Author Topic: ModelsbyDesign Shannon  (Read 113454 times)
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon
« Reply #675 on: February 13, 2020, 06:02:29 pm »
I just tried this idea for the safety lines. Using Graupner 10mm turnbuckles. I will also use a number of these for between stanchions.
Nothing but doubled back electrical wire with heat shrink.
I've not made the metal backplates for the anchor points yet.
Google Graupner 492.1  about £15 for 10
ANDY
Mayhem is the name model boats is our game
Taranis
  • Balne Moor MBC
« Reply #676 on: February 13, 2020, 08:56:00 pm »
I feel I am going to do all stanchion lines the same way which would require 18 turnbuckles total. Although lacking in detail it does mean that there is largely less metal to metal contact and paint chipping.
I just wish there was a silver heat shrink.
I've ordered 1mm stainless steel rod for the safety line anchors rather than the brass pictured.
EDIT
It just occurred to me that I can use stainless rod on the brass stanchions too as I'll be fitting them into the accurately drilled holes with CA that if I fit one end of a turnbuckle as appropriate before gluing it will save a lot of other work. (only to the ones that have a tensioner)
ANDY
Taranis
  • Balne Moor MBC
« Reply #677 on: February 13, 2020, 10:44:12 pm »
Forgive my ineptness
Thank you Declan for correcting my error on farce book
Everywhere I typed turnbuckles please substitute with bottle screws  {-)    :-))
ANDY
tsenecal
« Reply #678 on: February 14, 2020, 01:30:08 am »
<snip>
</snip>
would you be able to use white heat-shrink and either silver paint, or a silver paint pen?
Taranis
  • Balne Moor MBC
« Reply #679 on: February 14, 2020, 09:23:02 am »
Actually Tamiya TS-83 requires a black base coat  :-))  so worth a try.
Port side
ANDY
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #680 on: February 14, 2020, 09:46:02 am »
 {-) {-)  That's me in the black book!
Have to say, I'm really enjoying the forum. Does a lot for the old bap - just to escape into my own wee world for a period of time. So much to read and take in. Keep up the great build  :-)) :-))
[/size]
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon WIPER ARM
« Reply #681 on: February 14, 2020, 12:58:28 pm »
First attempt
What you think Kim? its your fault  {-)
The decals I asked David Leftley to make  :-))
ANDY
Canterbury Coxswain
« Reply #682 on: February 14, 2020, 02:00:59 pm »
Andy,
Absolutely 'brill'.
Kim
Taranis
  • Balne Moor MBC
« Reply #683 on: February 14, 2020, 02:25:19 pm »
Thanks Kim
Unfortunately the brass isn't thin enough to create the required number of steps of the real ones but they will do I think.
I can easily add the screen wash jet to half of them. I just hate making 10  %%
ANDY
Canterbury Coxswain
« Reply #684 on: February 14, 2020, 02:32:17 pm »
Arno and I share a phrase for these occasions.............'gently, gently, catchy monkey.......'. That's a good start and the detail will look good against the windows Andy. That will give some other folks the idea to start theirs on a day when other jobs cannot be done.
Kim
Taranis
  • Balne Moor MBC
« Reply #685 on: February 14, 2020, 02:35:41 pm »
Once I have a full one completed I can create a template for the three holes below each window. It's important that they look correct in the parked position and its not really a measure that can be done off the plan.
For the drive shaft I used 1mm rod then the next two sizes of brass sleeve on that.
ANDY
mk1
« Reply #686 on: February 14, 2020, 03:23:28 pm »
Andy you can get a light grey heat-shrink cant rember were I got mine from. Like the wipers gives me ideas.
Taranis
  • Balne Moor MBC
« Reply #687 on: February 14, 2020, 04:06:48 pm »
Thanks John
I will try the Spray first same as my cleats.
ANDY
Taranis
  • Balne Moor MBC
« Reply #688 on: February 14, 2020, 06:52:40 pm »
I've not decided what to do for the wiper blade
ANDY
Canterbury Coxswain
« Reply #689 on: February 14, 2020, 08:51:13 pm »
Andy, I knew you would do it - and it's given you a mini-project to fill in all that spare time {-) !!
Kim
Taranis
  • Balne Moor MBC
« Reply #690 on: February 14, 2020, 10:30:14 pm »
It helps  :-))  there are so very many things to do
Some measurements  28mm and 55mm
16mm
Tools for shaping
I'm thinking keep it simple for the blade, square styrene
ANDY
tsenecal
« Reply #691 on: February 14, 2020, 11:08:07 pm »
Taranis
  • Balne Moor MBC
« Reply #692 on: February 14, 2020, 11:29:10 pm »
Now first I'm thinking YES!
Then I'm thinking this square section has a lot of meat on it to sand some shaping.
Then I'm thinking add a small T to the square  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #693 on: February 15, 2020, 12:01:10 am »
ANDY
coch y bonddu
« Reply #694 on: February 15, 2020, 09:08:21 am »
Your attention to detail is unbeleivable this will be a show winner
Taranis
  • Balne Moor MBC
« Reply #695 on: February 16, 2020, 05:02:47 pm »
Woah! I didn’t see that coming Dave
Compliments always welcome  O0
Show winner maybe a bit ambitious but I do the best I can.
ANDY
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
« Reply #697 on: February 16, 2020, 06:59:09 pm »
Re above
I could have followed Kim with the attachment but I use my vertical drill absolutely loads so the stand alone miller was best for me.
The compound bed attachment is very well priced on amazon prime
ANDY
Taranis
  • Balne Moor MBC
« Reply #698 on: February 16, 2020, 08:37:56 pm »
Maybe useful to others
I chose to buy and use a keyless chuck for my baby drill. I cannot fault it in anyway, it fits the tiniest of bits and has never come loose.
ANDY
Taranis
  • Balne Moor MBC
« Reply #699 on: February 18, 2020, 07:02:34 pm »
A big revelation!
I have in the past almost exclusively used K&S brass.
All my railings and stanchions have been 3.18mm or 1/8 so you would think that running a 3.5mm die up it should be easy? well it hasn't been with K&S
I don't know why as both K&S and the brass I got recently form Macc Models are precise in size but the MACC stuff threads easily with a squeaky noise as I rapidly thread it in a fraction of the time.
I thought too good to be true so I just checked it for bending and that too is excellent.  :-))
ANDY
