Pages: 1 2 [3]   Go Down
Author Topic: Speedline Tamar Lester 1/12  (Read 22033 times)
Holger
Re: Speedline Tamar Lester 1/12
« Reply #50 on: August 04, 2019, 07:18:25 pm »
yes .. for £ 4,76
Holger
« Reply #51 on: August 23, 2019, 08:05:18 pm »
last sunday it was finally time for me to do the jungvernfahrt .. here are a few pictures of it and a little video .. it's only very short because i had to drive and film .. i hope i will not be alone again next Sunday drive and someone to film is with ..
except for some water inside, I am very satisfied first ..
 and it is a dream to drive this boat .. !!!!!!! :embarrassed: :embarrassed: :embarrassed:
Holger
« Reply #52 on: August 24, 2019, 06:59:59 am »
here are the pictures ..
Holger
« Reply #53 on: August 24, 2019, 07:25:59 am »
Taranis
  • Balne Moor MBC
« Reply #54 on: August 24, 2019, 08:32:54 am »
Lovely wake  :-)
ANDY
Holger
Holger
« Reply #56 on: December 26, 2020, 04:12:14 pm »
well ..
finally this year is almost over ..
It started with an illness at the beginning of the year and a necessary operation in the hospital .. after recovering, I went back to my job where I was very busy the whole year .. so I couldn't continue building at all .. thank god it was it was a bit quieter in autumn and I could FINALLY continue building again ..
but i used the recovery time and looked around the net for all sorts of information about the great role model .. and lo and behold ..
I found more than what I was looking for .. !!!!!!!!!
I discovered the following two sides ..
https://matterport.com/de/media/2518
https://my.matterport.com/show/?m=n8zEKKbKMaG
YOU ARE THE HAMMER .. !!!!!!!!!! :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
there you can look around virtually on and in the boat and even measure everything ..
I found some details that differ from the blueprint and that I now had to change again.
For example, I redesigned the four flaps over the Y.boat .. this time only from 2mm thick plexiglass and the two middle ones are narrower than the outer ones .. and this time also scaled down ..
and the front and rear support of the panels are now in a slight curve .. just like the curved deck shape ..
I also changed the hinges for the plates .. I soldered the two original holes closed .. and had small circles engraved in the hinges in an engraving shop .. that's five because each hinge is attached with five screws on the original .. and they are then countersunk by the thickness of the hinge so that only the round part stands over the plates .. so it is more true to the original and I like it much better that way ..
it's going on again ..
the squirrel eats idle ..  :embarrassed: :embarrassed: :embarrassed:
Holger
« Reply #57 on: December 26, 2020, 04:18:52 pm »
Holger
« Reply #58 on: December 26, 2020, 04:21:30 pm »
Holger
« Reply #59 on: December 26, 2020, 04:25:40 pm »
Pages: 1 2 [3]   Go Up
Page created in 0.576 seconds with 21 queries.
