Author Topic: 3 masted square rigger- Brigg. Grp hulls  (Read 3614 times)
john44
« on: November 06, 2018, 01:20:43 pm »
Hi guys, can anyone tell me where I can find a fiberglass hull to make a 3 masted square rigger
That I can build for sailing. About 36" with a mast height of about 30"
Many thanks.
Re: 3 masted square rigger- Brigg. Grp hulls
« Reply #1 on: November 08, 2018, 01:15:11 am »
***Topic now split***
New topic Ketch vs Schooner here
http://www.modelboatmayhem.co.uk/forum/index.php/topic,62023.0.html
john44
« Reply #2 on: November 08, 2018, 09:51:54 am »
Hi guys good news a friend has offered me plans for the Raven/Swift brigantine so I will be looking
For a suitable hull when I go to Warwick on Sunday. A schooner or west coast trading ketch hull are
Favourite up to now, what do you think.
Thanks very much for your valuable input tiger.
tony52
« Reply #3 on: November 08, 2018, 04:14:44 pm »
Scale-sail hulls are available from Chris Brown Model Boats. A 36" long hull is under the Clinker effect tab.
http://www.christopher-wyn-brown.co.uk/modelboats/
john44
« Reply #4 on: November 17, 2018, 11:27:26 am »
Hi, could a moderator please remove this thread. I have a hull on order from M B D.
Thank you
« Reply #5 on: November 18, 2018, 07:47:45 am »
I would like to leave it up for future reference. Others may also want to buy a schooner hull.
john44
« Reply #6 on: November 18, 2018, 11:40:12 am »
Ok by me :-))
rcboater1
  • Webmaster, Marine Modelers Club of New England
    • Marine Modelers Club of New England
« Reply #7 on: December 29, 2018, 11:30:45 pm »
What is “M B D”?   I tried googling it, didn’t get any matches that looked like a supplier of model boat hulls....
Maybe it is shorthand??
Webmaster and Newsletter Editor
« Reply #8 on: December 30, 2018, 12:14:22 am »
MBD.......one possibility?
raflaunches
  • The Penguins are coming!!!
« Reply #9 on: December 30, 2018, 09:38:27 am »
Models By Design
I’m only guessing but that’s the only one I know with those initials.
Nick B
Illegitimi non carborundum!
john44
« Reply #10 on: December 30, 2018, 07:11:55 pm »
Models By Design
Yes you are right Models by Design it is.
JerryTodd
  • Scale Sailor
    • Modeling Projects
« Reply #11 on: February 07, 2019, 03:08:50 am »
There's someone making "square-rigger" hulls?  And I've been building mine all this time.
john44
« Reply #12 on: February 07, 2019, 09:41:38 am »
Hi guys, decided to build a brigantine instead of a 3 masted square rigger.
The grp hull from Models by Design was superb as expected.
« Reply #13 on: February 07, 2019, 09:59:00 am »
Airfix and heller have been doing it for years  {-) {-) {-) {-) :P
john44
« Reply #14 on: February 09, 2019, 02:58:13 pm »
Hi guys, could anyone tell me what angular degrees the sails should be set at on the brigantine
The hull is 37 1/2" in length, jib, square sails, mizzen etc. Or is it trial and error until you get it right.
JerryTodd
  • Scale Sailor
    • Modeling Projects
say what?
« Reply #15 on: February 09, 2019, 05:34:53 pm »
Are you setting sails on a static model to a certain point of sail?
If this is a sailing model (as in actually goes in the water and gets pushed around by the wind), then the angles change depending on the angle of the vessel relative to the wind.
If you're talking a free-sailing model, sit the model pointed in the direction it's going to go across the pond, and set the sails so they are all full and drawing, then place it in the pond and hope it balances.  You might make rudder adjustment to trim for the next run, and so forth.   If it doesn't balance, then there's an issue between the rig, the fin, and the rudder.
john44
« Reply #16 on: February 09, 2019, 08:51:48 pm »
Hi Jerry, I am setting the sails on a sailing (in the water) servo controlled boat.
JerryTodd
  • Scale Sailor
    • Modeling Projects
« Reply #17 on: February 10, 2019, 04:13:00 am »
Then I think you'll need to go into a bit more detail about what you meant by "what angular degrees the sails should be set at on the brigantine" and what it's size has to do with that.
Do you mean the rotation of the yards, how close to center the fore-n-afts come in, the rake of the masts, there's a lot of angles on a boat.
john44
« Reply #18 on: February 10, 2019, 09:28:47 am »
Hi again jerry, the rake of the mast I have made adjustable till I see what she is like on the water
It is the hauled in setting to centre I was after and the max, settings for when the sails are let out.
JerryTodd
  • Scale Sailor
    • Modeling Projects
« Reply #19 on: February 11, 2019, 03:52:13 am »
Ok, I get it!
The mains'l - that is the big gaff-headed fore-n-aft sail on the mainmast, can only swing out as far as the main shrouds and backstays allow and your servo ought to allow that.  It doesn't need to go out to 90°, 80° will do fine.
The heads'ls depend on how you're going to control them and if they overlap.
If you look at real square riggers, you'll note the heads'l do not sheet to the center line of the boat, but out at the rail.  Drawing them in to the center will actually work against you when sailing.I control my heads'l with a semophore-arm set-up.  The jib-sheets are on free-swinging arms pushed by a sail-arm-servo.  When it's pushing one, the other is slack, like real jibs.  The spanker sheet is run to the arm itself, so the servo operates the heads'ls and the spanker.
The spanker, or in your case, the main, are not sheeted to the center-line either.  My spanker sheet anchors to a eyebolt on the waterway in the port-quarter, runs up through a block on the boom, then down through a fairlead in the waterway on the starboard quarter, below decks to the to sail-arm in the diagram above.
john44
« Reply #20 on: February 11, 2019, 08:12:49 am »
Hi jerry, thank you for the info and drawings, it has made things a lot clearer in how a model
sails and where to attach the control chords.
Thank you for taking the time out to answer my post it is appreciated.
JerryTodd
  • Scale Sailor
    • Modeling Projects
« Reply #21 on: February 11, 2019, 01:25:34 pm »
Click the My Webpage link under my signature, I document my projects with diagram, notes, and photos showing everywhere I fell on my face just so other folks can avoid the same holes.
john44
« Reply #22 on: February 11, 2019, 10:03:46 pm »
All I can say Jerry is WOW :o  amazing model making.
Page created in 0.108 seconds with 21 queries.
