Author Topic: small springs  (Read 5099 times)
durhambargeman
small springs
« on: September 22, 2007, 03:51:33 pm »
 Hello all, Does anyone know of a supplier of small springs, principally for use in tensioning control cords inside the hull.
portside II
  • tugs at rest
Re: small springs
« Reply #1 on: September 22, 2007, 06:20:30 pm »
there must be a few supliers out there for you,but for a suply of various sized springs try unwanted turntables and casette players etc from your
recyling center (tip/dump) there are lots in these items and if its an older model with a radio in you even get pullys and string as a bonus O0
daz
Roger in France
Re: small springs
« Reply #2 on: September 22, 2007, 06:53:21 pm »
The moral of this is....never throw anything away.
I broke a plastic washing line peg yesterday (......don't ask!). I immediately thought, "Ah, there is a small, strong spring and a couple of paint stirrers with a little notch to rest on the edge of a tinlet".
Roger in France.
Re: small springs
« Reply #3 on: September 22, 2007, 07:03:11 pm »
Assorted springs here, click on "Miscellaneous Fixings" and scroll down.
http://www.yellowcatshop.co.uk/shop/default.asp?clientid=14&gid=4dmod&viewstate=32769&tabcatid=3500045
 O0
bogstandard
Re: small springs
« Reply #4 on: September 22, 2007, 07:05:04 pm »
If you go around the tool traders on market stalls some usually have mixed boxes of springs for a few pounds, or if you go onto the net you can get the same sort of thing but you have to pay the postage. If you have to buy them individually as I had to do a week ago from a local engineering supplier, £1-80p each plus the dreaded vat.
Most spring manufacturers have a rather large minimum order of say about £20.
I tend to take apart anything mechanical before it is thrown away, disposable lighters and click ballpoints are a good source of small compression springs.
RickF
Re: small springs
« Reply #5 on: September 22, 2007, 07:20:31 pm »
We have a "cheapo" shop locally called QD - part of a chain. Don't know if they have them where you live, but they have all sorts of cheap tools, which, as a serial tool abuser, suit me down to the ground. More to the point, however, they do "bargain boxes" at a quid a time - 100 assorted screws, washers, metric nuts and bolts -  and springs.
Worth looking out for.
Rick
Re: small springs
« Reply #6 on: September 23, 2007, 01:14:51 pm »
If the line is accessible, stationary stores do a pack of about 100 spring tensioning devices for about 80p.  They call them rubber bands, but we know better.
I have just a few minutes ao had to change a bulbholder - twp small spirings fell out of the remains of the old one.
durhambargeman
Re: small springs
« Reply #7 on: September 23, 2007, 02:18:38 pm »
 Thanks for all the advice fellers. I am now dismantling every household appliance and gadget. There must be some springs in there somewhere.
Re: small springs
« Reply #8 on: September 23, 2007, 05:10:51 pm »
Well, for God's sake don't start on the vacuum cleaner! I did once and the spring chased me round the room. It was like a Python had got loose. And as I was supposed to be mending the thing I had to work out how to get it back in the cage. Never again!
Bluebird v2
Re: small springs
« Reply #9 on: September 23, 2007, 07:25:00 pm »
Ah, Colin, you have what is known in my house as the 'Drumming Bear' syndrome  ;D Quick explanation:
When my son was very small, he had a drum playing plastic bear that we used to wind up and one day it failed, over to Dad to fix. So, 18 years later bits of bear are still in the box, main spring sprung..never to be seen again..but, on a more serious note,
How about the clicky top biro pens, there are springs in them; and by hey there are some 'howking geet' big springs in an automatic washer and aye, I could tell you a good story about them too.
As previously mentioned I have also dismantled an old cassette player that I thought my son had finished with, to use some of the springs and pulleys in there.
aye
john e
bluebird
ps my son doesnt know about the cassette player yet  :P
edible_engine
Re: small springs
« Reply #10 on: September 24, 2007, 01:25:07 am »
if you want a long thin spring take apart a empty lighter one with a flint
HS93 (RIP)
  • I cannot spell , tough
Re: small springs
« Reply #11 on: September 24, 2007, 02:38:39 am »
I got some from Bruce eng , they are compression but you can tread the wire through the spring on both ends and it should work
http://www.pollymodelengineering.co.uk/sections/bruce-engineering/materials.asp
Peter
durhambargeman
Re: small springs
« Reply #13 on: September 25, 2007, 09:37:52 am »
 Thanks once again chaps, as usual one finds a lot of helpful folk on this forum.
