Pages: [1] 2 3   Go Down
Author Topic: Speedline Tamar Lester 1/12  (Read 17511 times)
Holger
« on: October 11, 2018, 06:25:50 pm »
now I'm a proud owner of the kit in 1/12 ..
au man is the big .. lol ..
I'm really looking forward to building that .. !!!!!!!!
It will still take some time until I am in the cellar of the new apartment electricity and light but until then I am diligently gathering information and worrying about how I can later realize my wishes in the reality .. it should then in my model like that much like me is possible to move and work as well as the big model ..
as soon as it starts I will share my progress with you here ..
I hope that it works with the pictures ..
Holger
Rottweiler
Re: Speedline Tamar Lester 1/12
« Reply #1 on: October 11, 2018, 10:06:46 pm »
If you think that is big,you had better not buy a Severn model or a Clyde model in the same scale lol👍👍
Mick F
Holger
« Reply #2 on: October 12, 2018, 05:28:17 am »
Hoi Mick ..
I was only surprised by the size .. Although I have used a ruler when ordering .. but he does not show the true dimensions .. lol ..
but now I'm happy about it ..
my first work will be the grinding of the hull .. from the bow tip extends over the keel to the heel seams .. below the tailgate are also seams and at the transition from the hull to the deck are almost all around smaller dents and corners ..
they have to get away so that the hull is perfect too ..
the actual work with the keels begins ..
Holger
Holger
« Reply #3 on: October 13, 2018, 05:58:53 pm »
drive search ..
by Adrian and some others, the emax 4030 is recommended .. but after intense search, I find him not .. he will probably no longer manufactured ..
by a note from Taranis I came across the Turnigy Aerodrive SK3 - 4250-410KV ..
and that will probably be my drive setup ..
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-4250-410kv-brushless-outrunner-motor.html
https://hobbyking.com/de_de/hobbyking-90a-boat-esc-4a-sbec.html
https://hobbyking.com/de_de/turnigy-battery-5000mah-5s-25c-lipo-pack-xt-90.html
what do you think .. ??
kinmel
« Reply #4 on: October 13, 2018, 07:18:35 pm »
I recommend you buy a programming card as well .....  https://hobbyking.com/de_de/hobbyking-boat-esc-programming-card.html
My Tamar never needed higher than 25 amp fuses with similar motors.
Many are using the same motors with the Speedline Shannon and have found the Turnigy ESCs to be a better product....
https://hobbyking.com/de_de/catalogsearch/result/?cat=&q=+9261000054-0 ( 50 amp )  or https://hobbyking.com/de_de/catalogsearch/result/?cat=&q=9261000056-0  ( 90 amp )
plus the card to match...  https://hobbyking.com/de_de/catalogsearch/result/?cat=&q=9261000059-0
Taranis
  • Balne Moor MBC
« Reply #5 on: October 13, 2018, 07:30:00 pm »
I agree with Alan and I use the 50amp Turnigy marine ESC too. Despite numerous thrashings they won't take out a 25 amp fuse  :-))  I no longer fit fuses and rely on the ESC to protect itself.
They are on the lower equipment shelf with servos and pumps.
A different boat yes and we use 1185kv 35-42 which may not be suitable for the Tamar so I would stick to the tried and tested.
An out of date picture without upper shelf and fuses now scrapped
ANDY
Holger
« Reply #6 on: October 13, 2018, 07:45:49 pm »
Sorry .. the programming card I had forgotten to write with ..
the regulator the Kinmel .. - he is called Alan .. ?? - I think it's fitting ..  :-)) :-))
and thanks for the pictures
Holger
Holger
« Reply #7 on: November 27, 2018, 05:39:13 pm »
After a long break, I now report back .. Meanwhile, the heart of Tamar has arrived and I have started to drill the rudder blades .. and although I have bored very slowly is partially way the half millimeter from the edge melted as I think .. but if I embed the 4 mm stainless steel rod, the holes are filled again .. after grinding the rudder shape and painting it will be nothing to see ..
« Reply #8 on: November 27, 2018, 06:20:40 pm »
Holger
« Reply #9 on: November 28, 2018, 02:47:32 pm »
yes Neil .. so it should actually be read .. I hope it works now synonymous with the images to ..
