hi all,
Scratch building to me, I must confess, is where the modeller scratch builds or makes, everything physically possible - i.e. all exterior fixtures and fittings, such as anchor chains, props, prop shafts and soforth.
With regards motors, batteries, and radio gear, they dont physically contribute to the 'looks' of the model - they only make it perform.
That to me, is a true scratch build.
Everything else, in my eyes, where you buy a hull/fittings - then it becomes semi-scratch build.
The closest I have ever become to a scratch build was my Fairmile B. I chickened out at making the anchor chains and the props. Also the portlights which I bought previously for another model. So, I can safely say 100% of my models are semi-scratch built.
The reason I semi-scratch is, in the very beginning, like a lot of us, we couldnt affort to purchase kits - pocket money wouldnt stretch to 16 shillings and sixpence and couple of sheets of balsa wood and scrounge some offcuts from the timber yard, yet :)
But to be honest though, now, the enjoyment for semi-scratch is to see the actual model come from the plans. Each piece you make be added.
As you know, I have already attempted to build for a kit, and quite honestly I struggled. Not because of the difficulty of the kit, but the difficulty in following someone else's instructions. There were so many times I wanted to do it MY WAY and there was a nagging thought at the back of my mind - if I go off my way, I may overlook something I should have added in earlier on.
so, yes, these guys who purchase kits and do it their way, are just as skilled as anyone else, if not more so.
At the end of the day whether you scratch build, semi-scratch build or kit build - it makes you happy and you are pleased with what you are doing THAT IS WHAT COUNTS - we arent building a model to prove we are better than anyone else - we are building for enjoyment.
Right, Im off to see if I can understand my 'daft' plan.
Aye
John E
Bluebird
