Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: side lever engine cira 1840s  (Read 21646 times)
tonyH
Re: side lever engine cira 1840s
« Reply #25 on: October 06, 2018, 10:37:39 pm »
Hi Daves,
Just thinking whether there would be need for weight in the piston to create enough inertia for full rotation, bearing in mind that the originals would have worked with very low pressure and relatively slow rotational speed.
daves
« Reply #26 on: October 08, 2018, 04:03:40 pm »
As I research and draw the engine and boiler for the steam ship Mississippi I came to the conclusion I will have to research and study the steam engine before I can draw and build one. It stands to reason the more input I have the more information I can collect so I contacted adminstrator on this forum as well as the moderator of another forum asking if I can link this topic on both forums.
 There is no reason to build and maintain two separate topics It makes more sense to link them.
I would like to invite you to take a walk about in a boiler graveyard over at the other site here is the link
https://www.shipsofscale.com/sosforums/index.php?threads/marine-steam-engines-and-boilers.2272/page-2#post-41960
daves
« Reply #27 on: October 19, 2018, 04:22:36 pm »
I finished the CAD work for the gothic style frame of the engine and posted more images at this link
https://www.shipsofscale.com/sosforums/index.php?threads/marine-steam-engines-and-boilers.2272/page-3#post-42771
now I am moving on to the CAD work for the condenser but it has me stumped right now as to how it goes together
I will post my drawings as soon as they are done.
« Reply #28 on: October 19, 2018, 09:44:03 pm »
Dave...I see in the alternate WEB site you ask ......'what is a P Block?'....and the resulting comment of a Pillow Block
I believe an earlier definition or of a P Block terminology was a Plummer Block......further I suggest the bearing housings you have drawn were originally cast as Plummer blocks....and long before someone converted dimensions to the ISO Standard referenced
One of the main differences between the P Bolcks is that the Pillow variety are usually centered around the shaft axis, whereas Plummer had upper and lower elements that had little resemblance with matters of symmetry ...or exactly as the original Drawings depict
Remember these structures featured heavily of Gothic Design
Honorary Secretary
daves
« Reply #29 on: October 20, 2018, 05:03:58 pm »
on some of the drawings the blocks are referred to as just a P block
the original drawings are difficult to see but here is the original
on the plan the blocks are called pillow blocks but your right there is a big difference  between a pillow block and a plummer block.
I do not know if back in 1840s the term was interchangeable
I did post a few pictures of these type of blocks at this link
https://www.shipsofscale.com/sosforums/index.php?threads/marine-steam-engines-and-boilers.2272/page-3#post-42774
grendel
« Reply #30 on: October 20, 2018, 05:27:33 pm »
I am guessing but plummer blocks may have had a white metal or lead insert, which would have formed the bearing surface, and been hand scraped to get the correct seating of the shaft in the bearing - plummer as in lead?
daves
« Reply #31 on: October 20, 2018, 05:28:35 pm »
the drawings have 4 different blocks I have to figure out where they go
the first says P block the other one does not say anything
daves
« Reply #32 on: October 20, 2018, 05:42:54 pm »
from what I photographed in the Ford collection there seems to have been a brass bearing surface but in the second photograph you can see a light colored insert at the top of the shaft
daves
« Reply #33 on: October 20, 2018, 05:52:07 pm »
on the two pictures there is a brass insert or bearing surface
this block and shaft is quite different it has this big split ring around the shaft
I wish I would have taken a picture of the back side to see if this ring goes all the way through the block and what stops it from spinning around with the shaft.
« Reply #34 on: October 20, 2018, 11:49:29 pm »
Do not be put off by the irregular octagional shaped bearing element blocks.....these were cast from the RED copper metal family.....down to Muntz Metal or a even softer from the White Metal variety
So,yes......after casting the blocks would have been lathe bored & then hand scraped....again we must remember that these new steam engine machines were to be melded with the accepted Gothic constructional[/size]  architectural design
[/size]Imagine today's costs .....this style of design must have created a very high demand for qualified Journeyman of the Pattern Making and Metal Casting Trades
[/size]Derek
Honorary Secretary
daves
« Reply #35 on: November 06, 2018, 03:54:53 pm »
I have been busy with CAD drawing this engine and finished the condenser drawings. NOW! the problem is how in the world does it go together
I do know it goes in the blue area
daves
« Reply #36 on: November 06, 2018, 03:57:35 pm »
here is the master drawing of the condenser and a series of closeups
« Reply #37 on: November 06, 2018, 08:05:20 pm »
Dave, forgive me...but do you not now have a series of layered tracings taken from an original hand drawing?....
