Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... 35   Go Down
Author Topic: ModelsbyDesign Shannon  (Read 262709 times)
Mark T
Re: ModelsbyDesign Shannon
« Reply #275 on: October 26, 2019, 09:43:54 pm »
I tell you what - that steel mesh was worth every penny.  Looks great and also looks very true to scale too  O0
Taranis
  • Balne Moor MBC
« Reply #276 on: October 26, 2019, 09:57:42 pm »
Yes I bought a few sheets of different grades knowing I'd use it eventually but for my tug builds.
Not especially expensive and I posted it in What have you bought this week?  months back  :-))
The filter isn't exactly like for like but close enough for me  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #277 on: October 26, 2019, 11:10:13 pm »
Last photo today. Got to get ready for launch tomorrow
Managed to recreate the raised surround that is part of the cabin. Only minor detail left to add before paint
ANDY
mk1
« Reply #278 on: October 27, 2019, 06:27:29 am »
Very nicely done hope all goes well today.
Taranis
  • Balne Moor MBC
« Reply #279 on: October 27, 2019, 06:57:19 am »
Thank you John.
I've been up since 4:30 too  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #280 on: October 27, 2019, 08:31:55 pm »
Pump is now connected up and outlet fitted to coincide with an actual one on the yellow line
The pump was proven successful today
There was no noticeable evidence of water along the keel but clearly evidence of water in the suction pipe.
So it does the job without a fuss
The finished model will of course not let water in
ANDY
Taranis
  • Balne Moor MBC
« Reply #281 on: October 29, 2019, 05:34:39 pm »
Almost there
Difficult to spray with 5 colours but my filter is not fixed making it a little easier
ANDY
Taranis
  • Balne Moor MBC
« Reply #282 on: October 30, 2019, 07:44:32 pm »
My Danish friend Ole Bodker is really going to town on EXTRA details to his Speedline kit. This has lifted the bar considerably so I am myself trying a little harder even though I know my eyesight will not allow me to match his brilliance  %%  His pictures can be viewed on the Facebook group.
Meanwhile I have emphasised the details a little more on this
Primer on this highlights the grill which will simply be Orange with the flap in red.
I'm focusing on port side details for a while
Modified Speedline leftovers
I will have to scratch make the brass fittings
ANDY
Taranis
  • Balne Moor MBC
« Reply #283 on: October 31, 2019, 04:34:09 pm »
Thought I'd try this today, nothing like mixing it up to keep interested.
Some sheet I bought as a mixed bundle for stock
Mixed with 4 pieces of 1mm styrene to look like real item. PVA to create weld lines. Bolts yet to fit before primer
ANDY
Taranis
  • Balne Moor MBC
« Reply #284 on: October 31, 2019, 06:29:37 pm »
A tip for those who haven't assembled ! The side panel comes with too small an opening to fit the fitting flush so consider this early on.
It took some effort to open it out in situ.
Fitting from the back view
In position
ANDY
Taranis
  • Balne Moor MBC
« Reply #285 on: November 01, 2019, 05:20:58 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #286 on: November 01, 2019, 08:39:43 pm »
A reminder for you to buy the photo CD from Kim (all proceeds to RNLI) it really is priceless.
Using this as a guide
Bit by bit literaly recreate
I don't expect things to work out mm perfect so long as it looks plausible
ANDY
me3
« Reply #287 on: November 01, 2019, 10:23:42 pm »
Super build as usual! Just a heads up for other Shannon builders, the later boats have three sections of conduit running down the stbd side of the mast, it was a real pain to get all the cables down two! I guess it would make it easier to make the lights etc on the models easier.  Had the miss-fortune of wiring three masts for these!
Taranis
  • Balne Moor MBC
« Reply #288 on: November 01, 2019, 11:05:10 pm »
Thank you  :-)
I’m still at it tonight as it’s so engrossing when things go well
This will probably be Bridlington to stay in Yorkshire
ANDY
Taranis
  • Balne Moor MBC
« Reply #289 on: November 02, 2019, 10:12:40 am »
I had no idea how I was going to do this but this morning within 2 hrs it just evolved.
CA Styrene Brass Solder 2mm tap servo rod end and it works  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #290 on: November 02, 2019, 11:27:36 am »
The stay arm tab fitted (soldered)
First light coat of Tamiya Fine primer
Will be finished in bare metal silver
ANDY
davidefoster
« Reply #291 on: November 02, 2019, 04:38:55 pm »
I am sure you must have posted it at least once before (but I can't find it!) but how & where does one contact Kim about the CD?
Many thanks.
David.
Taranis
  • Balne Moor MBC
« Reply #292 on: November 02, 2019, 04:43:33 pm »
ANDY
Mark T
« Reply #293 on: November 02, 2019, 05:03:41 pm »
Top job on a difficult part.  I really like the way the soft solder imitates the welds something silver solder couldn't do.  Keep the photos coming  :-))
Taranis
  • Balne Moor MBC
« Reply #294 on: November 02, 2019, 05:21:34 pm »
Thanks MarK  :-)
This is my mate Ole from Denmarks work. He's pushing everyones goals !  yes it is a Speedline but he is going the extra 100 miles in detail
ANDY
davidefoster
« Reply #295 on: November 02, 2019, 09:04:27 pm »
Thanks Andy.
David.
Taranis
  • Balne Moor MBC
« Reply #296 on: November 03, 2019, 10:47:52 am »
Today I want to fill those big holes in the cabin. No not the windows {-)  the fuel fillers :-)
Incidentaly I love this drill, it's so smooth and with the aftermarket chuck very straight forwards with even the tiniest drill bits
Here I just drilled 0.8mm
Using 1.5mm styrene for the main structure and 0.75mm for the filler plate
EDIT just in time
These are the smallest bolts I can get hold of from Knupfer. They are a very snug push fit in the 0.8mm holes
ANDY
Taranis
  • Balne Moor MBC
« Reply #297 on: November 03, 2019, 05:29:34 pm »
Need another order with Knupfer for bolts
ANDY
Canterbury Coxswain
« Reply #298 on: November 03, 2019, 06:14:41 pm »
Andy,
The scratch built detail being added is really bringing your model 'to life'. Also, the build stages for the detail are allowing others to 'copy' - hence helpful to newcomers to the scratch building approach. As for the Survivors' Gantry, that is a little work of art!
Thanks for the 'promo' for the DVD of photos - two have been received and 'burnt off'. Into the Post tomorrow. Another £15 for the RNLI at Dungeness.
There will be a PM on its way to you later this evening.
Continue enjoying your build - it shows through! :-))
Kim
Taranis
  • Balne Moor MBC
« Reply #299 on: November 03, 2019, 06:41:21 pm »
Thank you Kim
Yes I'm really enjoying developing ways to do things, it just seems to happen for me  {-)
NOTE for CD buyers. Be sure to transfer the folders to your PC hard drive. They will view much faster from there than from a CD
Not sure how I'll make the filler caps yet tho  %%
I started this morning with the intention of copying a surplus Speedline fuel filler but as soon as I referred to real photos I gave that idea up as they are very different
For general info, some people struggle with the Knupfer site being German but if you use Google Chrome browser it will change it all to English  :-))
Personally I pay by IBAN in euros but they do take Paypal
https://knupfer.info/shop/
ANDY
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... 35   Go Up
Page created in 0.559 seconds with 21 queries.
