Pages: 1 2 [3] 4 5 6 7   Go Down
Author Topic: HMS Clyde build  (Read 69335 times)
stuart22
Re: HMS Clyde build
« Reply #50 on: July 29, 2019, 09:07:41 pm »
Hi All did the water test this weekend and yes I have a leak, started to put weight in to get her down to water line then in it came I thought I had made a good seal round the thruster shows what thought did <:( I will have to sort this asap.
Just like to say about us modellers how some can be kind and thought full T888 gave some of his casting he made for his Clyde to help me complete my Clyde, what a kind chap he is  :-))
stuart22
Re: HMS Clyde build
« Reply #51 on: August 04, 2019, 06:47:44 am »
Thought I do some thing different a bit of sowing, so have started to do the netting round the flight deck railings and gun deck.
stuart22
Re: HMS Clyde build
« Reply #52 on: August 04, 2019, 07:12:48 pm »
Bit more done today
Re: HMS Clyde build
« Reply #53 on: August 04, 2019, 07:24:09 pm »
Patience + skills = great work.
I guess dedication also comes into it.
Looking good  O0
jonggd
  • The Fleet!
Re: HMS Clyde build
« Reply #54 on: August 04, 2019, 10:14:39 pm »
A very neat job in deed, I'm now thinking about my build and could I do the same in 1/72 scale. In the past I've always used brass etched netting, which is great but a little 2 dimensional and not as realistic as I would like. Seeing your work has me thinking, Jon
In the Dockyard...
1/128 HMS Warspite - QE Class Battleship
1/72 HMS Campbeltown - T22 Class Frigate
1/72 HMS Apollo - T12I Leander Class Frigate
1/72 HMS York - T42 Batch 3 Destroyer
On the Slipway...
1/72 HMS Duncan - T45 Destroyer
Re: HMS Clyde build
« Reply #55 on: August 04, 2019, 10:33:56 pm »
So Stuart22 says.....
"Hi All did the water test this weekend and yes I have a leak" ......yes well... a rather famous receltly built RN Aircraft Carrier developed a similar 9of [sortsl eak on early trials
You are doing a brilliant built & thread....Helipad netting rails on our FFG's always flapped in the breeze.......congratulations :-))
gingyer
Re: HMS Clyde build
« Reply #56 on: August 05, 2019, 10:36:53 am »
The netting looks good what did you use??
T888
Re: HMS Clyde build
« Reply #57 on: August 06, 2019, 05:41:05 am »
Hi Stu,
The nets looking good, this the info of the 1/48 figures I used on my HMS Clyde.Hasegawa X48-5 1/48 US Pilots and Crew Set:B
Regards David
stuart22
Re: HMS Clyde build
« Reply #58 on: August 07, 2019, 07:10:08 pm »
Thanks T888.
Gingyer I used what is called cross stitch material it comes in two scales and think the smaller one would do for a class 1/72 scale ships, the one I used is a little bit to large but not far from scale and it does look better than having brass ones.
I cut them to size then dyed them black with water based paint watered down see pictures. then stitched to the frames and will varnish them to seal.
gingyer
Re: HMS Clyde build
« Reply #59 on: August 07, 2019, 07:22:23 pm »
Looks like I might need to visit my mum and see if she still has cross stitch material.
I will need it for my very slowly moving Clyde
Fred Ellis
Re: HMS Clyde build
« Reply #60 on: August 08, 2019, 08:09:55 am »
Hi
This may be of some interest Screen Mesh Net Insect Fly Bug Mosquito Spider   it come in black or grey.
T888
Re: HMS Clyde build
« Reply #61 on: August 08, 2019, 02:20:07 pm »
Stu, may be to late, but this is a picture of the New nets that the manufactures sent me. ( But after I'd finished my model and which I've updated to the new fit). I did question if the netting would be white when fitted they said it would, but after time at sea more like and off white.
Regards David
Rob47
Re: HMS Clyde build
« Reply #62 on: August 08, 2019, 03:58:43 pm »
Mmmm Derek wonder which one that was {-) {-) {-) {-) {-) {-)
I will finish this model
stuart22
Re: HMS Clyde build
« Reply #63 on: August 08, 2019, 07:18:02 pm »
Wish I had that picture some time back, that could be achieved but still happy with what I have done although I could still do it as they are not fixed yet but its been a lot of work I shall see. I need to get other bits done for now.
this should help other Clyde builders with ideas.
raflaunches
  • The Penguins are coming!!!
Re: HMS Clyde build
« Reply #64 on: August 08, 2019, 08:31:12 pm »
Well that is a brilliant use of material I never thought of using. You’ve inspired me to scrap the etched brass items I was planning to get for my 1/72 HMS Protector project I started a few years back.
Nick B
Illegitimi non carborundum!
RST
Re: HMS Clyde build
« Reply #65 on: August 08, 2019, 08:42:08 pm »
LoL I recognised the cross stitch material straight away, used it in the past for grilles etc. I thought it looked rather good for you as it has some texture to it which outweighs the thickness of other options.
Looks great.
stuart22
Re: HMS Clyde build
« Reply #66 on: August 09, 2019, 06:50:15 pm »
Finished the railings but not fixed yet.
jonggd
  • The Fleet!
Re: HMS Clyde build
« Reply #67 on: August 09, 2019, 08:27:48 pm »
They look great, you've done a great job with the netting. Jon
In the Dockyard...
On the Slipway...
stuart22
Re: HMS Clyde build
« Reply #68 on: August 26, 2019, 07:34:03 am »
Did a bit more work on the top section, made all of the aerials, connected the radars up. its amazing how much is involved and how long it takes but that's modelling.
stuart22
Re: HMS Clyde build
« Reply #69 on: September 02, 2019, 08:57:01 pm »
 She flouts and no leaks did the ballast test this week end, this was in our pool we use for kids to have a go at shows. I feel much better now.
stuart22
Re: HMS Clyde build
« Reply #70 on: September 29, 2019, 01:53:47 pm »
Bit more detail starting to make the fuelling rig some pictures with the 1/48 figures I will be using and Sea king hele.
stuart22
Re: HMS Clyde build
« Reply #71 on: September 29, 2019, 06:55:38 pm »
These individual projects can be challenging its taken me most of the day so far.
Re: HMS Clyde build
« Reply #72 on: September 29, 2019, 07:39:49 pm »
... but the end result looks great, thereby making the effort worthwhile  :-)
stuart22
Re: HMS Clyde build
« Reply #73 on: October 07, 2019, 05:46:29 pm »
99% Finished fuel rig. just need to paint and add hose. also found a picture of the real thing.
stuart22
Re: HMS Clyde build
« Reply #74 on: October 11, 2019, 08:39:04 pm »
Have completed the refuelling rig, started to make the life rafts containers which the Clyde has 8 held on brackets in twos for quick release.
Pages: 1 2 [3] 4 5 6 7   Go Up
Page created in 0.018 seconds with 20 queries.
