Pages: 1 2 3 4 [5]   Go Down
Author Topic: Tyne Class Life Boat  (Read 18026 times)
Perkasaman2
Re: Tyne Class Life Boat
« Reply #100 on: September 22, 2021, 01:31:45 am »
Well done with all your work and patience. Your Tyne class is very impressive.
Trucker
« Reply #101 on: September 23, 2021, 06:36:42 pm »
Thank you for your encouragement  :-)) , heres a another picture of my latest parts made and added, ive now added a new black rubber fender around the hull, a new and better looking chain guide at the bow and a new roller behind that, the roller and guide are completely fabricated from many parts and sanded and shaped.
Trucker
Trucker
« Reply #102 on: September 23, 2021, 07:50:40 pm »
 %%  Also have in the last few minutes completed and tested all the lighting using a Action P44 switcher, im impressed.....
Trucker
Trucker
« Reply #103 on: September 24, 2021, 06:56:41 pm »
lighting up  :-))  all working as i had hoped, a big thanks to all that i have had help from from this forum regarding the electrics.
Trucker
Trucker
« Reply #104 on: September 25, 2021, 06:10:57 pm »
Hi all, constructed the two large  whip aerials today, most parts are aluminium tube, a brass sleeve was made into the bracket which holds the legs thats glued into position, next step some paint.
Trucker
Trucker
« Reply #105 on: October 10, 2021, 06:09:03 pm »
 :((   put the tyne on the kids garden pool today, found it needed very little ballast which i thought was a good thing, secondly i found i had to put a lager main fuse in, i now have a 25 amp, but the most disturbing of all, it bloody leaks, can only be from around where the shaft go through aaaaaahhhhhh.
Trucker
Trucker
« Reply #106 on: October 16, 2021, 08:04:43 pm »
Traced the point where the leak is entering the hull, now to etch a plan for the repair, fiber glass is looking the best option to me, but it means another set back  {:-{
Trucker
RST
« Reply #107 on: Yesterday at 02:05:26 am »
Hi, excuse my forgetfulness but looking back to early posts I can't remember if you built on a PS hull from sarik or a grp one from elsewhere?  Where's the leaks coming from?  It's looking very fantastic anyway.
Trucker
« Reply #108 on: Yesterday at 06:11:21 pm »
Hi, Rich.
Its been so long now from when i purchased the hull i cant remember where i actually purchased it, its a thin plastic hull. the leak appears to be from the area where i put the port side shaft through the hull...BUT, i now have worse things to fix, in my attempt to try and fix the leak i put a good lump of evostick gripall around the area of the leak DO NOT DO THIS ,, it generates heat and over a couple of days has destroyed the plastic and now has no strength or stability a massive rebuild is now on the cards. lots of tears and choice words around my garden...
Trucker
Pages: 1 2 3 4 [5]   Go Up
