Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 35   Go Down
Author Topic: ModelsbyDesign Shannon  (Read 139794 times)
coch y bonddu
Re: ModelsbyDesign Shannon
« Reply #125 on: August 18, 2019, 09:06:58 am »
This is the stuff I have been baning on about for years and it used to be top stop....i use this on a daily basis on cars I am not into hard work or rubbing filler ....time is important to us in body shops,I have used this on Balsa wood.....ok you have to be very careful on this wood as it is so so soft but it does the job admirably,the beauty of this product is that you can use it a fill imperfections after priming,not many car fillers can do this without showing after a reprime,I also use this on plastic card as it seems to stick to the plastic without falling off like a lot of fillers.
Yes of course I know it is expensive but Hey ho quality products always are
Andy.....I have a tin of this same size as what I have shown in the link and it is 4 yrs old and it is still usable,Just make SURE 100% you put the lid back on it straight away and it will NOT dry up.
Canterbury Coxswain
« Reply #126 on: August 18, 2019, 12:02:09 pm »
Andy,
Totally agreeing with what Dave and Mark have said. I will be going down the same path to correct my original fault - sorry! Like wise my tine of UPol is just keeping perfect, just like the similar product I used before that. It's what Andy G. uses too.
Kim
Taranis
  • Balne Moor MBC
« Reply #127 on: August 18, 2019, 04:57:50 pm »
Yes thanks all it is on the way for future.
For now the deluxe Materials putty actually did a good job and doesn't shrink or crack but the thicker it is the longer time to dry.
Meanwhile I've nearly broke the back of the rear cabin assembly. The bulkhead will be held in place with 3x3mm and 5x2mm screws so only a few minutes to dismantle. This obviously makes painting and detailing so much more accessible especially if you forget something and realise later on.
Tasks like texture coating the upper control floor a doddle
ANDY
Youíll only know your best effort if you donít give up.
Taranis
  • Balne Moor MBC
« Reply #128 on: August 18, 2019, 10:11:42 pm »
The side wall will eventually be glued to the comms tower support wall and the screws removed and holes filled. For some time to come it's more desirable that I can separate this.
Shannon builders have a facebook group for all things Shannon of any brand.
https://www.facebook.com/groups/220509768718588/?multi_permalinks=519229205513308&notif_id=1566145876711865&notif_t=feedback_reaction_generic
I expect the Jet drive new parts this week and will use another thread to do a complete fitting guide my way. I say my way because there are always more ways to skin a cat so it is open to do what you like and advise of better options if you have ideas
ANDY
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
« Reply #130 on: August 19, 2019, 02:12:14 pm »
I had so many other things to do yesterday  :((
However I did get a bit done to a point that it all fits and can be fine tuned later.
Likely hinge
Something to build on with a styrene infil perhaps. T profile I'm thinking to the sliders will be captive
People keep asking me what order to do things? well in most cases it's just a matter of how you feel and what you fancy.
The only override is that anything you do must not cause an impact on things you need to do later. Example, you wouldn't glue the deck on until you've finished everything inside the hull
Just now I'll have a break and contemplate the drives that I now have a tracking number for  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #131 on: August 19, 2019, 03:14:55 pm »
So much for a break  {-)  sometimes the model just guides you
Much potential  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #132 on: August 20, 2019, 11:04:42 am »
My job for today
and tomorrow and Thursday  {-)
Seriously doesn't take long
Knupfer bolts  102 required 1.4 x 6 type 400
EDIT Done this side within the modify post period
ANDY
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #133 on: August 20, 2019, 03:00:36 pm »
Hi Andy.
Are you using some form of template to equally space out the hole positions and drilling.
Declan
Taranis
  • Balne Moor MBC
« Reply #134 on: August 20, 2019, 03:35:21 pm »
No Declan just a tape measure rule and pencil and a steady hand. The bolts are slightly overscale but because I'm not using washers they appear OK
ANDY
dpbarry
« Reply #135 on: August 20, 2019, 03:39:34 pm »
Taranis
  • Balne Moor MBC
« Reply #136 on: August 20, 2019, 03:44:35 pm »
Maybe some help but at peoples own risk  :-)
The side panels find the centre. Measure 2.5mm either side of centre then 5mm intervals gives 22 bolts
The big panel measure centre and 5mm intervals either side equals 29 bolts including the centre
Drill line 5mm from edge all around
This is as 13-01
ANDY
Taranis
  • Balne Moor MBC
« Reply #137 on: August 20, 2019, 05:14:52 pm »
I've just placed another order with Knupfer and they haven't even asked for advanced payment, seem to trust previous customers. I pay by bank transfer in euros.
