If you want to shape wooden stringers, or any stripwood you could do worse than trying this.
Find an old metal pipe, I use a piece of aluminium pipe from an old vacuum cleaner. secure one end and aim a blowtorch at the other. While you were doing that soak your wood in water for 30 mins or so. all you do then is shape the wood around the hot pipe, easing and bending as you go. with practice you can bend ply into funnels or make stringers into an exact fit so you get no stresses in the model. It's quick and can be very precise, BUT be carefull or you will have some burns. Lastly, I wouldn't aim the blowtorch into the pipe, you might end up with a flame thrower!!
