Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... 35   Go Down
Author Topic: ModelsbyDesign Shannon  (Read 202265 times)
The Old Fart
Re: ModelsbyDesign Shannon
« Reply #375 on: November 20, 2019, 12:51:32 pm »
nice.
Taranis
  • Balne Moor MBC
« Reply #376 on: November 20, 2019, 06:20:53 pm »
Grab rail roses. This is my method, I made a styrene template to mark the centre punch points with an indelible pen.
I then punch the marks followed by a 1.5mm drill in a pin vice.
I then fit and superglue whilst spaced off a uniform distance.
The aftermarket CA applicators are very useful
ANDY
The Old Fart
« Reply #377 on: November 20, 2019, 06:28:10 pm »
Started my MBD today, fitted those dangley bits underneath.
Taranis
  • Balne Moor MBC
« Reply #378 on: November 20, 2019, 06:32:35 pm »
You best learn how to post pictures  O0
ANDY
Taranis
  • Balne Moor MBC
« Reply #379 on: November 20, 2019, 07:01:01 pm »
How I do my grab rail stabs Soldering
This is essential to ensure flow into the joint.
Soft soldering is not weak if done correctly and it is certainly strong enough for the job being asked of it.
I never take this below 480
End game
Beer o'clock
ANDY
RST
« Reply #380 on: November 20, 2019, 07:31:42 pm »
Ha, you do same as me pretty much though I doubt I clean -up after as good as you. I had no problem soft soldering and even using plumbers flux after 20+ years nothing corroded or fell apart -yet. Of course silver soldering is ultimately better, but horses for courses and available workshop etc. Just make sure the brass etc is clean and roughed up and cleaned after. I use clip-on heat sinks to prevent damage to plastic (or crocodile clips wrapped in wet tissue), or on balsa jigs, keep adding water to stop burning.  Whatever works!
Taranis
  • Balne Moor MBC
« Reply #381 on: November 20, 2019, 07:36:58 pm »
Far more important is having the bends and junctions in the right place before making it permanent. This is so much easier soldering in situ  O0
A complicated structure as pictured is not as weak as one solder joint rather it is as strong as its multiple joints working together.
ANDY
mk1
« Reply #382 on: November 20, 2019, 11:02:09 pm »
Hi Andy the rivets I used are just like the ones you show the only difference is they were aluminium ones. I drilled them and put a 1mm fibre optic cable in them and several cables went to 1 LED bulb. This time I am going to look at fixing a small LED into the end of the rivets.
The Old Fart
« Reply #384 on: November 21, 2019, 10:22:33 am »
They look very good. Could use the 'lighthouse' leds. Couldn't use the bright 0402 leds that Ole suggested. Leds would short out.
Taranis
  • Balne Moor MBC
« Reply #385 on: November 21, 2019, 10:24:58 am »
Very careful drilling but I'm sure we could do it  :-))
ANDY
The Old Fart
« Reply #386 on: November 21, 2019, 10:31:43 am »
The 0402 have bare contacts at either side,  will short out,
If we can find plastic ones, they will work.
Taranis
  • Balne Moor MBC
ANDY
The Old Fart
« Reply #388 on: November 21, 2019, 12:29:56 pm »
Close, prefer shape of the metal ones.
Taranis
  • Balne Moor MBC
« Reply #389 on: November 21, 2019, 06:40:44 pm »
That's the cabin sides and roof rails complete bar painting
Now the Cabin front rails
I use many tactics to enable soldering at the correct angles. It's important that the verticals are vertical regardless of the sloping deck
ANDY
ChrisH1981
« Reply #390 on: November 21, 2019, 08:20:56 pm »
Peeepo! Just to let you know im also following you on here andy! I like the first picture showing the inside of the port side wheelhouse, just the picture angle i was looking for!
Taranis
  • Balne Moor MBC
« Reply #391 on: November 21, 2019, 09:01:04 pm »
This is the best place to follow Chris. All the better quality pics are here, Facebook compresses them
I've made a 3 hole template for the next roses
10 more to make and straighten up as each one fitted.
ANDY
Taranis
  • Balne Moor MBC
« Reply #392 on: November 22, 2019, 01:44:59 pm »
I though I'd expand on my rose making
Washer located beneath to mark with pen
Centre popped
After some twizeling with 1.5mm bit
Turn over and hammer flat
Reason why they can only be fixed whilst in position
Eye up through bow railings to check upright
Will be fixed from below with a dab of stixall when all painting complete
ANDY
Canterbury Coxswain
« Reply #393 on: November 22, 2019, 02:28:19 pm »
Andy,
Your model is progressing so well and the various fixtures and fittings will give an overall great finish. What I really did like, though, was your process of making the working telecomms tower mechanism, which looks pretty scale-like and realistic, whilst at the same time robust in its operation. I might well be using the same approach - when I get there - but using my black Delrin rods milled to the shape required for a few parts. This does allow for the 'collapse' method of transport, thereby concealing the model away from prying eyes when travelling, and also be able to display it like most Shannons would be like when in their boat houses, but at the same time a quick and easy [realist] raise and lock-off if required when on display. I think a lot of folk will benefit from a lot of your ideas and processes, even if a few then make their own slight tweeks and modifications.
This Forum really does benefit from builds such as this. Keep up the good work and photography - so detailed.
Kim
Taranis
  • Balne Moor MBC
« Reply #394 on: November 22, 2019, 03:52:58 pm »
Thank you my friend  :-)
A couple of big ones
ANDY
Taranis
  • Balne Moor MBC
« Reply #395 on: November 22, 2019, 04:17:09 pm »
ANDY
The Old Fart
« Reply #396 on: November 22, 2019, 06:47:12 pm »
First attempt for deck lighting. Plastic holder.
Taranis
  • Balne Moor MBC
« Reply #397 on: November 22, 2019, 06:53:55 pm »
Got any links for the parts?  O0
ANDY
Taranis
  • Balne Moor MBC
« Reply #399 on: November 22, 2019, 08:07:35 pm »
Interesting Dave however the pictures are so blurred that it’s not obvious how you’ve done it
ANDY
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... 35   Go Up
Page created in 0.126 seconds with 21 queries.