If this is the case, does each sub component tracing on another layer confirm all dimensions of the sub component?
So as such...I wasn't aware  that CAD packages have an auto assembly tool from tracings
Honorary Secretary
daves
« Reply #38 on: November 07, 2018, 03:52:23 pm »
I do not understand your post
no layered tracings but what you see are tracings from the original and are all scaled to one another
each component on the original had dimensions drawn in so I used those dimensions to size each part so everything drawn is now the same scale.
I do not know what "auto assembly tool" is somehow all the parts fit together to make a condenser
the original look like this and I used the dimensions on the plans are redrew the pARTS
grendel
« Reply #39 on: November 07, 2018, 04:36:06 pm »
put the different drawings into a single drawing, on different layers (maybe think of saving each as a block) then you can adjust the relative positions quite easily by turning layers on and off and moving the parts on one layer relative to another)
Of course as a professional CAD draughtsman, I would probably have initially drawn up the parts using the drawings as a guide, but creating the CAD in 3d to start with, then with the individual components all saved as separate blocks, juggled the parts around until they fitted properly. (but that is me being a smartie pants)
daves
« Reply #40 on: November 07, 2018, 07:18:10 pm »
and the smartie pants are the people I hope to meet
I can send anyone who wants a copy of the CAD drawing a DWG or DXF file if you want to just fiddle with it and try to put it together or do a 3D file
I have the main frame and the condenser files done and working on the cylinder
it may take a village to build this engine I am not smart enough with steam engines to do it alone
daves
« Reply #41 on: November 07, 2018, 07:23:04 pm »
3D modeling is an art unto itself  I think I get what your saying that is to create the parts in 3D and try to fit it all together brilliant!
like the frame columns
grendel
« Reply #42 on: November 07, 2018, 07:39:09 pm »
yes, thats the idea
grendel
« Reply #43 on: November 07, 2018, 07:49:05 pm »
basically you create building blocks and then merge them together to form your finished object
daves
« Reply #44 on: November 08, 2018, 03:02:07 pm »
my problem is I am OK with cad drafting not a pro just at a hobby level.  I did have a pro who would take my CAD drawings and redo them as 3D models but lo and behold that person is no longer available. So at this time I am at a stand still until I can find someone willing to create a 3D model from the CAD drawings.
I will carry on with drawing the parts and hopeful someone with an interest in this old gothic engine will attempt the 3D model.
my skills with 3D modeling is with a simple program Google sketchup
daves
« Reply #45 on: November 19, 2018, 03:13:06 pm »
a progress report on the CAD drawing
so far I finished the main frame, the cylinder, the condenser and the air pump
I am wondering if these engines had just one lever or was there a lever on both sides of the frame?
« Reply #46 on: November 19, 2018, 07:55:20 pm »
Dave.......
1. the image you are working on [progress3] is an inverted beam engine.........these [usually] have a symmetric pair of 'outer' lower beams driving a top mounted crankshaft
2. the gloss white images from a restored engine with the beautiful exampled Gothic cast entablature and structure is of single 'central' upper beam engine driving a lower mounted crankshaft
So to answer your question, as far as I can see......yes....your design example will have a balanced symmetric pair of 'outer' lower beams driving a top mounted shaft
Honorary Secretary
ooyah/2
« Reply #47 on: November 19, 2018, 11:59:55 pm »
Daves,
Here is a link to side lever engines (  https://en.wikipedia.org/wiki/Marine_steam_engine ) which may be of some help to you.
 can't prove it but I am sure that the engine has only one beam per side, "Hence a side lever engine."
The engine shown at Dumbarton is only about 20 miles from me but not in a place that I visit often, it sits outside Denny's experimental tank, at one time the longest in Britain if not the world and can be visited anytime that one is in the area, this tank was used by Barnes Wallis to experiment with his design for the bouncing bomb used by the Dam Buster patrol during the WW 11 bombing raids.
I hope this is of help to you.
George.
ooyah/2
« Reply #48 on: November 20, 2018, 12:04:37 pm »
Dave,
(can't prove it but I am sure that the engine has only one beam per side, "Hence a side lever engine." )
OOPS wrongly worded,
I should have  said , Only one beam on the engines "  side.
George.
Treble
« Reply #49 on: November 21, 2018, 05:49:45 pm »
Dave , There is a side lever engine at Markham Grange Steam Museum , Doncaster , England . They have a web site , where you will find pictures and a description of its working . Hope this helps a little . Sorry , I am not computor literate , and so cant post a link . Trevor .
Pages: 1 [2] 3 4 5 6 7   Go Up
