Author Topic: ModelsbyDesign Shannon  (Read 82627 times)
Taranis
  • Kirklees MBC/ Balne Moor MBC
Re: ModelsbyDesign Shannon
« Reply #625 on: January 26, 2020, 09:15:04 PM »
I worked carefully around the handle with a chisel blade and got it off undamaged. Relocated with CA  :-))
ANDY .. I don't do lights!
Lobster boat
Portgarth
Every day above ground is a good one
Martin [Admin]
« Reply #626 on: January 27, 2020, 12:50:55 AM »
Where are all the brass fittings / hinges coming from?
Taranis
« Reply #627 on: January 27, 2020, 09:35:17 AM »
From my hands Martin
Lobster boat
Portgarth
Martin [Admin]
« Reply #628 on: January 27, 2020, 11:22:31 AM »
Taranis
« Reply #629 on: January 27, 2020, 05:29:49 PM »
Like it Not a Lot  {-)
Bish bash bosh! anyone got an idea for buckles to fit 2mm wide webbing?
EDIT thank you C3P0 :-))
https://theknittinglady.co.uk/index.php/misc-items/buckles/3-5mm-wide-buckle-x-1-silver-detail?fbclid=IwAR2uQSrIZ3tOu0g3JqLl2UMHOK-b-TR3H5YcerBs8my3-VXEusU6sUoYfaY
Lobster boat
Portgarth
RST
« Reply #630 on: January 27, 2020, 06:04:27 PM »
Dolls belt buckles (these might be a bit big)...
https://www.bluebellminiatures.co.uk/product_list.asp?p_subcategory=OP11
Taranis
« Reply #631 on: January 27, 2020, 06:07:47 PM »
Thanks Rich
I bought the ones I just posted in the edit , for 2mm webbing  :-))
Lobster boat
Portgarth
Taranis
« Reply #632 on: January 28, 2020, 04:53:31 PM »
Returning to the magnets idea.
These are the 5mm x 0.5mm and they do it for me. Wont look out of place on painted hatches.
Lobster boat
Portgarth
Taranis
« Reply #633 on: January 29, 2020, 06:06:05 PM »
A couple of hours of tedium and again it just evolved.
I started with the main plate from sheet brass and then found suitable size brass tube and as it was 1.7mm rod for the hinge pin.
Soldering was awkward but managed obviously.
This will actually work if I wish but a bit pointless.
I had to deepen the rebates a bit
Just the 8 screws to fit
Lobster boat
Portgarth
Taranis
« Reply #634 on: January 29, 2020, 09:25:00 PM »
Lobster boat
Portgarth
Taranis
« Reply #635 on: January 29, 2020, 10:15:15 PM »
I just bought a pair of these. If you're going to a show better to buy from ComponentShop but these are under £12 a pair delivered and because its less than £15 no import charges.
The ESC will cut power at a set voltage but better to have a little bit of advance warning to head back in.
https://uk.banggood.com/In-Line-Battery-Voltage-Alarm-with-LED-XT60-Plug-For-2-6s-Lipo-Battery-p-1177822.html?fbclid=IwAR2c3kjziD5cRzDGM0U6UwJg0efeQmImtDVTzlNeTgGDXiarnW1pz2AMMyA&cur_warehouse=CN
Lobster boat
Portgarth
Taranis
« Reply #636 on: January 30, 2020, 10:42:04 PM »
I don't know who is responsible for these parts but it really was a stroke of genius to make them how they did. It can pretty much be detailed to a completed finish before being very well inserted into the deck recess. It does need a lot of attention to the real hatch as it does need a lot of fettling to the subtleties that can be easily overlooked.
Firstly it should not fit flush to the deck and will need packing up slightly proud. All the edges need to be rounded off rather than sharp too.
Anyway here is a picture of the 13-15 hatch
My progress so far and I haven't found a suitable colour yet either.
