Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... 35   Go Down
Author Topic: ModelsbyDesign Shannon  (Read 153966 times)
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon
« Reply #425 on: November 24, 2019, 06:44:25 pm »
I meant to say that I try hard to make all parts removable. This allows fitting after cabin paintwork.
This assembly is purely located by the tight fitting grab rail
ANDY
« Reply #426 on: November 24, 2019, 08:11:29 pm »
That self draining safety gate looks superb Andy.  O0 ......in the last image below, is it a metal  finished paint to represent stainless steel construction?
The locking/unlocking working function also  :-))
Without having seen a video of this Class of vessel, I assume a few hundred kilograms of
heavy sea wave water could crash over/into with that space & so needs a speedy self draining function?
Taranis
  • Balne Moor MBC
« Reply #427 on: November 24, 2019, 08:16:13 pm »
Thanks Derek
The paint is Tamiya bare metal silver. I don't think any of the grab rails etc are stainless steel. Some say anodised steel but I'm not aware that steel can be anodised so I errr on it being aluminium
ANDY
Canterbury Coxswain
« Reply #428 on: November 24, 2019, 08:53:20 pm »
Derek and Andy,
They are all anodised aluminium [duralumin] rails throughout. Hence most [not the black] will require minimal maintenance.
I believe steel would be galvanised.
Kim
« Reply #429 on: November 24, 2019, 08:57:42 pm »
Andy....I would think that 'anodized steel' is an error in understanding metals and not a misprint   %)
......any form of electrolytic process to hard drawn aluminium tubing would look very flash O0 [for a few weeks] after that no one in their correct state of mind would try & support their life by holding it after those same few weeks of sea mist :embarrassed:
Stainless Steel Grade 316 [1.4571 is the closest Continental designation] tubing is easily bent......however requires stainless TIG welding in full size, or silver soldering in scale applications of the material to mounting flanges etc
Taranis
  • Balne Moor MBC
« Reply #430 on: November 24, 2019, 08:59:41 pm »
Derek and Andy,
Kim
My thinking exactly  :-))  thanks Kim
ANDY
« Reply #431 on: November 24, 2019, 09:05:11 pm »
Morning Kim......thanks & I understand OK if the rails are anodized Duralumin ........this chemical varient has totally different electrochemical resistance properties & hence corrosion resistance [over 99.9% aluminium]
Courtesy of a Chemical Table under Google
'In addition to aluminium, the main materials in duralumin are copper, manganese and magnesium. For instance, Duraluminium 2024 consists of 91-95% aluminium, 3.8-4.9% copper, 0.3-0.9% manganese, 1.2-1.8% magnesium, <0.5% iron, <0.5% silicon, <.0.25% zinc, <0.15% titanium, <0.10% chromium and no more than 0.15% of other elements together'
Really like chalk & cheese between the two metals...a simple test to check if the metal is aluminium or duralumin is to wipe a strong magnet over the metal......if it's duralumin you sure will feel the magnetic attraction to the manganese + iron [total ~~1.25%] in the metal
Never buy Duralumin from a second hand scrap dealer........ <*<
High strength heat treated Duralumin tubing is also used in Hang Glider tubular frames..........being of such critical importance, the tubing is sold from the Merchants with a Certificate of Tractability back to the individual heat when the metal was brewed ......genuine Duralumin tubing has the Certificate Material  Grade & Heat Number micro Laser printed on the continuous length of the tube ........such is the importance of human life  O0
me3
« Reply #432 on: November 24, 2019, 10:20:40 pm »
I believe it's just bare sand blasted aluminium. It certainly is on refit boats. On the refit boats we take the painted parts and blast the paint off them. It leaves a rough surface but then we do have different grades of blasting depending on the item.
Canterbury Coxswain
« Reply #433 on: November 24, 2019, 11:23:35 pm »
I can only go on what I have been told by by both engineers at the RNLI lifeboat stations that have Shannons and also by those at the AWL Centre at Poole when I have asked the question - it's always been 'anodised aluminium' and on one occasion 'duralumin'. I have asked this, as being an RNLI Educational Trainer for the South East [official staff - voluntary] I get asked this question frequently, by enthusiasts and modellers alike. This is especially when I give my illustrated talk on 'The launch and recovery of the Shannon Class lifeboat' - based on the Dungeness boat - up and down the country. My next one will be given in Eastbourne in March. Well before then, I will get the definitive answer from the 'top man' at the AWL Centre, Poole. It will posted here then.
