I tried various ideas put forward by the kind people on this site, but the problem was definitely cavitation, and only when turning right, even a small deflection of the rudder was enough to start it.
So I made a crude prototype rudder, as per photo.(I did not want to drill the hull and fit two new rudder tubes)
This has cured the problem and I plan to refine the idea over the winter. 0ne idea is that the flat part of the assembly, at the top, that bridges the two blades could be extended and angled to form a trim tab (without drilling the transom) I also plan to move the blades closer together.
On the lake today she seemed more stable and her wake was smoother, altogether an improvement in handling, also steered better in reverse.
Thanks again for previous input, all comments welcome
