Author Topic: ModelsbyDesign Shannon  (Read 160258 times)
Paul2407
Re: ModelsbyDesign Shannon
« Reply #750 on: March 01, 2020, 10:42:38 am »
Good luck with that buckle  :o that's mighty small but if anyone can I'm pretty sure you can  :-))  look forward to seeing the outcome
Taranis
  • Balne Moor MBC
« Reply #751 on: March 01, 2020, 11:50:21 am »
ANDY
Youíll only know your best effort if you donít give up.
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon : miniature securing strap buckle
« Reply #752 on: March 01, 2020, 12:06:12 pm »
I think this is achievable by anyone who really wants it.
The smallest I can manage even if a smidge big to scale.
2mm spacing
Solder this and file to shape
ANDY
Paul2407
« Reply #753 on: March 01, 2020, 01:27:47 pm »
Superb and quick work there mate
Mark T
« Reply #754 on: March 01, 2020, 01:59:15 pm »
Thats very realistic - its great making your own parts ain't it  ;)
Taranis
  • Balne Moor MBC
« Reply #755 on: March 01, 2020, 08:55:00 pm »
Thank you both  :-)  This morning I had a picture in my head of what I thought might work but thought I might be all day at it or even fail. I tried smaller drill bits but they just snap so 0.8mm really is my limit which dictated the overall size. The 2mm webbing won't stick with CA so I had to use epoxy which unfortunately spoils the colour too. On the final build I'll shorten the strap but for now I need the length to undo and refasten it.
ANDY
Taranis
  • Balne Moor MBC
« Reply #756 on: March 01, 2020, 09:34:13 pm »
I would say take a bow but being female ?  {-)
Back on the stanchions tomorrow I've had a good break  O0
ANDY
Taranis
  • Balne Moor MBC
« Reply #757 on: March 02, 2020, 10:15:38 am »
Burning the midnight oil I tried another strap with a different CA Everbuild industrial and this DOES work on this material  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #758 on: March 02, 2020, 12:54:38 pm »
The penultimate upright ready for soldering.
ANDY
Taranis
  • Balne Moor MBC
« Reply #759 on: March 02, 2020, 01:15:26 pm »
OK so after the Amazon drill bits waste of money.....
I'm taking these for a ride. Seller has great prices for Heller and the suitability chart puts these Titanium as the most suitable for brass/non ferrous.
So at £7.98 for 10  delivered I will let you know
https://www.ebay.co.uk/itm/10x-GERMAN-QUALITY-HELLER-HSS-DRILL-BITS-Titanium-Ground-Rolled-Long-For-Metal/192457789277?ssPageName=STRK%3AMEBIDX%3AIT&var=492481983613&_trksid=p2057872.m2749.l2649
Taking a break now as todays stanchion was completed an hour ago
My feedback on these for brass is fantastic and I've just bought another 20
ANDY
Taranis
  • Balne Moor MBC
« Reply #760 on: March 03, 2020, 02:08:16 pm »
I'm getting close to completion of all brasswork.
I don't think I pictured my pinning before of the Stanchion brace junction? 1mm hole drilled through and brass rod fitted covered in flux.
Starboard complete
ANDY
Canterbury Coxswain
« Reply #761 on: March 03, 2020, 02:17:43 pm »
.......or even Port side %)
C.C.
Taranis
  • Balne Moor MBC
« Reply #762 on: March 03, 2020, 02:21:45 pm »
Port side is still under construction.  %%
ANDY
Canterbury Coxswain
« Reply #763 on: March 03, 2020, 02:24:49 pm »
Andy,
It's just that you showed the Port side when you said Starboard and the Starboard side when you said Port. Confusing.....maybe.
Kim
Taranis
  • Balne Moor MBC
« Reply #764 on: March 03, 2020, 02:25:46 pm »
Maybe but both sides where visible in the confusing post  {-)
ANDY
Canterbury Coxswain
« Reply #765 on: March 03, 2020, 02:32:11 pm »
..........but very nice they still look :-))
Kim O0
Taranis
  • Balne Moor MBC
« Reply #766 on: March 03, 2020, 02:54:49 pm »
Thank you Kim. It's very nice being able to view them all without the cabin in the way, something not possible with the kit version.
This also aids vertical alignment.
ANDY
Canterbury Coxswain
« Reply #767 on: March 03, 2020, 03:06:27 pm »
Yes, I had not considered that......so quite helpful in that aspect, especially when pond or lakeside with the wheelhouse removed - where ever you are, there's always a 'rivet counter' about!
Kim
Paul2407
« Reply #768 on: March 03, 2020, 07:11:03 pm »
Andy,
Kim
I think Andy's been on that Spanish wine again
Taranis
  • Balne Moor MBC
ANDY
Paul2407
« Reply #770 on: March 03, 2020, 07:22:32 pm »
https://media.giphy.com/media/lz7GtEHgSHencsRmYW/giphy.gif
 {-) {-) {-)  Fantastic............... Top work finishing off the rails though, they got a little labour of love but you've made a top job of them
Taranis
  • Balne Moor MBC
« Reply #771 on: March 03, 2020, 07:29:01 pm »
Thanks Paul. Not finished yet! but hopefully by tomorrow night. I think the only brass left to do is the grab rail facing the gate to the upper helm Amen
Then there's all the bolts to fit on the feet and the leg pull pins in stainless after painting
ANDY
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon. The stand alone stanchion features
« Reply #772 on: March 03, 2020, 10:39:49 pm »
Every stanchion base is the same procedure but the stand alone stanchion is different there after.
3.18mm bore brass tube set for soldering. My centre height from deck is 35mm at the centre line of the foot
Trim off the other side and repeat soldering.
Then grind off both sides near to their final length.
drill from both sides 1mm
Follow both sides with one of these at 3.18mm also
Only as deep as the solder
2mm bit NO BIGGER from both sides also, smaller if you choose.
to be continued ......
ANDY
Taranis
  • Balne Moor MBC
« Reply #773 on: March 04, 2020, 11:43:24 am »
So for the top I drill just one hole in the brass tube.
I shape the top of the leg so it fits fully into the round tube and slot the top to make drilling easier later.
Again I solder one side then cut the other side to length and solder too
My finished stanchion height are 76mm
Centre here is complete the outer two will be trimmed to height AFTER fitting the shackle points.
This clearly shows the extreme angles of the foot plates to maintain a vertical leg and why in my opinion the only accurate way to do this is in place as they are all different.
ANDY
Taranis
  • Balne Moor MBC
« Reply #774 on: March 04, 2020, 03:47:33 pm »
ANDY
Pages: 1 ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35   Go Up