Lobster boat
Portgarth
« Reply #637 on: January 30, 2020, 10:58:19 PM »
Well, after adding the complex profile of the anti-skid surfacing, I suggest your build is a pretty darn good representation of the origin  :-))
One question, on the actual vessel, does each of the Crew Members carry or wear a rope & square drive for the 4 x corner locks?
kinmel
  • Colwyn Bay M.B.C.
« Reply #638 on: January 31, 2020, 07:03:07 AM »
That hatch is the engine space emergency exit, the handles are on the under side.
Taranis
« Reply #639 on: January 31, 2020, 07:41:18 AM »
From JH
Hi Andy, the main purpose of the hatch is as an escape hatch for the jet space
- in case of fire, flooding or pyrogen discharge in the engine compartment (the standard access route)
The jet space is separated from the engine compartment by a watertight bulkhead with an acces door
The possible reason for a crewmember to be in the jetspace is to be able to manually control the buckets and steering nozzles by mechanical means in the event of a total failure of the electronic controls and the back up electrical controls.
The other reason to access there would be in the case of impellor fouling
As there are inspection scuttles /hatches that can be opened with the boat afloat (with everything stopped!) as long as sea-state is moderate to allow an attempt to physically remove or cur away whatever is fouling the impellor - (assuming that the normal control procedure of carrying out a back-flush by engaging reverse gear to drive the impellor in reverse has failed to clear the fouling)
As for opening the hatch the internal opening lever is permanently fitted, and you are correct that there is a removable
 key/lever that is stowed just inside and to the right of the wheelhouse door
Lobster boat
Portgarth
alan44
« Reply #640 on: February 01, 2020, 03:09:24 PM »
 Hi Andy. I chose this colour 👍
Taranis
« Reply #641 on: February 01, 2020, 03:12:03 PM »
Good choice Alan and your Speedline is truly stunning  :-))
I just happen to have bought that myself along with AS-16 USAF light grey and about to try it.
EDIT the grey below , not sure until dry but I think you nailed is with Insignia
Lobster boat
Portgarth
Taranis
« Reply #642 on: February 01, 2020, 05:19:37 PM »
Yes definitely AS-20 Alan  :-))  I have finished mine in gloss clear. I'll leave it 24hrs before masking up for texturing.
Lobster boat
Portgarth
Taranis
« Reply #643 on: February 02, 2020, 03:13:46 PM »
Can any of you at Poole come up with some dimensions for this? me3? Pleeez  O0
Lobster boat
Portgarth
me3
« Reply #644 on: February 02, 2020, 07:57:50 PM »
Hi, Just seen this, I will see what I can do, give me a week and hopefully I'll have something for you!
Taranis
« Reply #645 on: February 02, 2020, 08:00:26 PM »
Very kind of you. Absolutely no rush and as many beam sizes as possible. Iíll work most out from length and breadth  :-)
Lobster boat
Portgarth
me3
« Reply #646 on: February 02, 2020, 08:07:22 PM »
No Problem, I will take as many measurements as I can and get a good set of photos for you during tea breaks over the next few days!
Taranis
« Reply #647 on: February 02, 2020, 08:08:07 PM »
Brilliant  :-)
Lobster boat
Portgarth
Taranis
« Reply #648 on: February 03, 2020, 06:16:43 PM »
I've started looking at the stanchions that I have to make for a second time. I need to be more organised to mass produce despite them all being different.
Firstly I discovered I barely have any 1/8th brass rod left.
Tired of paying £5.25 per 36" I've googled and found MACC Models to be best at £2.66 per length but postage has to be considered so I bought 10 lengths to average it out delivered to £3.56 per length.
https://maccmodels.co.uk/shop/1-8-brass-round-cz121-per-foot-2/
Collection in person is possible too.
A bit further with the jet escape hatch. My masking up is below par but at a foot away it looks fine lol
Lobster boat
Portgarth
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #649 on: February 03, 2020, 07:20:50 PM »
Hi Taranis..
Are your brass hinges nickel plated?
Declan