Cheers to each.
Kim
me3
« Reply #434 on: November 25, 2019, 07:12:52 am »
Hi Kim, interesting, I work at the alc in Poole on the Severn, Trent and Tamar refit lines. I will ask or look at a drawing when I'm back later in the week. Whilst I can't be 100% on the Shannon the refit boats are definitely bare ally!
Taranis
  • Balne Moor MBC
« Reply #435 on: November 25, 2019, 07:06:56 pm »
Another good day
ANDY
swiftdoc
« Reply #436 on: November 25, 2019, 07:57:49 pm »
Excellent work, Andy! The mast mechanism is a source of inspiration :-)) And the gate insert is the icing on the cake!
Taranis
  • Balne Moor MBC
« Reply #437 on: November 26, 2019, 05:18:18 pm »
Thank you Arno
I have an ear infection so not very focused on production today.
So some pictures under the influence of Ibuprofen
102 bolts
ANDY
Taranis
  • Balne Moor MBC
« Reply #438 on: November 26, 2019, 08:47:19 pm »
ANDY
Martin [Admin]
« Reply #439 on: November 27, 2019, 06:11:34 pm »
Hi Andy,
Oops, I broke something.... can you repost please?
( Best put the video in a separate post... )  :D
Taranis
  • Balne Moor MBC
« Reply #440 on: November 27, 2019, 06:18:42 pm »
Whole post has gone  {-)  That's a memory tester  :-))
The video
<iframe frameborder="0" scrolling="no" width="1080" height="1920" src="https://api.smugmug.com/services/embed/8997744874_vfLDvbw?width=1080&height=1920&albumId=195202017&albumKey=k3nMnf"></iframe>
ANDY
Taranis
  • Balne Moor MBC
« Reply #441 on: November 27, 2019, 06:32:03 pm »
I had a rest from brass today and had a go at the gas struts. This is a working prototype that needs a little elaboration/embelishment yet.
I've placed another order for a Scarborough decal set with David Leftley Graphics £56 FYI
Now catching up on Portside
ANDY
Taranis
  • Balne Moor MBC
« Reply #442 on: November 28, 2019, 06:43:41 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #443 on: November 28, 2019, 10:18:50 pm »
Tamiya spray Silver Leaf is durable and won't tarnish
I'm with Arno
Someone made a fair effort with the supplied grille but I think we can up the game
Bolts and paint to finish
ANDY
Taranis
  • Balne Moor MBC
« Reply #444 on: November 30, 2019, 09:11:52 am »
Good morning  :-)
Working from Kim's excellent photo collection I set about creating the port side gas strut lower mounting.
This took two attempts but I think its ok now.
First one stood off the side wall too far once in place
This one is spot on
Later vessels use this reinforcement plate to bolt through
ANDY
Taranis
  • Balne Moor MBC
« Reply #445 on: November 30, 2019, 04:18:31 pm »
I apply all tactics to secure parts in the correct position for each solder. It gets easier once the first connection is made.
Cleaned up
Primered
ANDY
Taranis
  • Balne Moor MBC
« Reply #446 on: November 30, 2019, 05:10:24 pm »
ANDY
Mark T
« Reply #447 on: November 30, 2019, 05:38:36 pm »
Quality work - its starting to look extremely detailed now  :-))
Taranis
  • Balne Moor MBC
« Reply #448 on: November 30, 2019, 05:55:23 pm »
Thank you Mark it's amazing how busy it looks and lots to add yet. At my current rate of progress I might have both Shannons ready for paint come spring. I'm very pleased that I have surprised myself in at least matching the detail of the other model if not in some instances bettering.
However that said I am not rushing
That gate etching makes such a huge difference  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #449 on: November 30, 2019, 06:08:19 pm »
My buddy in Ireland has recommended this to us on Shannon Facebook today. I think I'm going to invest in it for my upcoming birthday. Thank you Steve :-))
https://www.ebay.co.uk/itm/Soldering-Station-Yihua-992DA-Digital-Welding-Solder-Desoldering-Air-Warm-/273888739134?hash=item3fc50a7f3e
https://notenoughtech.com/review/yihua-992da-reveiw/
https://youtu.be/SnEZnt9yNcA
ANDY
Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... 35   Go Up
