Pages: 1 ... 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35   Go Down
Author Topic: ModelsbyDesign Shannon  (Read 199995 times)
kinmel
Re: ModelsbyDesign Shannon
« Reply #825 on: June 19, 2020, 12:21:54 pm »
That is how I painted my white line.
However it took a full day to get the six laser lines to all join up correctly. <:(
Don't forget the black paint on the top of the step.
Taranis
  • Balne Moor MBC
« Reply #826 on: June 19, 2020, 12:37:23 pm »
That's reassuring to know  :-))   I do fully expect it to take all day and a scalpel.
This will form the main body of the line. From a local Ebay seller who dropped it through my letterbox  :-)
ANDY
minimariner
« Reply #827 on: June 19, 2020, 03:03:01 pm »
 [quote author=kinmel
                   Kinmel,
                             Can I ask the Make/model of the Laser you are using, the cheaper
                           ones I have looked at seem to have a rather thick and very fuzzy line.
                                                         Bryan.
kinmel
« Reply #828 on: June 19, 2020, 04:01:08 pm »
Mine is a self levelling unit, a special buy from Aldi.
You need to adjust the distance to sharpen up the line, fuzzy means too far away
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #829 on: June 20, 2020, 03:05:28 pm »
Just a wee query here in terms of making up all the brass railings etc..
Has anyone considered spot welding? - assuming access to a spot welder. Just thinking of an alternative to soldering/silver Soldering
Declan
Taranis
  • Balne Moor MBC
« Reply #830 on: June 20, 2020, 03:52:08 pm »
Spot welding is for joining two sheets of flat steel together by passing a high current through it.
I don’t see how that can be applied to brass rods ?
IMV soft soldering is better anyway because if you make a crock of it it’s easy to reheat and adjust
ANDY
dpbarry
« Reply #831 on: June 20, 2020, 04:04:51 pm »
I’ve seen it done with mild steel rod rod - making fishing creels etc. Not sure of brass rod although I’ve seen a lot of items made from brass that look spot welded. Get your point about soldering though. Will stick to it. Just curious 👍👍
Taranis
  • Balne Moor MBC
« Reply #832 on: June 20, 2020, 05:49:14 pm »
Since the question has been asked. This is my laser from my working days.
It has been used in all my blogs
ANDY
dpbarry
« Reply #833 on: June 20, 2020, 06:27:43 pm »
Lidl’s did one a year or so ago which I bought for fencing work. Did the job in helping to erect cupboards in the shed. Has the automatic levelling unit built in.👍
Taranis
  • Balne Moor MBC
« Reply #834 on: June 21, 2020, 10:52:39 pm »
I managed satin lacquer on the deck today plus primer and white top coat on the midriff.
I'd like another coat tomorrow them masking on Tuesday.
Very much looking forwards to seeing the bow completed
Also ready for masking
ANDY
Taranis
  • Balne Moor MBC
« Reply #835 on: June 23, 2020, 10:15:20 pm »
I had a day off today to be sure of full curing of paint. The masking may be on for some time and I'll now start tomorrow
ANDY
Taranis
  • Balne Moor MBC
« Reply #836 on: June 24, 2020, 06:33:59 pm »
It's all RNLI's fault  O0  must be easy on full size though  {-)
Progress today
ANDY
Taranis
  • Balne Moor MBC
« Reply #837 on: June 24, 2020, 06:37:03 pm »
Black tomorrow
ANDY
Taranis
  • Balne Moor MBC
« Reply #838 on: June 24, 2020, 06:44:14 pm »
First time I've looked at the Graphics for the bow from David Leftley and they are wrong size and spacing.
David produced these based on information he was given and he is always happy to revise them but he is recovering from an op so I'm not going to bother him.
Firstly they are too small for 1:12 at only 25mm high. They scale at 33.3mm from 400mm actual. Probably Ok for 1:16 apart from the spacing of the numbers is too great also.
Look at the 1  5  %%  for example
Actual
I've contacted the same guy that printed my Portgarth decals and he spent quite some time making me happy.
I've now ordered sets in both 30mm and 33mm to see what fits best. Size affects length.
ANDY
kinmel
« Reply #839 on: June 24, 2020, 08:47:11 pm »
Change of plan?
I thought it was white stripe first and then upper and lower hull colours to define athe actual line.
Taranis
  • Balne Moor MBC
« Reply #840 on: June 24, 2020, 08:49:48 pm »
Thats what I've done. The white is masked over and I've sprayed the blue. Tomorrow I'll mask the blue along the white line and spray black. Then depending how I feel I might do the grey keel strip.
I'm already feeling another wooden kit coming on  {-)
ANDY
Beyno1968
« Reply #841 on: June 26, 2020, 11:42:51 pm »
Hi Andy
Thanks for your pm about appliance white paint. I did try and send you a pm but it keeps telling me you have blocked me from sending you messages.
Chris
Taranis
  • Balne Moor MBC
« Reply #842 on: June 26, 2020, 11:44:18 pm »
That’s odd not knowingly  :-))
Martin??
Edit
My fault and easy fixed
I had it set to buddies and admin only, dates back to getting nasty messages from nasty members  {-)
ANDY
« Reply #843 on: June 27, 2020, 01:13:48 am »
What's up?.... Ah!.... Sorted!..... back to sleep......  {-)
Taranis
  • Balne Moor MBC
« Reply #844 on: June 29, 2020, 11:12:31 am »
Yes all fine thank you  :-))
Two steps back! yes it happens to me too.
Painting was ok but realised too late that the line is too narrow so I'm flatting it all back for bigger tape which is on the way.
I've seen many other builds that also suffer from a 6mm line.
I don't mind persevering
ANDY
Taranis
  • Balne Moor MBC
« Reply #845 on: June 29, 2020, 03:33:40 pm »
Having lots of postal delays so I got a sack full today  {-)
Decals arrived 30 & 33mm not sure which I will use yet but they both fit ok
ANDY
Taranis
  • Balne Moor MBC
« Reply #846 on: June 30, 2020, 10:41:31 pm »
Steve Ryan has now updated the original Speedline figures to the new kit
RIB too
ANDY
Taranis
  • Balne Moor MBC
« Reply #847 on: July 01, 2020, 09:50:54 pm »
Despite starting a new build the Shannon is continuing with painting as weather permits. I remasked and white primed for the waterline today.
ANDY
Taranis
  • Balne Moor MBC
« Reply #848 on: July 23, 2020, 05:12:36 pm »
If anyone is desperate for a part built 1:12 Speedline one has just come up for sale on Shannon Facebook group
My friend Ole Bodker in Denmark has decided he is too old to spend more time on this in favour of other things.
Looking for £1500 plus shipping from Denmark
The work he has done is museum quality ! No contact here full details and pictures on Facebook
ANDY
marco
  • Model Boat Mayhem Is Great !
« Reply #849 on: August 20, 2020, 05:11:53 pm »
Hello Andy ,
      What are the reference RAL for the blue paint , the orange paint and the grey paint on the deck .
marco
if you don't know ask , if you know share
Pages: 1 ... 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35   Go Up
Page created in 0.111 seconds with 22 queries.
