedlam
« Reply #4 on: August 09, 2018, 12:03:29 pm »
Very impressive indeed. Very much like the real deal. Looks just like you could just motor on board!
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
hama
« Reply #5 on: August 09, 2018, 05:40:28 pm »
Thanks all of you!
Here is another one and a pic of my "travel kit"!
All the best
Hama
« Reply #6 on: August 10, 2018, 01:40:16 am »
Another nice example of a model jetty. :-))
hama
« Reply #7 on: August 10, 2018, 08:29:41 pm »
Thanks!   :-))
Hama
hama
« Reply #8 on: August 10, 2018, 09:46:48 pm »
The m/s Visby has been in service for some time now and the first issue occurred the other day. The forward ramp wouldn't close properly and I thought it was because the wooden structure had expanded due to high temp and moisture. When I tried to fix it using a file I managed to break the eyelet on the pushrod connection on the visor...I then realised that the problem with the ramp was in fact rust! The pin for the hinges on the ramp had rusted ( no:2 )and got stuck and therefore broke loose one of the hinges ( no:1 ) making the ramp close twisted. So now I had two problems to fix, and away from home!
hama
« Reply #9 on: August 10, 2018, 09:58:56 pm »
Using what I could find I set out to fix the faults. First I put some rust solvent on the rod and carefully knocked it out.
hama
« Reply #10 on: August 10, 2018, 10:00:41 pm »
I found a piece of brass rod on a tool for cleaning nozzles on windscreen wipers that was a perfect fit for the  hinge ,and after gluing the hinge back the ramp was fixed.
hama
« Reply #11 on: August 10, 2018, 10:15:51 pm »
I then had to fix the eyelet on the visor and I have no soldering equipment where I am now. I cut a piece of isolation from an electric wire, taped it to the arm with a thin piece of masking tape and then put superglue to the whole thing making it solid. Visor fixed and everything back in working order!
Tafelspitz
  • Model Boat Bedlam
« Reply #12 on: August 11, 2018, 06:41:10 pm »
Well done! To improvise is half the art when it comes to "repair under despair"  :-))
hama
« Reply #13 on: August 11, 2018, 07:28:00 pm »
Thanks! Yes it was all good fun to try and fix it with what was available!  :-))
Here are some pictures of a somewhat rough crossing.
Hama
hama
« Reply #14 on: August 11, 2018, 07:35:31 pm »
....and here is one from a smoother crossing.
Hama
Onetenor
« Reply #15 on: August 12, 2018, 02:02:53 am »
The full size had the same problem. Nice spot where was it?
hama
« Reply #16 on: August 12, 2018, 02:07:40 pm »
Hello John!
If you mean the place I sail it's on a small island on the Swedish east coast where my father in law has a house. We usually go there on vacation and I always bring a boat or two.
All the best
Hama
hama
« Reply #17 on: August 12, 2018, 08:01:08 pm »
Onetenor
« Reply #18 on: August 13, 2018, 03:33:19 am »
Nice Hama and thanks
Page created in 0.361 seconds with 21 queries.