Holger
« Reply #10 on: November 30, 2018, 05:56:10 pm »
the last two parts .. the covers of the water inlets - are now there .. I would like to use them to cool over a small pump, the two controllers .. now I have everything then in winter to finish everything so that the Tamar in the spring the first time into the water can ..
Taranis
  • Balne Moor MBC
« Reply #11 on: November 30, 2018, 06:45:58 pm »
Very realistic  :-))
ANDY
gingyer
« Reply #12 on: November 30, 2018, 08:56:40 pm »
Where did you get those covers from??
Holger
« Reply #13 on: December 01, 2018, 11:35:58 am »
Hoi Ginger
I let them have 3D print from the company ..
https://www.3dnetzwerk.com/zeitdruck/
but surely there is someone near you who can print them for you .. I have a drawing with the measurements from the article here by OVL - TAMAR Speedline 1/12 - made page 2 and sent to the company ..
greetings Holger
Holger
« Reply #14 on: December 01, 2018, 11:41:22 am »
Very realistic  :-))
yes Taranis ..
they look great .. I am now only on the superior if I leave them in color as the color is already very close to the original color approach ..
gingyer
« Reply #15 on: December 01, 2018, 01:14:17 pm »
Thanks for that information
furball
« Reply #16 on: December 02, 2018, 05:39:35 pm »
Did you get an STL file from the 3D printing company, or did you send them one?
Lance
Holger
« Reply #17 on: December 03, 2018, 07:39:07 am »
Neither Lance nor .. I have sent him a drawing with the measurements .. he then gave me a picture of the model if it is ok for me or if I may have change requests .. he has then changed something .. me again then sent a picture again and I then gave my ok to print .. but you will surely find someone near you or on the island .. from here, too, the shipping would be very expensive ..
Holger
howardspary
« Reply #18 on: December 08, 2018, 03:04:18 pm »
hi all again
are the bolts supplied by speedline on the 1/12 scale  tamar 14ba or 12ba with head one size smaller,have had reply from member in cornwall has some spare from his trent build may contact him as the size seems difficult to obtain
thanks for members help
howard spary#
scuppers
kinmel
« Reply #19 on: December 09, 2018, 06:12:18 am »
they are  12BA Steel Hex Head Bolts (one size smaller head)  and are usually in stock at ...
https://www.chronos.ltd.uk/acatalog/Steel_Hex_Head__one_size_smaller__BA_Bolts.html    -  Scroll down the page for 12BA
Holger
« Reply #20 on: December 26, 2018, 06:19:17 pm »
now it goes slowly forward .. first I would like to prepare the hull for painting and then drill everything .. grind .. this should also come to the two water inlets on the rear fuselage bottom .. but since they are not shown in the plans I need now necessarily the dimensions for the right position ..
It would be great if someone could help because they belong to the boat and 2. I would like to use them to cool the two controllers.
Thank you, Holger says
Charlie
  • I spend far too much time on Model Boats Mayhem!
    • My Youtube Channel
« Reply #21 on: December 27, 2018, 09:56:00 am »
Hi Holger,
If the location is not shown on the drawings, you can always use photos to find the location. I found this one on the net which may assist you. Water Inlet is circled.
Charlie
gingyer
« Reply #22 on: December 27, 2018, 10:11:37 am »
https://www.modelboatmayhem.co.uk/forum/index.php/topic,51542.50.html
Is that them in the drawing in the picture top of the page?
furball
« Reply #23 on: December 27, 2018, 11:35:55 am »
This is what I let into the hull, they’re commercial aluminium inlets.
The centre of the block is 145mm from the stern and 38mm from the chine. They’ll have the oval grills added when I’Ve made some.
Lance
Holger
« Reply #24 on: December 30, 2018, 12:17:05 pm »
Hoi Charlie ..
the picture is awesome .. !!! because of the arrangement of the main engine sea water inlets .. but also the many other details .. - keels .. and so on ..
where did you find it in the net .. ??
I wish you and your family a happy new year ..
Pages: [1] 2 3   Go Up
Page created in 0.119 seconds with 22 queries.