After marking out I spot drill all the holes with the tip of a 0.8mm drill bit and if they then look ok I drill through and then re drill 1mm before following with 1.4mm tap
ANDY
RST
« Reply #138 on: August 20, 2019, 06:19:46 pm »
Re that post about the deluxe filler. I said on another post I've not been convinced yet it's just decorators caulk in a small squeeze tube.  As Stavros mentioned there's better out there. Also for small holes we used a single part putty "knifing putty" in the shop, nothing else 2k usually fills pin holes or micro cracks. It's like the squadron putty but finer, flexible and made in a bigger tube. Perhaps Stavros / coch ye bondru can help as I'm needing it now but can't remember what it was called.
coch y bonddu
« Reply #139 on: August 20, 2019, 08:17:23 pm »
RST is it Dolphin Glaze you are thinking of ????
Taranis
  • Balne Moor MBC
« Reply #140 on: August 20, 2019, 08:26:42 pm »
My filler arrived by DHL today. Threw it over my 2 metre fence so nicely dented, good job I have some filler for it  {-)
Not much filling left to do and bulkhead now also secured by the windscreen hinge bolts (I've ordered miniature countersunk ones for later) Paxolin CA'd to the resin so I could tap it from above
The screen side channels will hide the gaps
ANDY
Taranis
  • Balne Moor MBC
« Reply #141 on: August 21, 2019, 10:59:29 pm »
Tonight I've taken the deck off to start looking at the running gear.
I've fixed this GRP sheet to a piece of 6mm Paxolin with two of the 3mm screws that hold the servos in place
The paxolin will be glued to the hull
Something like
So this whole unit can be removed with just the two screws via the centre hatch
I can't set this up until the trim tabs are in place.
The 2mm SS servo rods will come up though Joysway bellows behind the servo arms then angle 90 degrees to forwards through them.
ANDY
Taranis
  • Balne Moor MBC
« Reply #142 on: August 21, 2019, 11:18:17 pm »
While I'm at it here is the fourth stringer I fitted
ANDY
Taranis
  • Balne Moor MBC
« Reply #143 on: August 22, 2019, 08:22:40 pm »
Thought I'd crack on a bit
Just taking far too long  {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #144 on: August 22, 2019, 10:37:45 pm »
Iíve just looked back at the original delivery of the first jet drives and it was 9 days
New parts were posted Monday and now on day four. Iím touring Scotland from Sept 5th anti-clockwise for an undetermined period. So itís touch an go whether weíll be on the water before I leave
ANDY
Taranis
  • Balne Moor MBC
« Reply #145 on: August 22, 2019, 11:42:16 pm »
End of day shot. What will tomorrow bring
Happy with progress
ANDY
RST
« Reply #146 on: August 23, 2019, 01:07:10 am »
...nope, I can picture the tubes, just can't remember the name.  Probably essentially the same  stuff though!!
...Are you using copperclad to screw servos down?  Seems a bit of a waste of copperclad!
Taranis
  • Balne Moor MBC
« Reply #147 on: August 23, 2019, 09:10:07 am »
Itís what I have in stock no other reason
ANDY
Taranis
  • Balne Moor MBC
« Reply #148 on: August 23, 2019, 05:35:22 pm »
Wasn't sure which direction to go today but with all the GRP and resin work my craft room was a tip and time for another clean up.
Two hours later .........
As it's cracking the flags today I thought to get the deck fully primered.
Then I turned my attention to the stern and an opportunity to share my ideas with Kim as so far I've been taking his work  :-))
I've started with a template that can be used either way up to produce both fittings.
Initially I was thinking of brass sheet but I didn't have any thick enough and when I spotted the small pieces of double sided copper GRP I bought months ago it was a no brainer.
About the right thickness can band saw and table sand it drill & tap it and solder to it .
As this will be painted there is also no need for nickel bolts.
I will cut off all but the corner bolts and use those as fixings to the deck
ANDY
Taranis
  • Balne Moor MBC
« Reply #149 on: August 23, 2019, 09:39:21 pm »
ANDY
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 35   Go Up
